ACC-3650 | copy flash:TAC_memory_monitoring.txt usbflash0 cannot copy
rindika7966
Im trying to copy the below file, but it dosent copy to USB.
25 Replies 25
Ok, so copying the file to another is not a problem, however, copying a file from the flash to the thumb drive is a problem.
Get a different flash drive.
I tried 3 usb drive .. all are same issue.
before copy are you able to view the file content of USB ? if not there device not detecting the USB at all.
other option you can use TFTP to copy that file.
BB
any update?
Dump the output to a file into your computer.
terminal len 0
more flash:TAC_memory_monitoring.txt
WHQ21FRK1-ACC-3650-1#more flash:AC_monitoring.txt
%Error opening flash:AC_monitoring.txt (No such file or directory)
I have fixed the command.  Please try again.
kindly check file attached ,,,,,check the mail
the file too large,, cannot send
WHQ21FRK1-ACC-3650-1#more flash:TAC_memory_monitoring.txt
*12:00:00.335 WAT Mon Feb 26 2024
------------------ History of Processor Mempool ------------------
666666666666666666666666666666666666666666666666666666666666
111111111111111111111111111111111111111111111111111111111111
100
90
80
70
60 **********************************************************
50 **********************************************************
40 **********************************************************
30 **********************************************************
20 **********************************************************
10 **********************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
Free memory per second (last 60 seconds)
100
90
80
70
60 ##########################################################
50 ##########################################################
40 ##########################################################
30 ##########################################################
20 ##########################################################
10 ##########################################################
Free memory per minute (last 60 minutes)
* = maximum # = average
666666666666666666666666644444444444444444444444444444444444444444444444
111111111111111111111111166666666666666666666666666666666666666666666666
100
90
80
70
60 ########################*
50 ######################################################################
40 ######################################################################
30 ######################################################################
20 ######################################################################
10 ######################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
Free memory per hour (last 72 hours)
------------------ History of lsmpi_io Mempool ------------------
100
90
80
70
60
50
40
30
20
100
90
80
70
60
50
40
30
20
100
90
80
70
60
50
40
30
20
Buffer elements:
1401 in free list
1129683070 hits, 0 misses, 1019 created
Public buffer pools:
Small buffers, 104 bytes (total 1200, permanent 1200, peak 1230 @ 7w0d):
1200 in free list (200 min, 2500 max allowed)
735431170 hits, 10 misses, 30 trims, 30 created
0 failures (0 no memory)
Middle buffers, 600 bytes (total 900, permanent 900, peak 906 @ 7w0d):
898 in free list (100 min, 2000 max allowed)
529011192 hits, 2 misses, 6 trims, 6 created
Big buffers, 1536 bytes (total 900, permanent 900, peak 931 @ 7w0d):
900 in free list (50 min, 1800 max allowed)
564695628 hits, 60 misses, 31 trims, 31 created
VeryBig buffers, 4520 bytes (total 100, permanent 100, peak 147 @ 7w0d):
99 in free list (0 min, 300 max allowed)
139358 hits, 2014 misses, 47 trims, 47 created
2014 failures (0 no memory)
Large buffers, 5024 bytes (total 100, permanent 100, peak 144 @ 7w0d):
100 in free list (0 min, 300 max allowed)
877 hits, 1137 misses, 44 trims, 44 created
1137 failures (0 no memory)
VeryLarge buffers, 8256 bytes (total 100, permanent 100, peak 153 @ 7w0d):
81130212 hits, 841 misses, 53 trims, 53 created
841 failures (0 no memory)
Huge buffers, 18024 bytes (total 20, permanent 20, peak 71 @ 7w0d):
20 in free list (0 min, 33 max allowed)
1906 hits, 364 misses, 55 trims, 55 created
364 failures (0 no memory)
Interface buffer pools:
CF Small buffers, 104 bytes (total 101, permanent 100, peak 101 @ 7w0d):
101 in free list (100 min, 200 max allowed)
12 hits, 0 misses, 9 trims, 10 created
Generic ED Pool buffers, 512 bytes (total 101, permanent 100, peak 101 @ 7w0d):
101 in free list (100 min, 100 max allowed)
0 hits, 0 misses
CF Middle buffers, 600 bytes (total 101, permanent 100, peak 107 @ 7w0d):
20755299 hits, 2 misses, 15 trims, 16 created
Syslog ED Pool buffers, 600 bytes (total 1057, permanent 1056, peak 1057 @ 7w0d):
1025 in free list (1056 min, 1056 max allowed)
4886 hits, 0 misses
EOBC19/0/1 buffers, 1524 bytes (total 256, permanent 256):
256 in free list (0 min, 256 max allowed)
1526440622 hits, 0 fallbacks
CF Big buffers, 1536 bytes (total 26, permanent 25, peak 26 @ 7w0d):
26 in free list (25 min, 50 max allowed)
19571534 hits, 0 misses, 9 trims, 10 created
IPC buffers, 4096 bytes (total 2496, permanent 2496):
2474 in free list (832 min, 8320 max allowed)
39980635 hits, 0 fallbacks, 0 trims, 0 created
CF VeryBig buffers, 4520 bytes (total 3, permanent 2, peak 3 @ 7w0d):
3 in free list (2 min, 4 max allowed)
128 hits, 0 misses, 9 trims, 10 created
CF Large buffers, 5024 bytes (total 2, permanent 1, peak 2 @ 7w0d):
2 in free list (1 min, 2 max allowed)
0 hits, 0 misses, 9 trims, 10 created
IPC Medium buffers, 16384 bytes (total 2, permanent 2, peak 8 @ 7w0d):
2 in free list (1 min, 8 max allowed)
16 hits, 11 fallbacks, 6 trims, 6 created
11 failures (0 no memory)
Private Huge IPC buffers, 18024 bytes (total 1, permanent 0, peak 1 @ 7w0d):
1 in free list (0 min, 4 max allowed)
Private Huge buffers, 65280 bytes (total 1, permanent 0, peak 1 @ 7w0d):
IPC Large buffers, 65535 bytes (total 17, permanent 16, peak 30 @ 7w0d):
17 in free list (16 min, 16 max allowed)
274 hits, 10 misses, 1521 trims, 1522 created
Header pools:
Header buffers, 0 bytes (total 266, permanent 256, peak 266 @ 1d01h):
10 in free list (10 min, 512 max allowed)
253 hits, 3 misses, 0 trims, 10 created
256 max cache size, 256 in cache
2847581 hits in cache, 0 misses in cache
Particle Clones:
1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 384, permanent 384):
128 in free list (128 min, 1024 max allowed)
256 hits, 0 misses, 0 trims, 0 created
0 hits in cache, 0 misses in cache
Normal buffers, 512 bytes (total 512, permanent 512):
384 in free list (128 min, 1024 max allowed)
128 hits, 0 misses, 0 trims, 0 created
128 max cache size, 128 in cache
Private particle pools:
lsmpi_rx buffers, 416 bytes (total 8194, permanent 8194):
0 in free list (0 min, 8194 max allowed)
8194 hits, 0 misses
8194 max cache size, 0 in cache
378089930 hits in cache, 0 misses in cache
lsmpi_tx buffers, 416 bytes (total 4098, permanent 4098):
0 in free list (0 min, 4098 max allowed)
4098 hits, 0 misses
4098 max cache size, 4097 in cache
2927551 hits in cache, 0 misses in cache
Processor Pool Total: 886321088 Used: 341024648 Free: 545296440
lsmpi_io Pool Total: 6295128 Used: 6294296 Free: 832
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 351167224 75898912 250600688 0 0 *Init*
74 0 27422372968 27174625896 31257880 0 765576 IOSD ipc task
425 0 12229312 4939664 6413312 0 0 Stby Cnfg Parse
169 0 8458864 136432 5681816 0 0 SNMP MA SA
0 0 0 0 4267688 0 0 *MallocLite*
382 0 3938440 5680 3989760 849828 0 EEM ED Syslog
0 0 1260194968 1250922168 2695992 17486679 0 *Dead*
1 0 2291968 13984 2326456 0 0 Chunk Manager
89 0 1602696344 1156371200 1802240 9648 0 cpf_msg_rcvq_pro
395 0 1519904 43720 1521184 0 0 EEM Server
83 0 4460016 716072 1266880 0 0 REDUNDANCY FSM
4 0 5352840 1679504 957256 0 0 RF Slave Main Th
433 0 82415408 272147808 508224 0 0 SISF Main Thread
196 0 140239496 74337104 485248 0 0 CDP Protocol
76 0 695672 148808 477400 0 0 NGWC_OIRSHIM_TAS
285 0 27833568 27407720 439064 0 0 XDR receive
383 0 380872 5680 432192 72316 0 EEM ED Generic
29 0 778464 1408 406392 0 0 IPC Seat RX Cont
179 0 1104630776 1122490832 373160 0 0 VMATM Callback
360 0 304816 2816 371000 0 0 Crypto IKEv2
509 0 225848 896 270064 0 0 IPC LC Message H
271 0 71181536 142794096 270032 0 0 MLDSN L2MCM
254 0 69640856 149612720 269520 0 0 IGMPSN L2MCM
210 0 631040 340616 265840 0 0 mDNS
305 0 1824 0 262824 0 0 COPS
73 0 23979832 23647488 251096 0 0 Standby service
427 0 167784 448 236336 0 0 MRIB Process
10 0 108211264 107561984 231064 102863311 102167423 Pool Manager
265 0 70440 448 186992 0 0 AN
238 0 123576 608 179968 0 0 IP Connected Rou
342 0 1029288 853104 176496 0 0 Crypto CA
431 0 217456 72776 172288 0 0 RADIUS
106 0 174936 2888 171576 0 0 ARP HA
204 0 98736 0 167736 0 0 IPAM Manager
445 0 48632 1728 165632 0 0 LICENSE AGENT
424 0 93184 5256 155104 0 0 VLAN Manager
159 0 100560 0 145560 0 0 radius dtls clie
195 0 99104 368 143736 0 0 ACCT Periodic Pr
321 0 99184 448 143736 0 0 Timer Library
270 0 30664 7456 142392 0 0 HTTP CORE
401 0 247152 91296 138776 0 0 Call Home proces
131 0 216464 84160 136096 0 0 EEM Callback Thr
101 0 126344 17912 132008 0 0 DHCP Snooping
67 0 620864 39528 126880 0 0 Net Background
176 0 9336 2304 125632 0 0 PKI/SSL IPC proc
75 0 11032 13744 119328 0 0 IOSD chasfs task
161 0 2600 448 119152 0 0 Ethernet CFM
165 0 73984 0 118984 0 0 Switch Backup In
391 0 13328 11728 118600 0 0 WSMAN Process
447 0 0 0 118248 0 0 SEP_webui_wsma_h
448 0 0 0 118248 0 0 SEP_webui_wsma_h
348 0 776 1040 117776 0 0 TPS IPC Process
442 0 0 0 117248 0 0 WSMA_NOTIFY
357 0 0 0 117000 0 0 Crypto ACL
240 0 0 0 117000 0 0 BSO task
170 0 448 448 117000 0 0 SNMP DBAL WRAPPE
267 0 0 0 117000 0 0 AN CONFIG DOWNLO
266 0 0 0 117000 0 0 AN HELPER
349 0 408 704 117000 0 0 WCM/AAA IPC proc
369 0 448 448 117000 0 0 ASP Process Crea
436 0 77512 178440 117000 0 0 SNMP ENGINE
95 0 131296 75520 117000 20880 0 DBAL EVENTS
435 0 409904 355904 117000 0 0 PDU DISPATCHER
511 0 71176 0 114768 0 0 CEF RP Backgroun
299 2 222120 175296 113624 0 0 Virtual Exec
362 0 169728 448 111712 0 0 PIM HA
207 0 66064 0 111064 0 0 IP ARP Retry Age
354 0 41464 448 110016 0 0 Crypto IKMP
154 0 53536 65677464 104328 0 0 EEM ED ND
423 0 2251080 2222024 98056 0 0 Syslog
394 0 29776 896 97880 0 0 RBM CORE
293 0 29272 1048 97224 0 0 CEF: IPv6 proces
16 0 154448 60640 92424 0 0 ifIndex Receive
57 0 84344 18624 85920 0 0 client_entity_se
318 0 104848 448 83464 0 0 SCTP Main Proces
419 0 30736 5680 82056 0 0 EEM ED Env
190 0 36976 0 81976 0 0 VRRS Main thread
191 0 37816 1096 81720 0 0 MKA
371 0 30256 5680 81576 0 0 EEM GED BINOS PR
35 0 284024 249080 79944 0 0 ARP Input
397 0 51000 1280 76904 0 0 DCM snmp dp Thre
338 0 7832 776 76680 0 0 AAA Proxy
181 0 17536 9096 75544 0 0 DTP Protocol
230 0 44984 52336 75488 0 0 CEF background p
418 0 24152 5680 75472 0 0 EEM ED Config
236 0 6304 0 74696 0 0 IP RIB Update
439 0 8019360 8017248 74192 0 0 SNMP Traps
290 0 68472 18000 73608 0 0 CEF: IPv4 proces
420 0 20352 5680 71672 0 0 EEM ED DS
421 0 20352 5680 71672 0 0 EEM ED CRASH
404 0 16408 1776 71632 0 0 EEM Policy Direc
206 0 2368 0 71368 0 0 IP ARP Adjacency
71 0 2232 0 71232 0 0 CTS CORE
72 0 2464 2280 71016 0 0 SXP CORE
333 0 2384 448 70936 0 0 TPLUS
328 0 2336 448 70888 0 0 LDAP process
345 0 1824 0 70824 0 0 PKI OCSP
437 0 2016 448 70568 0 0 IP SNMPV6
347 0 1552 0 70552 0 0 pki_app
434 0 59496 11016 70552 0 0 IP SNMP
356 0 6936 5608 69880 0 0 IPSEC key engine
379 0 31136 6008 69760 0 0 DCM Core Thread
261 0 680 23456 69680 0 0 WCM CONFIG SHARE
512 0 504 0 69504 0 0 ADJ resolve proc
297 0 408 0 69408 0 0 MFIB Master back
291 0 408 200 69408 0 0 ADJ background
292 0 73024 87472 69408 0 0 Collection proce
231 0 408 0 69408 0 0 fib_fib_bfd_sb e
199 0 408 0 69408 0 0 CEF switching ba
514 0 65912 0 69280 0 0 MRIB RP Proxy
426 0 107723069168 107723069024 69144 0 0 mdns Timer Proce
284 0 0 0 69112 0 0 PKI Trustpool
208 0 0 0 69112 0 0 IP Input
60 0 448 448 69000 0 0 XML Proxy Client
55 0 0 0 69000 0 0 License IPC serv
69 0 448 448 69000 0 0 Logger
107 0 0 0 69000 0 0 Crypto PKI-HA
54 0 0 0 69000 0 0 License IPC stat
41 0 0 0 69000 0 0 Policy Manager
68 0 1472 1472 69000 0 0 IDB Work
257 0 0 0 69000 0 0 TCP Timer
440 0 448 448 69000 0 0 NTP
438 0 0 0 69000 0 0 SNMP ConfCopyPro
344 0 0 0 69000 0 0 Crypto PKI-Rev-P
157 0 0 0 69000 0 0 CWAN OIR Handler
205 0 448 448 69000 0 0 IPAM Events
218 0 448 448 69000 0 0 PPP IP Route
373 0 0 0 69000 0 0 IKEv2 FlexVPN Pr
223 0 0 0 69000 0 0 SSS Policy Manag
235 0 0 0 69000 0 0 Routing Topology
221 0 448 448 69000 0 0 SSM connection m
359 0 0 0 69000 0 0 IPSec background
129 0 42183320 3192 69000 0 0 RFS server proce
353 0 448 448 69000 0 0 Crypto IKE Dispa
279 0 448 448 69000 0 0 Flow Exporter Pa
289 0 448 448 69000 0 0 Tunnel
278 0 448 5384 69000 0 0 Flow Exporter Ti
262 0 0 0 69000 0 0 RSVP SYNC
381 0 0 0 69000 0 0 Test AAA Client
258 0 498000 0 69000 0 0 TCP Protocols
222 0 0 0 69000 0 0 SSS Manager
250 0 0 0 69000 0 0 Ethernet PM Moni
139 0 0 0 69000 0 0 FEP background p
140 0 0 0 69000 0 0 RPS background p
320 0 0 0 69000 0 0 Opaque Database
392 0 0 0 69000 0 0 FNF background p
143 0 0 0 69000 0 0 Thermal backgrou
331 0 448 448 69000 0 0 LOCAL AAA
245 0 448 448 69000 0 0 nbar-custom-prot
246 0 448 448 69000 0 0 nbar-auto-custom
352 0 0 0 69000 0 0 Crypto INT
341 0 0 0 69000 0 0 RSA background p
244 0 448 448 69000 0 0 nbar-graph-sende
350 0 0 0 69000 0 0 encrypt proc
243 0 448 448 69000 0 0 NGCP SCHEDULER P
346 0 0 0 69000 0 0 PKI Revocation
343 0 448 448 69000 0 0 Crypto PKI-CRL
239 0 448 448 69000 0 0 Policy bind Proc
432 0 36988096 0 68544 0 0 SISF Switcher Th
408 0 15456 5680 66776 0 0 EEM ED Interface
416 0 168464 158880 66584 0 0 EEM ED Timer
414 0 15008 6248 66328 0 0 EEM ED SNMP Obje
412 0 15064 5776 65792 0 0 EEM ED RF
384 0 14248 5680 65568 0 0 EEM ED Routing
415 0 14248 5680 65568 0 0 EEM ED SNMP Noti
153 0 14208 5680 65528 0 0 EEM ED MAT
410 0 14160 5680 65480 0 0 EEM ED None
146 0 14096 5680 65416 0 0 EEM ED Identity
396 0 14056 5680 65376 0 0 EEM ED RPC
417 0 14056 5680 65376 0 0 EEM ED Test
407 0 14056 5680 65376 0 0 EEM ED Counter
409 0 14056 5680 65376 0 0 EEM ED IOSWD
406 0 14056 5680 65376 0 0 EEM ED CLI
411 0 14056 5680 65376 0 0 EEM ED OIR
413 0 14056 5680 65376 0 0 EEM ED SNMP
422 0 14056 5680 65376 0 0 EM ED GOLD
43 0 36824 88136 64944 0 0 Entity MIB API
27 0 219432 304096 64576 9240 0 IPC Seat Manager
123 0 98904 88696 63408 0 0 RF Master Main T
367 0 112569888 217355456 63392 0 0 PM Callback
193 0 29800 3008 61680 0 0 AAA Server
86 0 14800 0 59800 0 0 IF-MGR control p
307 0 19576 5048 59528 0 0 SR CapMan Proces
103 0 13656 0 58656 0 0 DHCP Snooping HA
309 0 2040 448 58592 0 0 MVPN Mgr Process
92 0 1064 776 58064 0 0 CONSOLE helper p
237 0 76128 75168 57960 0 0 IP Background
310 0 896 448 57448 0 0 Multicast Offloa
251 0 856 448 57408 0 0 AUTO LAG Protoco
288 0 408 0 57408 0 0 Tunnel FIB
314 0 0 0 57128 0 0 IPv6 RIB Event H
336 0 448 448 57120 0 0 MVRP SWITCH Proc
137 0 0 0 57000 0 0 ngpm main proces
127 0 0 0 57000 0 0 Mwheel Process
163 0 448 448 57000 0 0 MVRP Process
114 0 448 448 57000 0 0 SISF HA Process
160 0 448 448 57000 0 0 Ethernet OAM Pro
317 0 2364572408 2364572408 57000 0 0 QoS stats proces
311 0 448 11592 57000 0 0 static
232 0 0 0 57000 0 0 IP IRDP
248 0 0 0 57000 0 0 Ethernet PM Proc
249 0 448 448 57000 0 0 Ethernet PM Soft
260 0 0 0 57000 0 0 Connection Mgr
516 0 0 0 57000 0 0 Per-Second Jobs
202 0 0 0 57000 0 0 HQF TARGET DYNAM
315 0 0 0 57000 0 0 IPv6 Static Hand
312 0 448 448 57000 0 0 App Route Proces
313 0 0 0 57000 0 0 IPv6 RIB Cleanup
370 0 0 0 57000 0 0 Licensing MIB pr
319 0 0 0 57000 0 0 DynCmd Package P
355 0 0 0 57000 0 0 IPSEC manual key
399 0 16896 23912 56544 0 0 Bulkstat-Client
126 0 27248 2688 56512 0 0 Process to do EH
272 0 10096 0 55096 0 0 MRD
182 0 34772144 42364912 55096 0 0 802.1x switch
496 0 10096 0 55096 0 0 IPC ISSU Version
104 0 10096 0 55096 0 0 NGWC ILP CF Proc
275 0 4662000 4592528 54504 0 0 IGMPSN-HA
428 0 79224 776 54448 0 0 EEM Helper Threa
378 0 9712 464 54384 0 0 dcm_cli_provider
443 0 8856 0 53704 0 0 SSH Event handle
363 0 7504 448 52056 0 0 VTP Trap Process
264 0 7504 448 52056 0 0 REP BPA/EPA Proc
400 0 6752 464 51128 0 0 dcm_expression_p
9 0 6240 448 50792 0 0 Check heaps
287 0 63232 448 50784 0 0 L2TRACE SERVER
398 0 6288 464 50672 0 0 snmp dcm ma shim
377 0 4824 200 49496 0 0 dcm_cli_engine
17 0 38440 30128 49408 0 0 IPC Apps Task
402 0 52680 936 48856 0 0 Call Home DS
403 0 3720 328 48720 0 0 Call Home DSfile
298 0 3576 0 48576 0 0 EM Action CNS
188 0 3344 0 48344 0 0 TRACK Client thr
186 0 3344 0 48344 0 0 FHRP Main thread
187 0 3344 0 48344 0 0 TRACK Main threa
189 0 3344 0 48344 0 0 VRRP Main thread
124 0 3232 1872 48232 0 0 RF Master Status
198 0 32080 0 48160 0 0 Call Home Timer
515 0 2816 0 47816 0 0 Per-minute Jobs
374 0 1824 0 46824 0 0 IKEv2 Cluster Lo
334 0 1165638184 1165636504 46680 0 0 NIST rng proc
294 0 3144 2896 46416 0 0 XDR FOF process
122 0 3288 576 46240 0 0 IOSXE-RP SPA TSM
81 0 2488 1344 46144 0 0 CTS HA
115 0 92528 160 46088 0 0 Network-rf Notif
340 0 247736 246664 46072 0 0 crypto engine pr
59 0 150400 209312 45888 0 0 crypto sw pk pro
306 0 632 0 45632 0 0 Service Routing
227 0 1024 448 45576 0 0 UDLD
233 0 408 456 45528 0 0 XDR background p
226 0 572504 448 45448 0 0 Spanning Tree
37 0 896 448 45448 0 0 ATM Idle Timer
375 0 408 0 45408 0 0 Online Diag EEM
180 0 408 0 45408 0 0 Port-Security
150 0 408 1264 45408 0 0 Src Fltr backgro
105 0 1728 1152 45288 0 0 DHCPD HA
111 0 1984 1320 45288 0 0 DHCPC HA
113 0 1728 1152 45288 0 0 DHCPv6 Server HA
112 0 1728 1152 45288 0 0 DHCPv6 Relay HA
456 0 0 0 45136 0 0 IPC ISSU Version
130 0 5745216 5745216 45128 0 0 MGMTE stats Proc
283 0 0 1360 45128 0 0 SpanTree Flush
58 0 0 0 45128 0 0 SERIAL A'detect
3 0 0 0 45128 0 0 IPC Zone Manager
183 0 7405072 7405072 45120 0 0 Inline Power
78 0 0 0 45120 0 0 Ng3k envvar sync
282 0 0 1896 45120 0 0 L2MCAST Wireless
42 0 448 448 45120 0 0 DDR Timers
508 0 0 0 45120 0 0 XDR RP Ping Back
82 0 0 0 45000 0 0 CTS HA IPC flow
242 0 448 448 45000 0 0 Ether EFP Proces
256 0 0 0 45000 0 0 IGMPSN
269 0 0 0 45000 0 0 Socket Timers
80 0 0 5760 45000 0 0 STACK MGR Proces
79 0 0 0 45000 0 0 MATM SPI client
263 0 448 448 45000 0 0 REP LSL Proc
268 0 0 0 45000 0 0 NGWC stack power
274 0 0 0 45000 0 0 IGMPQR
225 0 0 0 45000 0 0 SSS Feature Time
276 0 62288 0 45000 0 0 MLDSN-HA
255 0 0 0 45000 0 0 IGMPSN MRD
174 0 448 448 45000 0 0 FMANRP REP Helpe
173 0 448 448 45000 0 0 REP Topology cha
280 0 0 0 45000 0 0 CMM IPC Msg Proc
281 0 0 0 45000 0 0 CMM event proces
175 0 448 448 45000 0 0 REP LSL Hello Pr
177 0 0 0 45000 0 0 NGWC led process
273 0 0 0 45000 0 0 MLD_SNOOP
224 0 0 0 45000 0 0 SSS Feature Mana
286 0 448 448 45000 0 0 FNF_WIRELESS_PRO
220 0 0 0 45000 0 0 RIB LM VALIDATE
172 0 0 0 45000 0 0 SNMP DBAL Cache
87 0 1592 0 45000 0 0 IF-MGR event pro
70 0 448 1504 45000 0 0 TTY Background
66 0 0 0 45000 0 0 Critical Bkgnd
259 0 0 0 45000 0 0 TCP HA PROC
64 0 0 0 45000 0 0 License HA Consi
241 0 560 560 45000 0 0 EFP Errd
295 0 0 0 45000 0 0 GLBP HA
252 0 0 0 45000 0 0 Inline power inc
63 0 448 448 45000 0 0 Licensing Auto U
219 0 267848 158288 45000 0 0 SpanTree Helper
62 0 0 0 45000 0 0 Image License br
300 0 0 0 45000 0 0 SNMP Timers
178 0 448 448 45000 0 0 PI MATM Aging Pr
302 0 0 0 45000 0 0 BFD HA
109 0 0 0 45000 0 0 REDUNDANCY peer
88 0 0 0 45000 0 0 cpf_msg_holdq_pr
61 0 0 992 45000 0 0 License Client N
217 0 448 448 45000 0 0 PPP Bind
228 0 0 0 45000 0 0 VRRS
229 0 0 0 45000 0 0 FRR Background P
110 0 0 0 45000 0 0 100ms check
168 0 0 0 45000 0 0 WLM HA IPC flow
184 0 448 448 45000 0 0 WDB Process
216 0 448 448 45000 0 0 PPP SIP
215 0 0 0 45000 0 0 PM EPD API
214 0 0 0 45000 0 0 AAA EPD HANDLER
213 0 0 0 45000 0 0 RTTYS Process
316 0 448 448 45000 0 0 DHCPv6 LQ client
166 0 8992 15256 45000 0 0 Wireless Manager
247 0 0 0 45000 0 0 CFM HA IPC messa
212 0 0 0 45000 0 0 IPv6 ping proces
171 0 0 0 45000 0 0 SNMP DBAL Cache
253 0 896 896 45000 0 0 LIM Process
322 0 448 448 45000 0 0 Crypto Support
90 0 0 0 45000 0 0 cpf_process_tpQ
324 0 448 448 45000 0 0 AAA Cached Serve
77 0 0 0 45000 0 0 NGWC OIR CC Proc
65 0 0 0 45000 0 0 Token Daemon
327 0 0 0 45000 0 0 IDMGR CORE
56 0 0 0 45000 0 0 Net Input
329 0 0 0 45000 0 0 Key chain liveke
330 0 448 448 45000 0 0 LINE AAA
164 0 4661109320 4661109320 45000 0 0 ngwc callhome pe
332 0 0 0 45000 0 0 IPC ISSU Version
53 0 0 0 45000 0 0 ARP Snoop
185 0 448 448 45000 0 0 CDP Forward Proc
335 0 448 448 45000 0 0 File Copy Handle
162 0 448 448 45000 0 0 Ethchnl
337 0 0 0 45000 0 0 COND_DEBUG HA IP
52 0 0 0 45000 0 0 WCDB ARP Process
339 0 448 448 45000 0 0 REP Switch Helpe
91 0 0 0 45000 0 0 RP HA Periodic
296 0 0 0 45000 0 0 HSRP HA
51 0 0 0 45000 0 0 Dynamic ARP Insp
158 0 0 0 45000 0 0 TP CUTOVER EVENT
156 0 7633928 7633928 45000 0 0 MATM RP Shim Pro
50 0 448 448 45000 0 0 SMART
155 0 0 0 45000 0 0 IPv6 Access Cont
49 0 448 448 45000 0 0 GraphIt
48 0 0 0 45000 0 0 IOSXE signals IO
301 0 0 0 45000 0 0 IP Traceroute
211 0 576 576 45000 0 0 PIM register asy
351 0 448 896 45000 0 0 CRYPTO MAP FREE
152 0 0 0 45000 0 0 FPD Action Proce
151 0 0 0 45000 0 0 FPD Management P
46 0 448 448 45000 0 0 Serial Backgroun
94 0 2240 39176 45000 0 0 EM_SHIM_NOTIFY_T
209 0 0 0 45000 0 0 ICMP event handl
44 0 0 0 45000 0 0 IFS Agent Manage
358 0 0 0 45000 0 0 Crypto PAS Proc
303 0 0 0 45000 0 0 STP HA IPC flow
149 0 0 0 45000 0 0 NGWC_MACSEC_IOSD
361 0 0 0 45000 0 0 IKEv2 AAA handle
93 0 94848 96216 45000 0 0 EM_SHIM_TASK
96 0 1032 1032 45000 0 0 NGWC Configurati
364 0 0 0 45000 0 0 IPC ISSU Version
365 0 0 0 45000 0 0 NCD Process
366 0 0 0 45000 0 0 SNMP LA Cache In
97 0 0 0 45000 0 0 MATM CF Flow Con
368 0 448 448 45000 0 0 dhcp snooping sw
40 0 0 0 45000 0 0 AAA_SERVER_DEADT
98 0 7791360 7791360 45000 0 0 NGWC Learning Pr
39 0 0 0 45000 0 0 CEF MIB API
372 0 448 448 45000 0 0 DHCP Security He
147 0 0 0 45000 0 0 Remote Console P
304 0 0 0 45000 0 0 AAA System Acct
308 0 0 0 45000 0 0 DNS Service
376 0 0 0 45000 0 0 SPA ENTITY Proce
192 0 0 0 45000 0 0 Spanning Tree St
99 0 0 0 45000 0 0 WPM HA Reconcile
38 0 0 0 45000 0 0 ATM ASYNC PROC
380 0 5176 15040 45000 0 0 AAA SEND STOP EV
145 0 3604800 3604800 45000 0 0 NGWC DOT1X Proce
234 0 787970224 787974728 45000 0 0 XDR mcast
36 0 4792 4792 45000 0 0 ARP Background
144 0 0 0 45000 0 0 MMN bkgrd proces
385 0 0 0 45000 0 0 Syslog Traps
386 0 0 0 45000 0 0 IPC ISSU Version
387 0 0 0 45000 0 0 ISSU Utility Pro
388 0 0 0 45000 0 0 EPC WS PI suppor
389 0 0 0 45000 0 0 EPC WS PD suppor
390 0 448 448 45000 0 0 SPAN switch
34 0 0 0 45000 0 0 SENSOR-MGR event
142 0 0 0 45000 0 0 NGWC L2M
393 0 0 0 45000 0 0 IPC ISSU Version
33 0 0 0 45000 0 0 IPC Session Deta
32 0 0 0 45000 0 0 IPC Loadometer
141 0 0 0 45000 0 0 NGWC diag proces
31 0 0 0 45000 0 0 IPC Keep Alive M
203 0 448 448 45000 0 0 IPAM/ODAP Events
201 0 560 560 45000 0 0 AAA Dictionary R
100 0 0 0 45000 0 0 DHCP Snooping cl
30 0 0 0 45000 0 0 IPC Seat TX Cont
323 0 0 0 45000 0 0 IPSECv6 PS Proc
197 0 0 0 45000 0 0 IPC ISSU Version
28 0 0 0 45000 0 0 IPC Check Queue
405 0 0 0 45000 0 0 IPC ISSU Version
138 0 0 214087600 45000 0 0 PLFM-MGR IPC pro
136 0 448 448 45000 0 0 NG Backup Interf
135 0 448 448 45000 0 0 FEC_Link_event_h
134 0 0 0 45000 0 0 IOSXE-RP FastPat
133 0 0 0 45000 0 0 SFF8472
132 0 0 0 45000 0 0 Transport Port A
117 0 0 0 45000 0 0 HA-IDB-SYNC
325 0 448 448 45000 0 0 ENABLE AAA
128 0 0 0 45000 0 0 RTTYC Flush
102 0 0 0 45000 0 0 DHCP Snooping db
125 0 0 0 45000 0 0 AggMgr Process
326 0 0 0 45000 0 0 EM Background Pr
194 0 21272 2608 45000 0 0 AAA ACCT Proc
26 0 0 0 45000 0 0 IPC Process leve
25 0 92312 336 45000 0 0 IPC Deferred Por
24 0 0 0 45000 0 0 IPC Periodic Tim
121 0 0 0 45000 0 0 ACL deny punt se
23 0 0 0 45000 0 0 IPC RTTYC Messag
22 0 0 0 45000 0 0 IPC Service NonC
21 0 0 0 45000 0 0 IPC Dynamic Cach
20 0 0 0 45000 0 0 Platform appsess
19 0 0 0 45000 0 0 IPC Mcast Pendin
167 0 448 448 45000 0 0 WLM HA
429 0 0 0 45000 0 0 SNMP LA Cache pr
430 0 0 0 45000 0 0 IPC ISSU Version
18 0 0 0 45000 0 0 IPC Event Notifi
120 0 0 0 45000 0 0 ACL Log Punt Ser
45 0 7168 7168 45000 0 0 PrstVbl
15 0 0 0 45000 0 0 DB Lock Manager
14 0 0 0 45000 0 0 IOSXE heartbeat
475 0 0 0 45000 0 0 IPC ISSU Version
12 0 448 448 45000 0 0 Timers
119 0 0 0 45000 0 0 IOSXE-RP Punt IP
11 0 0 0 45000 0 0 DiscardQ Backgro
118 0 20960 20960 45000 0 0 IOSXE-RP Punt Se
477 0 0 0 45000 0 0 IPC ISSU Version
479 0 0 0 45000 0 0 IPC ISSU Version
513 0 0 0 45000 0 0 Compute load avg
444 0 0 0 45000 0 0 IPC ISSU Version
8 0 0 0 45000 0 0 VIDB BACKGD MGR
446 0 394097032 394097032 45000 0 0 RADIUS IO STATS
7 0 0 0 45000 0 0 RO Notify Timers
6 0 91672 144 45000 0 0 IPC ISSU Dispatc
449 0 0 0 45000 0 0 IPC ISSU Version
450 0 2466864 2468152 45000 0 0 DiagCard1/-1
451 0 2478384 2479160 45000 0 0 DiagCard2/-1
452 0 2479928 2480704 45000 0 0 DiagCard3/-1
453 0 0 0 45000 0 0 IPC ISSU Version
454 0 0 0 45000 0 0 IPC ISSU Version
455 0 0 0 45000 0 0 IPC ISSU Version
510 0 0 0 45000 0 0 XDR RP Test Back
457 0 0 0 45000 0 0 IPC ISSU Version
458 0 0 0 45000 0 0 IPC ISSU Version
459 0 0 0 45000 0 0 IPC ISSU Version
460 0 0 0 45000 0 0 IPC ISSU Version
461 0 0 0 45000 0 0 IPC ISSU Version
462 0 0 0 45000 0 0 IPC ISSU Version
463 0 0 0 45000 0 0 IPC ISSU Version
464 0 0 0 45000 0 0 IPC ISSU Version
465 0 0 0 45000 0 0 IPC ISSU Version
466 0 0 0 45000 0 0 IPC ISSU Version
467 0 0 0 45000 0 0 IPC ISSU Version
468 0 0 0 45000 0 0 IPC ISSU Version
469 0 0 0 45000 0 0 IPC ISSU Version
470 0 0 0 45000 0 0 IPC ISSU Version
471 0 0 0 45000 0 0 IPC ISSU Version
472 0 0 0 45000 0 0 IPC ISSU Version
473 0 0 0 45000 0 0 IPC ISSU Version
474 0 0 0 45000 0 0 IPC ISSU Version
5 0 0 0 45000 0 0 Retransmission
Send that file to TAC (not me!).
