ACL question...
I have a Cisco 3925 Router..
I want to "redirect" Port 80/443 to a different port ...I am hoping you may let me know if this is right..
ip nat inside source static tcp xxxx.xxxx.x.x 80 interface GigabitEthernet0/0 30080
ip nat inside source static tcp xxxx.xxxx.x.x 443 interface GigabitEthernet0/0 30443
access-list 101 permit tcp any any eq 30080 log
access-list 101 permit tcp any any eq 30443 log
Also do i always need to specify an ACL when oprening Ports?
Thanks.....
access-list 1 remark --- GigabitEthernet0/2 MY LAN-(LAN) ---
access-list 100 remark --- GigabitEthernet0/2 MY LAN ---
access-list 101 remark --- GigabitEthernet0/0 SPECTRUM-(WAN)(DHCP-bootps/bootpc) ---
ONLY you need what you mention in your original post, this ACL need to pass the ACL you apply to WAN interface.
no need any other change. you config is perfect.
19 Replies 19
no need acl, only NAT need.
balaji.bandi
i am hoping the traffic coming from out side  and you like to port-forward to internal Server ?
xxxx.xxxx.x.x  - is the internal IP ?
GigabitEthernet0/0  - IP getting from ISP ? or static ?
so the router knows  internal server xxxxxxxx  how to reach? never connect IP address ?
BB
xxxx.xxx.xx.x is internal IP
Gigabitethernet0/0 is OUTSIDE (DDNS)
the only case that we use ACL with port forwarding it to exclude the IP-L4Port from dynamic NAT applied to same interface.
so just to clarify...so I really understand...all of the ACL'S I have been using a worthless in my configuration?
access-list 101 remark *******************************
access-list 101 remark --- SOME SERVICE ---
access-list 101 permit tcp any any eq 31000 log
access-list 101 permit udp any any eq 32000 log
the ACL you sharing is no need, the port is open by default since you dont config any other ACL.
so you dont need it.
why you think that you need it ?
below lines work as exected for port-forward external to internal (taking grant router not running any service on 30090 and 300443 port)
access-list 101  - is this ACL you match to NAT going out ?
then I would deny the host NAT traffic.
access-list 101 deny TCP x.x.x.x eq 80 any
access-list 101 deny TCP x.x.x.x eq 443 any
I also take into account that you do not have any ACL configured on gig 0/0 coming in traffic.
BB
here is g0/0
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source list 1 interface GigabitEthernet0/0 overload <<- this the answer why you need ACL for port fowrding
also thhis
access-list 101 permit udp any any eq bootps log
access-list 101 permit udp any any eq bootpc log
replace my example 101 with 1 - that should work as expected.
access-list 1 deny TCP x.x.x.x eq 80 any
access-list 1 deny TCP x.x.x.x eq 443 any
still an issue, post complete show run (removing passwords and any confidential information - not need to remove RFC 1918 address)
BB
the above nat must be
ip nat inside source list 101 interface GigabitEthernet0/0 overload  <<- if you use ACL 101 in other place please make it 110
ip access-list extended 101
permit ip any any <<- instead of source any you can specify your local LAN
Like----perrmit ip any MY LAN
no
permit ip <your LAN need to NAT> any
also can I ask, are you apply access-group 101 in WAN interface ? if YES then you also need
in simple words:- you need DENY for ACL for NAT and need PERMIT for ACL apply to interface.
