08-01-2014 09:36 AM
I am running ACS 5.2. I need to reboot the server through the GUI. I can't find a place anywhere in the GUI to reboot. Can someone please lead me to where I can reboot?
Solved! Go to Solution.
08-01-2014 10:17 AM
AFAIK, Unfortunately , there is no way you can reload the ACS server via GUI , it has to be done via CLI only with reload command.
Thanks-
Afroz
***Ratings Encourages Contributors ***
08-01-2014 10:16 AM
I just found this:
This section explains why you cannot restart the ACS server version 5.x from the GUI.
There is no option available to restart the ACS 5.x server from the GUI. The ACS can only be restarted from the CLI.
I guess I cant do it from GUI. When I try to sign into SSH session I get access denied. My account is a SuperAdmin. What do I need to do to ssh into it?
08-01-2014 10:17 AM
Thanks-
Afroz
