Active power source set to PS for Unit 1
chriscorkery
I'm getting the below messages constantly, whether i have any devices patched to the switch or not. I did not configure the switch, but I wanted to try to troubleshoot this before i resorted to factory resetting it.
Any help is appreciated, as im finding it difficult to find the resolution. The switch is a SG350, v2.3.5.63.
20-Aug-2017 07:44:18 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:44:23 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:44:53 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
20-Aug-2017 07:44:53 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:45:03 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:45:13 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
20-Aug-2017 07:45:13 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:45:23 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:45:34 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
20-Aug-2017 07:45:34 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:45:44 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:45:49 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:45:54 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
20-Aug-2017 07:45:54 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:46:04 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:46:09 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
20-Aug-2017 07:46:09 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:46:14 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:46:19 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:46:29 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
20-Aug-2017 07:46:29 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
20-Aug-2017 07:46:35 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
marce1000
 - You may want to include switch model and software version.
M.
Thanks, i have updated
