Cisco 3640 Router running only over half-duplex and DHCP Client problem
Lucas Rene
Hi guys. I recently bought a 3640 and when configuring i realised i cant make fa3/0 to run over full duplex mode. Only Half-Duplex Option. Already tried full duplex mode in the interface and it doesn´t recognize the comand.n The interface is a 10/100 so i dont see why i cant do it.
And there is also a thing about dchp client on a interface, it just doesnt recognize the command... Is it about the 12.0 ios version? or is a hardware issue?.
Thanks for reading !!
CCENT
Hi Lucas
The ip address dhcp interface command was introducted in IOS version 12.1(2)T. The ip dhcp client command was introduced in 12.3(2)XF. You mention that you are running IOS 12.0 so the solution to this particular one is to upgrade your code.
https://www.cisco.com/c/en/us/td/docs/ios/12_2sb/12_2sba/feature/guide/sbhcpcf.pdf
Please rate if this helps.
5 Replies 5
luis_cordova
Try with this comands:
(config)#interface fastethernet3/0
(config-if)#speed 100
(config-if)#duplex full
balaji.bandi
can you post the interface config and capabilites
show run interface fas 0/3
show interface fas 0/3 capa
show your DHCP config or post full config.
BB
Hi Lucas
Regarding the duplex, please try an older ios command duplex-full or no half-duplex on the interface.
http://www.ciscopress.com/articles/article.asp?p=101658&seqNum=2
Hi Lucas
Lucas Rene
Guys, it was a layer 1 problem. Bad cable. And about the dhcp i believe i would upgrade soon. Thanks to all !!!
CCENT
