Active/Standby failover pair firmware upgrade
rutekp123
   There is offical document how to upgrade software on Cisco ASA in Active/Standby. But no document about firmware upgrade. Anyone try to upgrade in active/standby but firmware not software ? This command is ok ?
failover exec mate upgrade rommon disk0:/asa5500-firmware-1118.spa
But what about confirm to reload ?
balaji.bandi
I did some time back, if this is active / on standby
you can upgrade standby first, once reload check shows the module
then upgrade the Primary unit.
Note: last time I did use a console so I would prefer this.
BB
rutekp123
I want to do it remotly. But this command: failover exec mate upgrade rommon disk0:/asa5500-firmware-1118.spa
will ask about reload.
On other hand i dont know if I use command upgrade rommon disk0:/asa5500-firmware-1118.spa on standby unit directly this will do only on standby only or on both units ?
The following commands are replicated to the standby ASA:
  • All configuration commands except for mode, firewall , and failover lan unit
  • copy running-config startup-config
  • delete
  • mkdir
  • rename
  • rmdir
  • write memory
The following commands are not replicated to the standby ASA:
  • All forms of the copy command except for copy running-config startup-config
  • All forms of the write command except for write memory
  • debug
  • failover lan unit
  • firewall
  • show
  • terminal pager and pager
this form CLI Book 1: Cisco ASA Series General Operations CLI Configuration Guide, 9.6 - Failover for High Availability [Cisco ASA 5500-X Series Firewalls] - Cisco
NOTE:- please be sure before apply any command.
