07-15-2007 01:40 AM
After the upgrade to Campus Manager 4.0.9, all links are now shown as "not in netwerk" (red dotted line).
Tx.
07-15-2007 05:19 AM
What happens after running a full Campus Data Collection?
07-15-2007 05:25 AM
I think I already did this : I used the "Start Data Collection" link, selected "All Devices" and that job completed.
The devices are all in green, it's just the links that are all in alert.
07-15-2007 02:56 PM
If the links still show red, enable core, corex, and topo debugging under Campus Manager > Admin > Campus Data Collection > Debugging Options, then run a new Campus Data Collection, and reload the topology map. The ani.log should have some indication of why the links are showing not in network.
07-15-2007 09:22 PM
Tx for the help.
Underneath some of the errors we see repeating :
2007/07/16 07:04:45 EvalTask-background-39 ani ERROR StpSMFGetStpInstance: unable to get stp device information
2007/07/16 07:04:45 EvalTask-background-27 ani ERROR StpSMFGetStpInstance: unable to get stp device information
2007/07/16 07:04:45 EvalTask-background-22 ani ERROR StpSMFGetSpanTreeDeviceInfo: Unable to fetch spanning tree type info from device "blanked out on purpose" com.cisco.nm.lib.snmp.lib.SnmpValueException: Illegal Access. NoSuchInstance being accessed as Integer.
2007/07/16 07:04:45 EvalTask-background-34 ani WARNING VlanStpInstance: unable to find vlan instance for instance id1003
2007/07/16 07:05:57 Discovery ani TopoSMFGenerateElmiTopology: Skipping device "blanked out on purpose" because ELMI neighbors are not discovered
2007/07/16 07:05:57 Discovery ani TopoSMFGenerateCdpTopology: Skipping device "blanked out on purpose" because CDP cache is not discovered
Then all links are shown as "not in network"
07-15-2007 09:57 PM
Nothing here speaks to an exact cause. If you cannot share the entire log on the forum, open a TAC service request, and attach the log.
07-15-2007 11:39 PM
I have the same problem. Likewise after loose contact to a device( device red )and after the devive is back it will stay red. Perform data collection doesn?t help. Is it possible to deinstall the patch?
07-16-2007 05:36 AM
No, the 4.0.9 update cannot be uninstalled. The debugging I mentioned previously might help determine what the cause of this problem is.
07-18-2007 06:42 AM
I have the same problem also UT doesn't scan the network devices correctly anymore. Seems that the update to CM4.0.9 wasn't a good idea.
07-19-2007 07:54 PM
I have the same problem. And in addition to the above problems any new device added after upgrading to 4.0.9 is not being discovered in topology database , and is not being displayed in the Network Topology.
07-19-2007 09:25 PM
I guess there was a problem with the ANI database. Once I did a cleanup of the database by re-initializing the database (complete). The Discovery , Data collection ran completely and now every thing seems to work.
Note: Re-initializing the database will erase the database completely.
07-22-2007 02:48 AM
This solved my problem. Tx.
For those of you who need to look like me for the instruction : run perl reinitdb.pl in the campus/bin folder from the command line.
08-06-2007 02:32 PM
I am having this same issue after upgrading to Campus 4.0.9 - all limks show as red. I read the solution and have question regarding the caveat about the re-init of the ANI database saying it "erases" the database.... what is the effect of that? Is it just a matter of doing rediscovery/data collection or are there further issues associated with the re-init? In other words, what do I have to be cognizant of if I do this? I have heard of no other solution to this issue so any advice would be greatly appreciated.
08-06-2007 02:41 PM
When you reinitialize you Campus Manager database, you lose all topology and User Tracking data. This means that you will need to do a new Data Collection followed by a new User Tracking Acquisition once dmgtd restarts.
08-06-2007 08:00 PM
Ok - I tried this procedure and it worked like a charm! I did campus data collection after the re-init of ANI database and my topology maps are back to way they were before upgrade to CM 4.0.9
Appreciate the solution given from list members - I would never have come up with this on my own and it saved me alot of grief....
THANKS ALL!!
