Alarm snmp on the fan detected but not visible on my switch
mhassine
I have configure an alarm snmp for the fan status. I use the MIB "CISCO-ENVMON-MIB".
Here are the different state of a fan :
CiscoEnvMonState ::= TEXTUAL-CONVENTION
        STATUS  current
        DESCRIPTION
                "Represents the state of a device being monitored.
                 Valid values are:
                 normal(1):  the environment is good, such as low
                                    temperature.
                 warning(2): the environment is bad, such as temperature
                                    above normal operation range but not too
                                    high.
                 critical(3):   the environment is very bad, such as
                                    temperature much higher than normal
                                    operation limit.
                 shutdown(4): the environment is the worst, the system
                                    should be shutdown immediately.
                 notPresent(5): the environmental monitor is not present,
                                    such as temperature sensors do not exist.
                 notFunctioning(6): the environmental monitor does not
                                    function properly, such as a temperature
                                    sensor generates a abnormal data like
                                    1000 C.
My snmp tool return an alarm with the argument : notFunctioning (6) on a power supply's fan
When i connect on my switch, i check the fan status with the command show environment status, i can see the fan sensor is good. (my alarm is on the equipment with the red arrow)
Why have I an alarm snmp on this fan ?
Thanks for your answers.
P.S : Sorry for my english, It is maybe bad.
balaji.bandi
what device is this, post show version and show environment full.
BB
oh yes i forget to indicate my device. The device is WS-C4500X-16.
device#sh environment status
Executing the command on VSS member switch role = VSS Active, id = 1
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C4KX-750AC-R AC 750W good good n.a.
PS2 PWR-C4KX-750AC-R AC 750W good good n.a.
Power supplies needed by system : 1
Power supplies currently available : 2
Chassis Type : WS-C4500X-16
Power consumed by backplane : 0 Watts
Switch Bandwidth Utilization : 0%
Supervisor Led Color : Green
Module 1 Status Led Color : Green
Beacon Led Status : off
Fan trays needed by system : 4
Fan trays currently available : 5
Chassis fan tray direction : FrontToBack
Fantray 1 : dir : FrontToBack status : Good
Fantray 2 : dir : FrontToBack status : Good
Fantray 3 : dir : FrontToBack status : Good
Fantray 4 : dir : FrontToBack status : Good
Fantray 5 : dir : FrontToBack status : Good
Fantray removal timeout : 180
Power consumed by Fantray : 90 Watts
Executing the command on VSS member switch role = VSS Standby, id = 2
Power Fan Inline
Module 11 Status Led Color : Green
device#sh version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.07.00.E RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sun 07-Dec-14 22:13 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG11
device uptime is 6 years, 24 weeks, 1 day, 2 hours, 59 minutes
Uptime for this control processor is 6 years, 24 weeks, 1 day, 3 hours, 1 minute
System returned to ROM by reload
System restarted at 15:13:08 CEST Wed Aug 26 2015
System image file is "bootflash:cat4500e-universalk9.SPA.03.07.00.E.152-3.E.bin"
Jawa Revision 2, Winter Revision 0x0.0x41
Last reload reason: reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-C4500X-16'
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C4500X-16 (MPC8572) processor (revision 9) with 4194304K bytes of physical memory.
Processor board ID JAE1915053P
MPC8572 CPU at 1.5GHz, Cisco Catalyst 4500X
Last reset from Reload
2 Virtual Ethernet interfaces
32 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x102
