Alerting on stack switches
Jamie Hancock
Level 3
Level 3
On a few occasions we have experienced issues with a stack switch where it has failed. The problem is Cisco Prime 2.2 does not notify us because the stack IP address it still contactable.
The stack does produce a syslog but it is only an informational notification.
Does anyone know of a way we can programme Prime to alert us when we lose a stack switch?
Jamie.
5 Replies 5
Jamie Hancock
Level 3
Level 3
Anyone??
Bumping this in case anyone can help.
Hi Jamie
Don't know if this works in PI 2.2 and haven't tried it myself.
In PI 3.0 you can change the severity of alarms under Administration->Settings->System settings->Alarm and Events->Alarm and events
There should be a simular way in PI 2.2
Hello Jamie,
To piggy back off of johanfogel, try following the Cisco Prime Infrastructure 2.2 Administrator Guide chapter 6 that goes over how to change the alarm severities. Follow this link to get to the digital pdf:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-2/administrator/guide/PIAdminBook.pdf
 -Charlie
Thanks for messages. Unfortunatly there is nothing in that section that would enable me to receive alerts should a mid stack switch die.
J,
