ANIServer Failed to run
Ram Kumar
Hello
I am unable to start the ANIServer process which has been working fine until Nov 2010. Below are the details for all the parts of LMS3.1
NameVersionLicense StatusSize
CiscoWorks Common Services3.2.0LicensedNot applicable
Campus Manager5.1.4Purchased1500
CiscoView6.1.8LicensedNot applicable
CiscoWorks Assistant1.1.0LicensedNot applicable
Device Fault Manager3.1.3Purchased1500
Internetwork Performance Monitor4.1.0Purchased1500
Integration Utility1.8.0LicensedNot applicable
LMS Portal1.1.0LicensedNot applicable
Resource Manager Essentials4.2.0Purchased1500
Health and Utilization Monitor1.1.0Purchased300
I have done lot of hanges as per the cisco blogs but still  not wroking .
I have done below changes but no luck
CSCsb52873
#ANI Server fails to start
#This problem occurs when you:
#Start ANI Server, the server is up for sometime and shuts down with RC as -2 and Info as ANI Server failed to load from the database.
#Workaround:
#Stop the Daemon Manager. Re-initialize ANI database and start the daemons.
#Enter the following command to reinitialize ANI database:
#/opt/CSCOpx/bin/perl /opt/CSCOpx/bin/dbRestoreOrig.pl dsn=ani dmprefix=ANI
You should not be using this interface to start any CiscoWorks services.  Your statup parameters look okay.  Either your ANI database is corrupt, or your transaction log is corrupt.
First, set the CiscoWorks Daemon Manager service to Manual, and reboot the server.  When the server reboots, delete NMSROOT\databases\ani\ani.log if it exists.  Then run:
NMSROOT\objects\db\win32\dbsrv9 -f NMSROOT\databases\ani\ani.db
After that, set the Daemon Manager service back to Automatic, and reboot again.  See if the ANI database engine starts.  If not, you will need to reinitialize your ANI database with the command:
NMSROOT\bin\perl NMSROOT\bin\dbRestoreOrig.pl dsn=ani dmprefix=ANI
We have done reinitializing:
1. Delete NMSROOT\databases\ani\ani.log
NMSROOT\objects\db\win32\dbsrv10 -f NMSROOT\databases\ani\ani.d
Here is the output of the pdshow ANIServer command:
Process= ANIServer
State  = Failed to run
Pid    = 0
RC     = -2
Signo  = 1073741822
Start  = N/A
Stop   = 5/12/2011 1:08:00 PM
Core   = Not applicable
Info   = Application failed or was registered incorrectly.
Pls find the atatched ANIServer.properties and ani.log file
Can somebody help me please?
Thanks in advance,
Ram
Joe Clarke
Your NMSROOT/campus/etc/cwsi/ANIServer.properties file is corrupt.  Post this file.
Joe Clarke
Thanks for your help.
Yes thats correct . ANIServer.properties was corrupted . I replaced file now with below setting  and this is working now.
1) AniName=ANIServer6.0- gbise0basnie12
2) DEVICESROOT=D:\\PROGRA~1\\CSCOpx\\campus\\lib\\classpath
3) DEVICESPACKAGE=com.cisco.nm.ani.server.devices
4) LogMsg.logfile=D:/PROGRA~1/CSCOpx/log\\ani.log
Ram
Hello
I did all what you mentioned but the ANIServer is still not working
Process= ANIServer
Pid    = 0
RC     = -2
Signo  = 1073741822
Start  = N/A
Stop   = 3/8/2011 1:12:00 PM
How can I solve this issue ?
Please start a new thread for your issue.
