Ansible Playbook out with many !
Steven Williams
Level 4
Level 4
I am running an ansible playbook to pull running configs of my switches. I do get this to work but my output has many lines of ! that I want to eliminate.
Does ios_command have something build into for this filtering? I have written this yml but doesn't seem to work.
- name: show version and other user level commands
  hosts: IOL_Routers
  gather_facts: false
  connection: network_cli
  become: yes
  tasks:
    - name: run multiple commands on remote nodes
      ios_command:
        commands:
          - show run
      register: print_output
- name: result of running commands above
    - debug:
        msg: "{{ print_output.stdout_lines | reject('equalto', '!') | list }}"
ansible-playbook showrunrv1.yml -u cisco -k
SSH password:
PLAY [show version and other user level commands] ************************************************************************************************************************************************************************************
TASK [run multiple commands on remote nodes] *****************************************************************************************************************************************************************************************
ok: [R03]
ok: [R02]
ok: [R01]
ok: [R04]
TASK [result of running commands above] **********************************************************************************************************************************************************************************************
ok: [R02] => {
    "msg": [
            "Building configuration...",
            "Current configuration : 1075 bytes",
            "! Last configuration change at 18:03:17 EET Thu Aug 22 2019 by cisco",
            "version 15.4",
            "service timestamps debug datetime msec",
            "service timestamps log datetime msec",
            "no service password-encryption",
            "hostname R02",
            "boot-start-marker",
            "boot-end-marker",
            "aqm-register-fnf",
            "no aaa new-model",
            "clock timezone EET 2 0",
            "mmi polling-interval 60",
            "no mmi auto-configure",
            "no mmi pvc",
            "mmi snmp-timeout 180",
            "ip domain name lab.net",
            "ip cef",
            "no ipv6 cef",
            "multilink bundle-name authenticated",
            "username cisco privilege 15 password 0 cisco",
            "redundancy",
            "interface Ethernet0/0",
            " ip address 10.20.250.101 255.255.255.0",
            "interface Ethernet0/1",
            " no ip address",
            " shutdown",
            "interface Ethernet0/2",
            " no ip address",
            " shutdown",
            "interface Ethernet0/3",
            " no ip address",
            " shutdown",
            "ip forward-protocol nd",
            "no ip http server",
            "no ip http secure-server",
            "ip route 0.0.0.0 0.0.0.0 10.20.250.1",
            "snmp-server location EveLab",
            "control-plane",
            "line con 0",
            " logging synchronous",
            "line aux 0",
            "line vty 0 4",
            " login local",
            " transport input ssh",
            "end"
Ben Walters
Level 4
Level 4
If you don't want any "!" in the output use show run | exclude ! it should only provide the running-config without all of the ! padding.
Ben Walters
Level 4
Level 4
Well that was much easier than creating a filter on the output.
Thanks.
