07-10-2020 11:38 AM
im new and i hope im in the right forum with my problem, if not i apollogize.
i got my hands on an ASA 5505 and still im learning and since this is a privat network and not a production environment security is not that mandatory.
What i want to do is monitoring the ASA with Zabbix.
What i got so far is
fritzbox (192.168.178.1) <-> eth0/0 (192.168.178.254) ASA 5505 eth0/1 (10.0.0.1) <-> Server (10.0.0.2) / PC (10.0.0.3)
where 192.168.178.0/24 is ouside security level 0 and 10.0.0.0/24 inside security level 100
Everything works fine and i can do an snmpwalk from my homeserver without any problems
since my homeserver is not running 24/7 i tried to monitor the asa from my vServer outside which is in a datacenter with a public ip
And here my problems start
I have set
snmp-server host outside [zabbix server ip] community [password]
I also added a roule that allowed snmp and snmptrap from outside to inside
but i dont get any responds when i try an snmpwalk from the server in the datacenter.
i dont even see the snmp request in wireshark forwarded to the asa.
If i forward port 161/162 to my pc i dont get a response either but i see the request in wireshark.
So ill guess, even i forward the ports to the asa. So ill guess the asa dont accept the snmp requests and the request is not forwarded at all.
Im teaching myself, experiment and read a lot but after a few days of experimenting without success i guess i need some help so any advice would be appreciated.
Solved! Go to Solution.
07-11-2020 02:21 AM
when i add a forward rule for port 161 and 162 to my PC i can see the snmp pulling request comming in on wireshark.
in the above case can you please clarify where is this PC connected?
also, post-ASA configuration,
also, capture the information outside interface, do you see them? (if not you need to re-visit fritzbox and check again, where it routing to) ?
07-11-2020 05:09 AM
07-10-2020 06:41 PM
you need to look fritz box here and see is there anything dropping there?
07-11-2020 12:34 AM
Thanks for the reply
but when i forward the ports to the outside interface ip of the asa i dont see the snmp request.
It looks like the fritzbox dont notice the asa is connected, what i think is very strange cause i can conect from inside to outside without any problems.Ill guess it might be a firewall problem of the asa?
07-11-2020 02:21 AM
07-11-2020 04:36 AM - edited 07-11-2020 04:59 AM
"in the above case can you please clarify where is this PC connected?"
PC was directly connected to fritzbox and 161-162 have been forwarded to the IP of PC.
I saw the snmp request in wireshark
I have changed the port forwarding to the ip of the ASA and i cant see the snmp request in wireshark
I let the fritzbox monitior traffic and i see fritzbox is forwarding the snmp request to the asa see below:
source destination protocol length info 62.141.x.x 192.168.178.254 snmp 69 get-next-request 1.3.6.1.2.1
192.168.178.254 is the ip of vlan 2 "outside" of the asa which it got from fritzbox dhcp server.
I cant see the snmp request when monitoring the outside interface of the asa.
Wireshark on my PC with ip 192.168.178.20 connected to the fritzbox didnt monitor the event
Asa Config
ciscoasa(config)# sh run : Saved : : Serial Number: ************ : Hardware: ASA5505, 512 MB RAM, CPU Geode 500 MHz : ASA Version 9.2(4)8 ! hostname ciscoasa enable password ************ encrypted names ! interface Ethernet0/0 switchport access vlan 2 ! interface Ethernet0/1 switchport access vlan 2 ! interface Ethernet0/2 ! interface Ethernet0/3 ! interface Ethernet0/4 ! interface Ethernet0/5 ! interface Ethernet0/6 ! interface Ethernet0/7 ! interface Vlan1 nameif inside security-level 100 ip address 10.0.0.1 255.255.255.0 ! interface Vlan2 nameif outside security-level 0 ip address dhcp setroute ! ftp mode passive object network obj_any subnet 0.0.0.0 0.0.0.0 object-group protocol DM_INLINE_PROTOCOL_1 protocol-object icmp protocol-object icmp6 access-list outside_access_in remark icmp packets access-list outside_access_in extended permit object-group DM_INLINE_PROTOCOL_1 any any pager lines 24 logging enable logging history debugging logging asdm informational mtu inside 1500 mtu outside 1500 icmp unreachable rate-limit 1 burst-size 1 icmp permit any inside icmp permit any outside no asdm history enable arp timeout 14400 no arp permit-nonconnected ! object network obj_any nat (inside,outside) dynamic interface access-group outside_access_in in interface outside timeout xlate 3:00:00 timeout pat-xlate 0:00:30 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00 timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00 timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute timeout tcp-proxy-reassembly 0:01:00 timeout floating-conn 0:00:00 dynamic-access-policy-record DfltAccessPolicy user-identity default-domain LOCAL http server enable http 10.0.0.0 255.255.255.0 inside snmp-server group admin v3 auth snmp-server host outside 192.168.178.1 poll community ***** snmp-server location DE snmp-server contact admin@********* snmp-server community ***** snmp-server enable traps syslog snmp-server enable traps ipsec start stop snmp-server enable traps entity config-change fru-insert fru-remove snmp-server enable traps interface-threshold snmp-server enable traps remote-access session-threshold-exceeded snmp-server enable traps connection-limit-reached snmp-server enable traps cpu threshold rising snmp-server enable traps ikev2 start stop snmp-server enable traps nat packet-discard crypto ipsec security-association pmtu-aging infinite crypto ca trustpool policy telnet timeout 5 no ssh stricthostkeycheck ssh timeout 5 ssh key-exchange group dh-group1-sha1 console timeout 0 dhcpd auto_config outside ! dhcpd address 10.0.0.2-10.0.0.25 inside dhcpd enable inside ! threat-detection basic-threat threat-detection statistics host threat-detection statistics port threat-detection statistics protocol threat-detection statistics access-list no threat-detection statistics tcp-intercept ! class-map inspection_default match default-inspection-traffic ! ! policy-map type inspect dns preset_dns_map parameters message-length maximum client auto message-length maximum 512 policy-map global_policy class inspection_default inspect dns preset_dns_map inspect ftp inspect h323 h225 inspect h323 ras inspect rsh inspect rtsp inspect esmtp inspect sqlnet inspect skinny inspect sunrpc inspect xdmcp inspect sip inspect netbios inspect tftp inspect ip-options ! service-policy global_policy global prompt hostname context no call-home reporting anonymous Cryptochecksum:************************************ : end ciscoasa(config)#
Thanks for trying to help me
07-11-2020 05:09 AM
07-11-2020 01:13 PM
Glad all sorted at the end, sometimes we need to look closely when the situation not going as expected and you think everything done, good we re-visit and step by step.
Thanks for the feedback.
