ASA 5506-X FTD DHCP Relay
Just upgraded my asa 5506-x to FTD and can not find how to configure a DHCP Relay on FTD GUI. I have a DHCP server running on my Windows Server 2012 connected to ASA Firewall Ethernet 1/3 and Ethernet 1/2 is connected to a Cisco SG-250 switch, wich are configured with VLAN 10, 20. I need to make two DHCP pools in my server and let computers from inside network get the addresses. Can anyone help me?
Giuseppe Larosa
Hello Jan,
I have looked at the configuration guide for FTD.
I can find a section about how to set a DHCP server with multiple pools, but no info about DHCP relay feature.
https://www.cisco.com/c/en/us/td/docs/security/firepower/610/fdm/fptd-fdm-config-guide-610/fptd-fdm-system.html#id_11195
System Server > DHCP settings
And it reports the following sentence:
>> DHCP clients must be on the same network as the interface on which the server is enabled. That is, there cannot be an intervening router between the server and client, although there can be a switch.
Depending on your network scenario you would consider if moving the DHCP server function to the ASA FTD.
I am trying to search in the pdf version of the configuration  guide
Edit:
I couldn't find any occurrence of DHCP relay in the pdf document. I am surprised.
Hope to help
Giuseppe
balaji.bandi
I have used some time back in my Lab, hope this information help you.
https://www.cisco.com/c/en/us/support/docs/security/firepower-ngfw/200475-Configure-DHCP-Server-Relay-on-FTD-Using.html
BB
Hello BB,
thanks for your useful info.
Best Regards
Giuseppe
