Netflow
robin.disla
Frequent Visitor
Frequent Visitor
I need help with the following error I'm configuring netflow in my network and when I assigned the configuration in the interface it shows me the following % Flow Monitor: Failed to add monitor to interface: internal error: field information missing
Mark Elsen
 - Post the configuration commands which you tried for Netflow on the particular interface. Also include switch model and software version.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
I have the next information.
1. what is the device model
Cisco Catalyst 9500-40X
2. IOS/NXOS code version
ios-xe version 16.09.02
3. your netflow configuration.
flow record HIT-NET-IN
match flow direct
match ipv4 tos
match transport destination-port
match transport source-port
collect counter bytes long
collect counter packets long
collect interface output
collect application dns domain-name
flow record HIT-NET-OUT
match flow direction
match interface output
match ipv4 destination address
match ipv4 protocol
match ipv4 source address
match ipv4 tos
collect interface input
flow exporter HIT-NET
source vlan X
destination X.X.X.X
transport udp 2055
export-protocol netflow-v9
flow monitor Netflow-Monitor-In
exporter HIT-NET
cache timeout inactive 10
cache timeout active 60
record HIT-NET-IN
flow monitor Netflow-Monitor-Out
exporter HIT-NET
record HIT-NET-OUT
The error  is in this part.
interface ten1/0/5
ip flow monitor Netflow-Monitor-In input
ip flow monitor Netflow-Monitor-Out output
Hello Robin,
have you enabled IPv4 routing on yur device?
according to configuration guide
IPv4 Traffic
  • The networking device must be configured for IPv4 routing.
  • One of the following must be enabled on your device and on any interfaces on which you want to enable Flexible NetFlow: Cisco Express Forwarding or distributed Cisco Express Forwarding.
see
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/software/release/16-6/configuration_guide/nmgmt/b_166_nmgmt_9400_cg/b_166_nmgmt_9400_cg_chapter_0111.html#reference_FB2AAC4511A140CEBC384F64F86F4DCC
There is also a list of Restrictions for Flexible netflow.
It is only the ingress netflow command rejected or both ?
If only the ingress direction fails Something in the flow record definition is missing.
Hope to help
Giuseppe
Duplicate post
BB
