09-14-2021 09:31 AM
Hello Everyone...
I have a remote region with (2) ASA 5545X in an Active / Failover configuration.
I am able to successfully transfer IOS 9.14.2.15 to the Active ASA using the file transfer utility in ASDM. I am trying to get the IOS to the Failover ASA with the following command, but it tells me that the "destination path is identical":
Here is what I am using:
failover exec mate copy /noconfirm disk0:/Filename disk0:/Filename.
I am trying to copy the IOS from the Active to the Failover. How can I do this without failing over the ASA? I do not have a TFTP server available...
Thoughts ?
09-14-2021 09:51 AM - edited 09-14-2021 12:34 PM
failover exec mate copy /noconfirm disk0:/xxxxx.bin disk0:
I use a console cable for each device
failover exec mate copy /noconfirm tftp://ipaddress/asaimage.bin disk0:/asaimage.bin
Apologies it was a typo, i read your question again, if you like to avoide using TFTP, then best option is USB.
09-14-2021 09:58 AM
I get a : (destination path is identical)...
