11-24-2020 06:23 AM
Dear Team,
Please my ASR1002 is not loading completely. when accessed via console, the below error message is displaced and i cannot enter rommon mode neither can i do any other thing else from console
System Bootstrap, Version 12.2(33r)XNC, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc
will appreciate any assistance on this.
11-24-2020 07:59 AM
- I can not see any error being displayed (yet....)
M.
11-24-2020 10:39 PM
@Mark Elsen . thanks for your response.
The router got stuck during boot process and showing below message via console. basically, it got stuck showing the below message
11-24-2020 11:17 PM
i mean the router got stuck showing this message; System Bootstrap, Version 12.2(33r)XNC, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport Copyright (c) 2009 by cisco Systems, Inc.
I am logging through console but it won't let me allow to get a prompt. i have reboot it 2 times but it stops responding at System Bootstrap, Version 12.2(33r)XNC, RELEASE SOFTWARE (fc1)
11-24-2020 11:35 PM
- This looks like a basic and or possibly a hardware problem. Have a cold power cycle of the device. Keep the console connected. Look for error messages during power up, if any.
M.
11-24-2020 11:42 PM
@Mark Elsen no Error message when power cycle, the device will load and stopped at same message;
11-25-2020 12:32 AM
- Seems like factory defaults reset remains an only possible left over option , a procedure can be found in the link below. However if that does not work neither , the device is corrupt and probably needs to be replaced (RMA). Discuss the situation further with Cisco TAC.
M.
11-25-2020 12:56 AM
(forgot to mention) -> Also check if there any led status indicators , pointing to severe problems.
M.
11-25-2020 01:03 AM
the critical led light is on
11-25-2020 02:24 AM
- Seems quite indicative of a serious problem -> RMA
M.
