Assistance with QOS on Router
omegaxero
policy-map wan-edge
class priority-class
bandwidth percent 75
class gold-class
bandwidth percent 10
class silver-class
bandwidth percent 5
class class-default
policy-map wan-edge
class gold-class
random-detect dscp-based
class silver-class
bandwidth percent 5
class class-default
fair-queue
random-detect dscp 0 10 15 2
ip access-list extended gold-data
remark *** ssh and terminal services traffic ***
permit tcp any any eq 22
permit tcp any any eq 3389
remark *** generic telnet traffic ***
permit tcp any any eq telnet
ip access-list extended priority-data
permit tcp any host 192.168.1.30 eq 5432
permit tcp any host 192.168.1.9
permit icmp any any
ip access-list extended silver-data
remark *** http traffic ***
permit tcp any any eq www
getting an error when i try to apply to an interface:
I/f FastEthernet0/0 class gold-class requested bandwidth 10%, available only 0%
i'm not sure what i am doing wrong if you could please take a look that would be very helpful
network.king
Level 4
Level 4
By default ,router will allow only 75% of the bandwidth to be used for all the classes configured . 25% would be taken for default class where other traffic that doesnt match the traffic in other classes defined and other headers used by router itself.
So since you have defined 75% for the first class , so available is now 0% thats the error .If you want to override the behaviour
then "max-reserved-bandwidth 90 " as per ur config . But take care that only 10% is allowed for your other traffic.
ref : http://www.cisco.com/en/US/tech/tk39/tk48/technologies_tech_note09186a00800fe2c1.shtml#understand
Pls rate all posts
regards
vanesh k
omegaxero
Thank you, I'd forgotten about that. works fine now.
