Authenticating LMS 4.x Users via TACACS+ on ACS 5.3.0
BARRY WILLIS
                   Does anyone have any notes/tips on how to Configure ACS 5.x so LMS 4 users can authenticate via TACACS+?  I have ACS 5.x setup and authenticating to Active Directory.  Have changed the LMS 4.x Authentication Module to TACACS+.  Have gotten past the user / password problem by configuring a local user in LMS 4.x.  Now, am hitting the Default rule in ACS and Shell Profile is deny access.  Doesn't look like I'm hitting my LMS 4.x Profile.
ngoldwat
Level 4
Level 4
ACS can be used for authentication to LMS however authorization is role-based for the users/groups on LMS4.x.  This is a departure from the classic LMS/ACS integration you saw in the past.
For more information check this post.
