Authentication failure for SNMP req from host
Mark Bracking
Level 3
Level 3
I geeting the following error message "1d10h: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host x.x.x.x"
can someone please tell me what I don;t have configured correct.
Building configuration...
Current configuration : 1192 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname 3640_2_2
ip subnet-zero
fax interface-type fax-mail
mta receive maximum-recipients 0
interface Ethernet0/0
ip address x.x.x.x 255.255.255.0
half-duplex
interface Ethernet0/1
no ip address
shutdown
half-duplex
interface Serial1/0
no ip address
shutdown
serial restart_delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
ip classless
ip http server
ip pim bidir-enable
access-list 1 permit x.x.x.x
snmp-server community your_community RW
call rsvp-sync
voice-port 3/0/0
voice-port 3/0/1
voice-port 3/1/0
voice-port 3/1/1
mgcp profile default
dial-peer cor custom
call-manager-fallback
transfer-pattern 52540
call-forward busy 50..
call-forward noan 5005 timeout 10
line con 0
logging synchronous
line aux 0
password tdd
logging synchronous
login
line vty 0 4
password todd
logging synchronous
login
End
thank you
Mark
Joe Clarke
This looks okay.  An authFail indicates that someone is polling this device with the wrong community string.  Check x.x.x.x to make sure there aren't any applications polling this device with wrong credentials.
Something else to note is that you should not be using '@' in your community strings.  While this shouldn't really matter for routers, it's a good rule of thumb not to use '@' on Cisco devices as that character is reserved for community string indexing.
Joe Clarke
I'm getting similar issue on my Nexus devices.
So there was a storage server that is polls the devices even without the SNMP configurations on the Nexus device with below errors,
 %SNMPD-3-ERROR: SNMP log error : snmp Auth fail:bad community name from host <x.x.x.x>
Tried to configure properly the SNMP on the box with the matching SNMP strings but still getting similar errors.
I have the below configurations:
ACL_TEST:
7 permit udp x.x.x.x/32 any eq snmp [match=0]
snmp-server host x.x.x.x traps version 2c <community_string>
snmp-server host x.x.x.x use-vrf default
snmp-server community <community_string> use-acl <ACL_TEST>
snmp-server community <community_string> group network-operator
Any thoughts is much appreciated!
