Automated Config Backups Using to SCP server from Management Interface
pat.mchenry
is it possible to automate configuration backups to an SCP server using the Archive command sourced from the Management VRF and Management interface?
Trying to accomplish this using an ASR, 4948, and ASA, and Nexus 5K.
So far I've been able to accomplish this using a managed IP (not a management interface or management VRF) from a variety of Cisco access layer switches, but not from the above devices using the Management interface in  a Management VRF.
Before digging further into configuring I would like to know if it is even supported?
Thank you, Pat
Mark Malone
these are the below mgmt supported protocols and it looks like scp is vrf aware too once the source is set but i havent tried this through archive before , im just seeing can i send it to my linux server with scp , ll our local switches are through mgmt ports and the mgmt traffic sourced to use it , whats happening when you try ?
Prerequisites for VRF-Aware SCP
Ensure that Secure Shell (SSH) connection is enabled.
Ensure that Virtual Routing and Forwarding (VRF) configuration is available on the device.
Information About VRF-Aware SCP
SCP and SSH
The secure copy protocol (SCP) feature allows a user with appropriate authorization to copy any file that exists in the Cisco IOS File System (IFS) to and from a device by using the copy command. Being Virtual Routing and Forwarding (VRF) aware, the SCP feature can provide the service only to a specific group or interface rather than providing global access and configuration. The VRF-aware SCP feature enables administrators to have more control and added security.
SCP relies on Secure Shell (SSH) for security and authentication.
Use the ip ssh source-interface command to source SSH traffic from any interface, including a VRF interface.
How to Configure VRF-Aware SCP
Configuring SCP to Use VRF-Aware Interface
Before You Begin
Configure Virtual Routing and Forwarding (VRF) aware interfaces.
SUMMARY STEPS
1. enable
2. configure terminal
3. ip ssh source-interface interface
4. exit
5. copy running-config scp://username@destination-host-address[/destination-directory][/destination-filename]
6. copy scp://username@source-host-address[/source-directory][/source-filename] bootflash:
7. exit
Supported Features on the Ethernet Management Port
The Ethernet management port supports these features:
  • Express Setup (only in switch stacks)
  • Network Assistant
  • Telnet with passwords
  • TFTP
  • Secure Shell (SSH)
  • DHCP-based autoconfiguration
  • SMNP (only the ENTITY-MIB and the IF-MIB)
  • IP ping
  • Interface features
    • Speed—10 Mb/s, 100 Mb/s, 1000 Mb/s, and autonegotiation
    • Duplex mode—Full, half, and autonegotiation
    • Loopback detection
  • Cisco Discovery Protocol (CDP)
  • DHCP relay agent
  • IPv4 and IPv6 access control lists (ACLs)
  • Routing protocols
Another option maybe is to use EEM with SCP and source the SSH traffic from the mgmt interface if the archive doesn't work out through the mgmt
example from one of Joes post just alter the tftp section
event manager applet backup-config
event timer watchdog time 86400
action 1.0 cli command "enable"
action 2.0 info type routername
action 3.0 cli command "copy runn tftp://x.x.x.x/$_info_routername.cfg" pattern "Address"
action 4.0 cli command "" pattern "Destination"
action 5.0 cli command ""
