automatic backup issue with kron
mod0108537733
Hi all,
Every month I have to issue these commands for backup at my network devices
#show run
#show version
# show diag
now I have around more than 200 network device form routers and switches so I go to automatic backup from cisco by using kron command
I use
# kron policy-list backup
#cli show run | redirect tftp://192.168.10.1/R1-run
#cli show ver | redirect tftp://192.168.10.1/R1-ver
#cli show diag | redirect tftp://192.168.10.1/R1-ver
but every command ''must'' have its own file for output ,can I find any solution to make all outputs of these three commands combined in one file automatically by the router
BR
Mahmoud
ghostinthenet
Level 7
Level 7
Well, there's a short answer and a long answer.
The short answer is to use "cli show tech-support | redirect tftp://192.168.10.1/R1-tech-support" instead. The output of this command includes all three of the items you're looking for and quite a bit more.
The long answer is to use an EEM script to combine things before sending.
event manager applet EEM_Status
 event timer cron cron-entry "* * 1 * *"
 action 1.0 cli command "enable"
 action 2.0 cli command "delete /force flash:/status"
 action 3.0 cli command "show running-config | redirect flash:/status"
 action 4.0 cli command "show version | append flash:/status"
 action 5.0 cli command "show diag | append flash:/status"
 action 6.0 cli command "copy flash:/status tftp://192.168.10.1/R1-status"
 action 6.0 exit
This script will combine all three commands into a file on the flash called "status" at midnight on the first of each month and then TFTP that file to your server.
Jody Lemoine, Network Architect
CCIE 41436, MTCRE, MTCINE, MTCIPv6E
tishco networks, Virtually Everywhere
(905) 378-1134, jody.lemoine@tishco.ca
ghostinthenet
Level 7
Level 7
 action 6.0 exit
Thanks Jody for your reply
can I customize the output of this command
#cli show tech-support
The "show tech-support" command doesn't have any options, so no. If you want granular control of the output, I would go with the EEM approach.
I made these commands and it worked great
event manager applet backup
 event timer cron cron-entry "45 13 19 10 *"
 action 6.0 cli command "copy flash:/status tftp:" pattern "Address or name of remote host.*"
 action 7.0 cli command "192.168.10.1" pattern "Destination filename.*"
 action 8.0 cli command "R1-status"
