automatic generating syslogs logs
mragula01
Visitor
hello all, i would like to ask you for advice. i would need to send from my devices each hour a syslog message (for example heartbeat_nameofdevice) each hour to Qradar. those devices are nexus 9K (9.3.9) and ASA firewall. i tried to configure it with event manager on nexus in this way
event manager applet heartbeat
action 1 syslog msg test_BEUWVVSSPRLESW009N93
but i am not able to set up timer in order to trigger this action each hour
thank you
Michal
14 Replies 14
Georg Pauwen
you can add a CRON timer (in the example below, the syslog message would be run one minute after each hour):
--> event timer cron cron-entry "01 * * * *" maxrun 99999999
unfortunately event timer is not a option which is enabled on my nexus devices
(config-applet)# event ?
cli  - Create a cli event specification
counter -  Create a counter event
fanabsent -  Create fanabsent event specification
fanbad - Create fanbad event specification
fib -  FIB related event
gold  - Create a 'Diagnostic' event specification
internal-link-flap -  Create a 'internal-link-flap' event specification
memory - Create memory thresholds event specification
module - Create a 'module' event specification
module-failure -  Create a 'module-failure' event specification
neighbor-discovery - Show CDP new neighbors
oir - Create Online-Insertion-Removal event specification
policy-default -  Use the event in the system policy being overridden
poweroverbudget - Create poweroverbudget event specification
snmp - Create a 'snmp' event specification.
storm-control -  Create a storm control event specification
syslog - Create a syslog event specification
sysmgr - System manager related events
tag - Event tag identifier
temperature - Create temperature event specification
test - Create a 'test' event specification
track - Create a 'track' event specification
is there some other option ?
check if you can use KRON instead:
event manager applet EVERYHOUR_APP
event none
kron policy-list EVERYHOUR_POL
cli event man run EVERYHOUR_APP
kron occurence EVERYHOUR_OCC in 60 recurring
hello Georg,
unfortunately even KRON is not enabled on our nexuses
 (config-applet)# kron ?
% Invalid command at '^' marker.
(config-applet)# exit
(config)# kron ?
maybe is there some other way how to automatically generate log on nexus and ASA each hour ?
for the Nexus, try the below:
feature scheduler
scheduler job name SYSLOG_JOB
scheduler schedule name SCHED_HOURLY
job name SYSLOG_JOB
time hourly 00
fmacias.duarte
Frequent Visitor
Frequent Visitor
Where you able to figure this out? I'm trying to do the same thing
each device have different configuration what device you looking to configure or what is the config not working ?
BB
fmacias.duarte
Frequent Visitor
Frequent Visitor
I'm trying to send a keepalive message every 10 min to sour syslog server in a Nexus 93180YC-FX3 switch. running NXOS version 10.4(5). I tried using scheduler, but the message is only being sent to the console:
scheduler job name KEEPALIVE_LOG
    send log 6 "Keepalive: Device is alive"
end-job
scheduler schedule name KEEPALIVE_LOG
   time start 2025:09:19:14:52 repeat 0:0:10
how about this :
event manager applet EEM_KEEPALIVE
event timer watchdog time 3600 (1hours you can change this)
action 1.0 syslog msg "EEM-KEEPALIVE: Nexus 9K alive"
BB
Thanks for your response. I had tried something similar that I found online, but the "event timer" command is not an option for event manager. I also tried this, but didn't work either:
event manager applet KEEPALIVE_LOG
    event syslog pattern ".*"
    action 1.0 syslog priority notifications msg Keepalive: Device is alive
This is what worked for me:
1. Created a python script to generate the log:
     1.1 open notepad++ and paste the following:
             #!/usr/bin/env python3
             import cli
             cli.cli('syslog priority notifications msg Keepalive: Device is alive')
      1.2 Save the file as keepalive.py and copy it to switch bootflash:
2. Create a scheduler job
3. Schedule to run the script every 5 min (you can adjust the time according to your needs)
Complete configuration :
scheduler job name python-keepalive
     python3 bootflash:/keepalive.py
end-job
scheduler schedule name keepalive
     time start now repeat 0:0:5
My next suggestion was that, since Nexus support Python, glad all good, thank you sharing the information with community.
even i did from syslog server same kind of script to check with nexus Managment IP, and report or generate syslog.
BB
