Bandwidth Distribution
cscisco_admin
Level 2
Level 2
Hi!
I have Cisco 837 ADSL Router and 1Mbps Internet. Is it possible to distribute bandwidth on its four ethernet ports? Secondly, is it possible to access its Web Interface in IE7 or IE8. I have tried a lot but it only works in IE6.
Apologize if this is not the correct forum to ask this kind of question.
Thanks!
Lucien Avramov
Level 11
Level 11
Are you using SDM? SDM only supports IE6.
If you use CCP, you can use IE7 as per the release notes:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_professional/v1_4/rlsnts/ccp_rel_notes.html
Regarding BW distribution, it is possible. I believe on the 837, there are 4 switchports and 1 ethernet port.
In that case you can assign the switchports to vlans and use class-maps, service policy and use the keyword bandwidth to configure the bandwidth you want to allocate.
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/12_4/qos_12_4_book.html
Example:
interface FastEthernet3
description ETC
switchport access vlan 3
no cdp enable
service-policy output ect_policy
policy-map ect_policy
class ect_class_voice
bandwidth 64
class class-default
bandwidth 128
class-map match-all ect_class_voice
match protocol h323
