Bandwidth Requirement for Video Streaming
Hi All, I have an Requirement to analyze the additional bandwidth required to access Video Streaming. There are set of learning module videos hosted in DC and users across location will be accessing the video stream. Is these a specific way to calculate this requirement? Video Length 30 Minutes at 720P and 480P. Kindly suggest if any.
5 Replies 5
balaji.bandi
there is good tool i have used before when we doing some demo.
hope this helps you.
https://www.israk.my/node/207
BB
Thanks Balaji for the quick response.
Is there a way to identify the Streaming Bit rate??
Can you elaborate more, not understand what you meant in the last message.
BB
To Calculate the bandwidth requirement, we would need to know the bit rate of the streaming Video.
do we have any specific way to identify the bit rate of the video? can we see that using wireshark captures?
here is standard good posted, this is for your reference :
https://support.google.com/youtube/answer/2853702?hl=en-GB
BB
