Bandwidth
mason.strad
Community Member
What switch can use the SRR- command to set the weight?
Georg Pauwen
you are looking for a comprehensive list of all switch models that support srr ? Not sure if that is out there. I know for a fact that 2950/2960/3750/3850 switches do support it.
balaji.bandi
Most of the switches support that feature, you can check with the feature navigator if your model of the device support that feature or not.
here are some command references if you looking to deploy QoS in your network.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960xr/software/15-2_2_e/qos/command_reference/b_qos_1522e_2960xr_cr/b_qos_152_ex1_2960-xr_cr_chapter_011.html
BB
