Baseline template - look for specific loopback interface when specifying "ip tftp source-interface"
jesper_petersen
Level 3
Level 3
Hello all
I'm new to regex and I'm trying to make a baseline template, that will check our network devices for our required basic configuration.
What I'm trying to do is to make a template that will look for either a loopback0 or loopback1 interface.
If eíther one is found (the loopback interfaces will not be there at the same time) it must apply the following command:
ip tftp source-interface loopback0 (or loopback1)
Is it even possible to make an if-then statement using regex?
Thank you in advance.
Best regards
Jesper Ross Petersen
Message was edited by: Jesper Ross Petersen
Dan Frey
Yes, this can be done
#Go to the tcl shell of the device.
C1811#tclsh
C1811(tcl)#
#copy and paste this at the tcl prompt.
proc intf {} {
set runningcfg [exec show run | inc ^interface Loopback]
foreach line [split $runningcfg \n] {
if {[regexp {interface (Loopback[0-1])} $line -> interface] } {
ios_config "ip tftp source-interface $interface"
return "ip tftp source-interface $interface"
# now type the name of the proc (intf) at the tcl prompt.
C1811(tcl)#intf
# If loopback0 or 1 is present the tftp source interface is added to the running config.
ip tftp source-interface Loopback0
C1811(tcl)#
Hello Dafrey
Thank you for your reply.
It seems that I haven't mentioned that this script is to be used with Cisco LMS, sorry about that.
Is it possible to do the script that you've provided in the Cisco LMS web gui?
I can see that the LMS server also has the tclsh (I've never even seen it or used it before ).
I hope you understand what I mean. Thank you and have a nice day!
Best regards
Jesper Ross
