basic WLC configuration (packet tracer)
Jorrie
Level 2
Level 2
Hi, I would like to ask can WLC be configured in a setup where the desktop and WLC are both connected to the switch. If yes, how? My problem is that I can't establish a connection between the WLC and the desktop even though they are on the same network ID.
Jorrie
it also works if you assign Vlan 20 as the native Vlan to the trunk:
interface GigabitEthernet1/0/3
switchport trunk native vlan 20
switchport mode trunk
The PC is connected to an access port (which equals an untagged Vlan), the WLC needs to be in the same, untagged Vlan (which the 'native' keyword is used for, it makes that Vlan untagged).
Hope that makes sense...
7 Replies 7
Georg Pauwen
post your zipped Packet Tracer project (.pkt) file...
Jorrie
Level 2
Level 2
Hi, here is my project.
seems to work only when the WLC is connected to an access port. Change:
switchport trunk allowed vlan 20-21
switchport nonegotiate
to
switchport mode access
switchport access vlan 20
Attached the revised file...
Jorrie
Level 2
Level 2
By changing it to access port only one VLAN can access the port. I'm trying to configure multiple VLANs in WLC.
regards,
Jorrie
Jorrie
Level 2
Level 2
I can now access the WLC by assigning it to the native VLAN and creating a network exclusive to the Native VLAN. Now I get two questions
how and why it works in Native VLAN?
Can I assign it again to another VLAN for remote management purposes?
Jorrie
Level 2
Level 2
Hi, I don't why I can't access the WLC after configuring the initial setup.
the image below is my initial configuration.
