Best QoS solution
3xIT
 Hi all,
We have internet line of 100 Mbs and couple networks. From the hardware side, there is ISP router, then our non-managed switch on which all other networks have been connected.
Now, I would like to make a new switch with QoS or some kind of bandwidth management and make limitations on some ports (ex. port 1 use 10 Mbps, port 2 use 50 Mbps, port 3 use 20 Mbps and port 4 use 20 Mbps).
What would you recommend for buying? Right now we have couple Cisco 2960, 2960-S and one Cisco 3750-X. Maybe we can use some of them for this?
Thanks in advance!
pieterh
none of these is realy a good idea for a new production configuration.
because end of cisco support is allread
