Buffer Failures
Thomas Grassi
Level 3
Level 3
I have a cisco 851
I monitor the cisco using opmanager
opmanger is reporting Buffer and Create Buffer Failures
I did a show buffers
MyRouter#show buffers
Buffer elements:
     1117 in free list (500 max allowed)
     9044926 hits, 0 misses, 1119 created
Public buffer pools:
Small buffers, 104 bytes (total 59, permanent 50, peak 150 @ 2w1d):
     32 in free list (20 min, 150 max allowed)
     15029144 hits, 330 misses, 461 trims, 470 created
     109 failures (0 no memory)
Middle buffers, 600 bytes (total 40, permanent 25, peak 108 @ 2w1d):
     17 in free list (10 min, 150 max allowed)
     1428730 hits, 770 misses, 2087 trims, 2102 created
     42 failures (0 no memory)
Big buffers, 1536 bytes (total 50, permanent 50, peak 62 @ 3d18h):
     50 in free list (5 min, 150 max allowed)
     7446506 hits, 50 misses, 12 trims, 12 created
     38 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 12 @ 3d18h):
     9 in free list (0 min, 100 max allowed)
     30 hits, 9 misses, 2 trims, 2 created
Large buffers, 5024 bytes (total 1, permanent 0, peak 3 @ 3d18h):
     1 in free list (0 min, 10 max allowed)
     3 hits, 6 misses, 35 trims, 36 created
     6 failures (0 no memory)
Huge buffers, 18024 bytes (total 1, permanent 0, peak 3 @ 3d18h):
     1 in free list (0 min, 4 max allowed)
     6 hits, 3 misses, 35 trims, 36 created
     3 failures (0 no memory)
Interface buffer pools:
MOTCR buffers, 1552 bytes (total 321, permanent 321):
     0 in free list (0 min, 321 max allowed)
     321 hits, 0 fallbacks
     321 max cache size, 321 in cache
     12021922 hits in cache, 0 misses in cache
Dot11Radio0Psp buffers, 1680 bytes (total 80, permanent 80):
     80 in free list (0 min, 80 max allowed)
     0 hits, 0 fallbacks
Dot11Radio0 buffers, 2400 bytes (total 96, permanent 96):
     32 in free list (0 min, 96 max allowed)
     804555 hits, 0 fallbacks
Header pools:
Header buffers, 0 bytes (total 137, permanent 128, peak 137 @ 3w5d):
     9 in free list (10 min, 512 max allowed)
     125 hits, 3 misses, 0 trims, 9 created
     0 failures (0 no memory)
     128 max cache size, 128 in cache
     505521 hits in cache, 0 misses in cache
Dot11Radio0 buffers, 0 bytes (total 300, permanent 300):
     150 in free list (0 min, 300 max allowed)
     150 hits, 0 misses
     150 max cache size, 150 in cache
     0 hits in cache, 0 misses in cache
Particle Clones:
     1024 clones, 505360 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 385, permanent 384):
     129 in free list (128 min, 1024 max allowed)
     3247 hits, 329 misses, 234 trims, 235 created
     256 max cache size, 256 in cache
     505360 hits in cache, 0 misses in cache
Normal buffers, 1536 bytes (total 512, permanent 512):
     384 in free list (128 min, 1024 max allowed)
     272 hits, 0 misses, 0 trims, 0 created
Private particle pools:
FastEthernet0 buffers, 1536 bytes (total 192, permanent 192):
     0 in free list (0 min, 192 max allowed)
     192 hits, 0 fallbacks
     192 max cache size, 128 in cache
     20078758 hits in cache, 0 misses in cache
FastEthernet4 buffers, 1536 bytes (total 192, permanent 192):
     18501051 hits in cache, 16 misses in cache
MyRouter#
Any ideas on what I might need to do?
Tom
Thomas R Grassi Jr
0 Replies 0
