bulk configuration of devices
justine.joubran
Is there a way to apply the same command (i.e. logging host <LMS_IP_address>) to a big number of devices?
If not in LMS, is there any other option?
Thank you,
Justine.
Marvin Rhoads
Sure, netconfig is designed for just this task. There's even a pre-defined template for the "logging host" setup.
Please refer to this section of the Configuration Management guide for complete instructions.
Marvin Rhoads
