C3560 and problem with routing
Hi Guys,
I have created a 3x VLANs on C3560. I have configured 'ip routing' and needed interfaces. I have access to the internet and I can try ping hosts in the other vlans, however I get response from them only if I add a route manually on each host - even on def. gateway.
Sample config here:
C3560#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/13, Fa0/23, Fa0/24, Gi0/1, Gi0/2
2    VLAN0002                         active    Fa0/2, Fa0/3, Fa0/4, Fa0/5, Fa0/6, Fa0/7, Fa0/8, Fa0/9, Fa0/10, Fa0/11, Fa0/12
3    VLAN0003                         active    Fa0/14, Fa0/15, Fa0/16, Fa0/17, Fa0/18, Fa0/19, Fa0/20, Fa0/21, Fa0/22
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
2    enet  100002     1500  -      -      -        -    -        0      0
3    enet  100003     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
C3560#
C3560#sh ip int b
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  192.168.2.1     YES NVRAM  up                    down
Vlan2                  10.1.2.1        YES NVRAM  up                    down
Vlan3                  10.1.3.1        YES NVRAM  up                    down
Vlan10                 10.1.10.1       YES NVRAM  down                  down
FastEthernet0/1        192.168.1.50    YES NVRAM  up                    up
FastEthernet0/2        unassigned      YES unset  down                  down
FastEthernet0/3        unassigned      YES unset  down                  down
FastEthernet0/4        unassigned      YES unset  down                  down
C3560#
C3560#sh route
C3560#sh run | in route
ip route 0.0.0.0 0.0.0.0 192.168.1.254
C3560#
Don't worry that those interfaces are DOWN as I have nothing connected while I'm writing this post.
Why I can't ping 192.168.1.254 which is my ASA5510 (gateway) unless I add route 192.168.1.0 255.255.255.0 192.168.1.50 (interface on a C3560) on that 5510?
I'm missing something simple, but can't figure out what it is...
Thanks in advance.
Slawek
I can't ping the above hosts each other. If you can help find out why is that all should start working I hope.
where is this host connected:  192.168.1.147/24, if the same switch what port?
sugestion for testing
default interface FastEthernet0/1
switchport access vlan 10 no shutdown
interface vlan 10
ip address 192.168.1.50 255.255.255.0
no shut
interface FastEthernet0/23
connect host to port 23 and test it
BB
14 Replies 14
post the full running configuration of your 3560 switch. Also:
--> however I get response from them only if I add a route manually on each host - even on def. gateway
does that mean it works only if you add something like 'route add' (on a Windows host) ?
balaji.bandi
Pinging from Switch you mean ?
if you add that route on ASA , are you able to Ping back and forth ?
By Default p2p IP should able to ping with out any Route adding,  since we do not ASA config we can not comment here.
BB
Thanks for your responses.
Let's try again from different angle to be sure that I have not mixed things up.
We are talking about 2x VLANs:
- 192.168.1.0/24
- 10.1.2.0/24
Switch is C3560 with L3 routing enabled:
- Native VLAN IP is: 192.168.1.50/24
- VLAN2 IP is: 10.1.2.1/24
FW is ASA5510 as a default gateway (192.168.1.254).
Hosts are:
Host1 - 192.168.1.147/24 - with def. GW set as 192.168.1.254 (ASA5510)
Host2 - 10.1.2.100/24 with def. GW set as 10.1.2.1 (VLAN2 IP in switch C3560)
Here's a config from the switch C3560 - I've removed password and usernames:
current configuration : 4796 bytes
! No configuration change since last restart
version 12.2
no service pad
service password-encryption
hostname C3560
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
password encryption aes
crypto pki trustpoint TP-self-signed-3587941504
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3587941504
 revocation-check none
 rsakeypair TP-self-signed-3587941504
spanning-tree mode pvst
vlan internal allocation policy ascending
 no switchport
 switchport access vlan 2
 switchport mode access
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
 switchport mode trunk
interface FastEthernet0/14
 switchport access vlan 3
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 ip address 192.168.2.1 255.255.255.0
interface Vlan2
 ip address 10.1.2.1 255.255.255.0
interface Vlan3
 ip address 10.1.3.1 255.255.255.0
interface Vlan1
interface Vlan2
interface Vlan3
interface Vlan10
 ip address 10.1.10.1 255.255.255.0
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
 password 7 01203C07411E160E22564B02495052
 login local
 transport input ssh
line vty 5 15
 password 7 1521310F1E3F3B252B293029435253
 login local
 transport input ssh
ntp clock-period 36029428
ntp server 192.168.1.100
end
and routing again from the switch:
C3560#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.1.254 to network 0.0.0.0
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.2.0 is directly connected, Vlan2
C    192.168.1.0/24 is directly connected, FastEthernet0/1
S*   0.0.0.0/0 [1/0] via 192.168.1.254
C3560#
So all networks should be routable....
and here is a config from ASA5510:
ASA5510# sh run | in route
 description PlusNet router
route outside 0.0.0.0 0.0.0.0 Gateway 1
route inside-NAT 10.1.2.0 255.255.255.0 192.168.1.50 1
route inside-NAT 192.168.2.0 255.255.255.0 192.168.1.50 1
ASA5510# sh ip address
System IP Addresses:
Interface                Name                   IP address      Subnet mask     Method
Ethernet0/0              outside                172.16.0.254    255.255.255.0   CONFIG
Ethernet0/1              inside-NAT             192.168.1.254   255.255.255.0   CONFIG
Ethernet0/2              DMZ                    unassigned      unassigned      DHCP
Ethernet0/3              Guest                  10.10.10.254    255.255.255.0   CONFIG
Management0/0            management             192.168.10.1    255.255.255.0   CONFIG
Current IP Addresses:
ASA5510#
I cannot put the whole config for obvious reasons. On ASA5510 there's no VLANs created.
Any idea what I have done incorrectly? The things is that all hosts can go to the internet but can't ping each other.
Many thanks.
this won't work:
--> Host1 - 192.168.1.147/24 - with def. GW set as 192.168.1.254 (ASA5510)
The default gateway for the hosts need to be a Vlan interface in the 192.168.1.0/24 range. What Vlan are your hosts supposed to be in ?
HOST1 (192.168.1.147/24) is in the same VLAN as its def. gateway which is 192.168.1.254 (ASA5510).
I even tried to change def GW to 192.168.1.50, but it doesn't work either.
Which Vlan is the host in ? You need to use the IP address of a Vlan interface as the default gateway.
I did - see below please:
Host1 - 192.168.1.147/24 - with def. GW set as 192.168.1.254 (ASA5510) --- for this one I have tried to change def. GW to 192.168.1.50 which the IP address of the switch, but it lost access to the internet immediately and I couldn't ping HOST2 nor 8.8.8.8.
I can ping any host I want directly from the switch. It must single thing.....
Which port on the switch is the host with IP address 192.168.1.147/24 connected to ?
You need a Vlan interface with an IP address in the 192.168.1.0/24 subnet. That IP address must be the gateway for your host. You cannot use the IP address of FastEthernet0/1.
interface vlan 10
no shut
BB
Thanks Both!
I live in UK and it’s late here. I’ll check it tomorrow morning first thing.
I think you may be right with that VLAN for 192.168.1.0 network. Will L3 switching still work?
Amazing! That was it! I totally didn't think that not having any VLAN in 192.168.1.0/24 and no ports added to that VLAN, can cause this problem.
I've learned something today
Many thanks Guys for your help. I appreciate it as you have read a random help request and you have sacrificed your time to help a stranger
nice to know all works as suggested...this is best part of community sharing the knowledge....i live in brit too..
BB
One more question. How about L3 switching? Since I have re-configured F0/1 into switchport mode, it is not anymore L3 port as per this document from Cisco:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/software/release/12-2_52_se/configuration/guide/3560scg/swint.html#wpxref48776
What it is then? L2 I think. How switch then works on L3?
Port is Layer 2, But VLAN SVI Layer 3 and it has routing enable
show ip route show you if no routing enabled as below :
show ip route
Default gateway is not set
same document give you information as below :
Configuring Layer 3 Interfaces
The switch supports these types of Layer 3 interfaces:
SVIs: You should configure SVIs for any VLANs for which you want to route traffic. SVIs are created when you enter a VLAN ID following the interface vlan global configuration command. To delete an SVI, use the no interface vlan global configuration command. You cannot delete interface VLAN 1.
BB
