C3650 update problem. Flash free space issue.
EvgeniyE
Hello!
I'm try to update WS-C3650-24TS (stack with 2 switches) from 03.07.04E to Denali 16.3.8
That's what i did:
1.Download Denali 16.3.8 from cisco.com
2. Execute software clean command on the stack and delete all unnecessary files.
3. Copy new ios to flash of stack master
4. Execute command software expand file <new ios>
Flash-2
Result: SW01#software expand file flash:cat3k_caa-universalk9ldpe.16.03.08.SPA.bin to flash-2:
Preparing expand operation ...
[2]: Expanding bundle flash:cat3k_caa-universalk9ldpe.16.03.08.SPA.bin
[2]: % flash: requires 522878 KB of free space, but only 256700 KB is available.Operation aborted.
To flash-1 Result:
SW01#software expand file flash:cat3k_caa-universalk9ldpe.16.03.08.SPA.bin to flash-1:
[2]: Copying software from active switch 2 to switch 1
[2]:Finished copying software to switch 1
[1]: Expanding bundle flash:cat3k_caa-universalk9ldpe.16.03.08.SPA.bin
[1]: Copying package files
[1]: A different version of provisioning file packages.conf already exists in /var/sysmgr/work/flash-1:. The provisioning file from the expanded bundle will be saved as /var/sysmgr/work/flash-1:cat3k_caa-universalk9ldpe.16.03.08.SPA.conf
[1]: Package files copied
[1]: Finished expanding bundle flash:cat3k_caa-universalk9ldpe.16.03.08.SPA.bin
Have a free space issue problem with one of flash.
Software install command have a same problem.
After that i checked content of both flash I noticed one moment.
Both of flash have a same content(except for one folder):
SW01#dir flash-1:
Directory of flash-1:/
8082 -rw- 81992312 Oct 4 2016 13:23:40 +05:00 cat3k_caa-base.SPA.03.07.04E.pkg
8083 -rw- 5667516 Oct 4 2016 13:23:41 +05:00 cat3k_caa-drivers.SPA.03.07.04E.pkg
8084 -rw- 36656136 Oct 4 2016 13:23:40 +05:00 cat3k_caa-infra.SPA.03.07.04E.pkg
8085 -rw- 46349632 Oct 4 2016 13:23:40 +05:00 cat3k_caa-iosd-universalk9.SPA.152-3.E4.pkg
8086 -rw- 28904332 Oct 4 2016 13:23:40 +05:00 cat3k_caa-platform.SPA.03.07.04E.pkg
8087 -rw- 128580312 Oct 4 2016 13:23:41 +05:00 cat3k_caa-wcm-ldpe.SPA.10.3.141.0.pkg
8088 -rw- 1250 Oct 4 2016 13:23:55 +05:00 packages.conf
32321 drwx 4096 Oct 4 2016 13:29:07 +05:00 virtual-instance
40401 drwx 4096 Oct 4 2016 13:29:07 +05:00 vman_fdb
48481 drwx 4096 Oct 4 2016 13:31:44 +05:00 dc_profile_dir
8090 -rw- 2097152 Jul 11 2019 16:14:36 +05:00 nvram_config
48483 drwx 4096 Oct 4 2016 13:32:38 +05:00 wnweb_store
8091 -rw- 676 Mar 21 2019 10:53:36 +05:00 vlan.dat
32322 drwx 4096 Mar 28 2018 12:56:20 +05:00 onep
1562902528 bytes total (1229455360 bytes free)
SW01#dir flash-2:
Directory of flash:/
8088 -rw- 81992312 Jul 11 2019 15:49:59 +05:00 cat3k_caa-base.SPA.03.07.04E.pkg
8089 -rw- 5667516 Jul 11 2019 15:50:26 +05:00 cat3k_caa-drivers.SPA.03.07.04E.pkg
8090 -rw- 36656136 Jul 11 2019 15:50:40 +05:00 cat3k_caa-infra.SPA.03.07.04E.pkg
8092 -rw- 46349632 Jul 11 2019 15:51:04 +05:00 cat3k_caa-iosd-universalk9.SPA.152-3.E4.pkg
8093 -rw- 28904332 Jul 11 2019 15:51:28 +05:00 cat3k_caa-platform.SPA.03.07.04E.pkg
8094 -rw- 128580312 Jul 11 2019 15:51:51 +05:00 cat3k_caa-wcm-ldpe.SPA.10.3.141.0.pkg
8095 -rw- 1250 Jul 11 2019 15:52:45 +05:00 packages.conf
8096 -rw- 2097152 Jul 11 2019 16:14:34 +05:00 nvram_config
8097 -rw- 676 Jul 11 2019 15:53:11 +05:00 vlan.dat
8098 drwx 4096 Jul 11 2019 15:53:27 +05:00 virtual-instance
16161 drwx 4096 Jul 11 2019 15:55:00 +05:00 dc_profile_dir
16162 drwx 4096 Jul 11 2019 15:55:58 +05:00 wnweb_store
16163 drwx 4096 Jul 11 2019 15:54:15 +05:00 onep
1562509312 bytes total (470110208 bytes free)
flash drives have the same total size, same file set with same size BUT different size of free space.
Have anybody same problem?
Сan you tell me something about my problem?
Leo Laohoo
I've seen that error message before.
I solved that issue by rebooting the stack and then re-run the same command again.
5 Replies 5
balaji.bandi
are you running any virtual-instance on switch ? by any chance for testing ?
if not clearn up the sameon flash 2: follow same below proceedure : ( swithc also in budle mode, check bundle mode upgrade, also if possible make to install mode)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-3/release_notes/ol-16-3-3850.html#pgfId-1135554
BB
Leo Laohoo
I resolve my problem.
I'm reboot stack and problem with free space issue on one flash is gone.
Good and glad to know the problem resolved.
can you mark post as solution, so other community members can refer.
BB
sajish.kumar
Issues in Upgrading IOS on Catalyst 3650 from 03.X.X to 16.X.X Code
If you see space issue even after software clean then you could try below steps which helped me to upgrade Catalyst 3650 from 3.6.10 ver to 16.09.05.
1) Make sure you have existing ios in install mode.
2) Copy the new IOS to flash:
3) Change the boot variable to "flash:cat3k_caa-universalk9.16.09.05.SPA.bin"  - Primary  & flash:packages.conf" - Secondary
4) save the change and reload the switch
5) Now switch will boot up with "Bunddle Mode"
6) No we need to expand the "flash:cat3k_caa-universalk9.16.09.05.SPA.bin" in all the switches one by one
Command: request platform software package install switch 1 file flash:cat3k_caa-universalk9.16.09.05.SPA.bin
7) change the boot variable to new ".conf" file in my case it was ":cat3k_caa-universalk9.16.09.05.SPA.conf".
Save and reload the switch
9) Now you can see new IOS is installed in "Install Mode"
10) Run software clean - "request platform software package clean switch all" . Completed.
