Help needed with creating VLAN Map
MiltonConnor
Hi all,
I need some help w.r.t setting up VLAN maps/ACL.
The following scenario is what I need:
Three VLANs - VLAN10, VLAN20, VLAN30
VLAN10 - Should be able to access all packets on VLAN20 and VLAN 30
VLAN20 - Should only be able to access VLAN10
VLAN30 - Should be able to access both VLAN10 and VLAN20
I am using a catalyst 2960 switch.
Thank you for your consideration.
balaji.bandi
you can start with VLAN ACL from below guide :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/vacl.html
http://www.thepacketwizard.com/blog/2018/09/21/cisco-switch-vlan-acls-vacl/
Once you make the basic config if you stuck anywhere post the configuration here so we can help to tweak.
BB
pmckenzie
Level 3
Level 3
here are the steps I would carry out for vlan 10.
1. create an access list on your switch (assuming your vlan 10 is 192.168.10.0 network)
access-list 100 permit ip 192.168.10.0 0.0.0.255 192.168.20.0. 0.0.0.255
access-list 100 permit ip 192.168.10.0 0.0.0.255 192.168.30.0. 0.0.0.255
2. create an access map for VLAN 10 allowed drop others
vlan access-map TO-VLAN-20-30
match ip address 100
allow
This will default to drop for anything else
3. apply VLAN filter
vlan filter 100 vlan-list 10
4. apply to interface(s)
int fa0/1
switchport capture
There are worlds out there where the sky is burning, where the sea's asleep and the rivers dream, people made of smoke and cities made of song. Somewhere there's danger, somewhere there's injustice and somewhere else the tea is getting cold" Dr Who
Hello
switch
ip access-list extended no_vl30
deny ip 30.30.30.0 0.0.0.255 any
permit ip any any
int vlan 20
ip access-group no_vl30-10 OUT
Kind Regards
Paul
