Campus Manager - Java Plugins
s.zubairi
Community Member
I am using XP, IE 6 and JRE 1.4.1_02 to access Cisco Works Campus Manager application. When I start any of the CM functions, the PC hangs when trying to connect to ANI server.
I have test CM application on server itself... it runs like a champ. But, from my local desktop/laptop it hangs.
CM version is 3.3 with upgrade 1 and IDU 11 applied.
Your help will be appreciated.
TIA
rmushtaq
Level 11
Level 11
There's a patch on CCO for CS 2.2 which will add support for JPI 1.4.2_08
