Can a UPS send traps to Cisco Prime ?
Ditter
Level 4
Level 4
Hi to All,
i have added in Prime some  UPS devices , Prime recognises them via the ReadOnly community i have configured to these UPS.
I have also configured them to send SNMP taps to Cisco Prime.
Is there a way i can view these traps from these devices into Prime?
Ditter.
6 Replies 6
what brand/model are the UPSs ? Do you have the relevant MIB(s) loaded in Prime ? I know that e.g. APC UPSs have their own MIB (PowerNet MIB).
The directory and log file where traps are received in Prime used to be '/opt/CSCOlumos/logs/ncs_nb.log', not sure if that has changed, but whatever traps the UPS sends, should be in that file...
Georg,
i tried to add a basic MIB at Cisco Prime , i got the message Please refer to  /opt/CSCOlumos/logs/ncs_nb.log',
and by looking at the '/opt/CSCOlumos/logs/ncs_nb.log" i get no info in there.
Any ideas?
Thanks.
Also checked the miblibrary.log , nothing there also.
What i did find is that when tried to upload the mib i got messages in the mibLibrary.log (with capital L).
And the message there was :
Added {} to MIB search path.
I did some progress there but the MIB does not get compiled.
Thanks Georg, i am aware of this doc, the messages come in /opt/CSCOlumos/logs   and it is called mibLibrary.log.
In addition MIBs in compressed format won't work, i compiled each mib seperately.
Ditter.
Ditter
Level 4
Level 4
Thanks for the reply.
I would like to get traps from Liebert GXT4-1000RT230.
Is there a way to get these traps in the Web interface?
What i need is to get these  traps from these devices and then forward them to email.
Ia this feasible?
Ditter
Am i missing something?
