Can I rate-limit on the sub-interface in cisco asr 1013?
123456789iig
I am looking for the command of rate-limit on a sub-interface in cisco asr 1013.
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.2(2)S, RELEASE SOFTWARE (fc1)
IOS XE Version: 03.06.00.S
Please let me know if it is possible in cisco asr 1013. If yes then what are the commands.
Zobair
blackrose21
Is it possiable .......???
The ASR no longer supports the rate-limit command, but it does support the same functionality in a QoS policy.
Please find a sample configuration -
ASR1004(config)#policy-map test
ASR1004(config-pmap)#class class-default
ASR1004(config-pmap-c)#shape average 10000
Applying for both ingress and egress : -
ASR1004(config)#int gig1/1/0
ASR1004(config-if)#service-policy output test
or
ASR1004(config-if)#service-policy input test
Command does not work on inboud
Can only use
