Can not reach Internet
MichaelMcCoy
I am afraid I am experiencing a simple oversight but I have looked at this for a little while, and decided to reach out to the community for help.
In my home I am running a Cisco 2901 with a 3560 behind it.  I have three vlans on the switch an dthe Router is handling DHCP.  From the switch I can ping the gateway, which is on the router in a router-on-a-stick config for the vlans.  also from the switch ip, I can ping the gi0/0 interface on the router which is directly connected to the ISP.  The issue is I am unable to get out to the internet.  I can not ping 8.8.8.8 from the switch, or router inside interface.  I can ping 8.8.8.8 from the outside interface on the router.  I have attached my configs.  I think the issue is somewhere involving NAT, but I can't be sure.
I have not done anything with the WAP at the bottom, I am currently plugged into port 1 (10.0.10.11)
Any ideas?
MichaelMcCoy
What I have come across as the biggest impediment and gotten resolved is that my statement
access-list 1 permit 10.0.0.0 0.0.0.255 was incorrect.  The correct statement was:
access-list 1 permit 10.0.0.0 0.255.255.255.
I initially hand this configured as a /24 to allow 10.0.0.0 to be natted, but I was attempting to do a /8.  I made an error with the wildcard mask.  Once this was corrected, I was able to successfully ping the internet from my internal interface on my router.
Now I am working on the WAP configuration.
7 Replies 7
balaji.bandi
high level i do not see route to outside
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
or
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
Interface gi0/1.10
ip nat inside
Encapsulation dot1q 10
Ip address 10.0.10.1 255.255.255.0
Interface gi0/1.20
ip nat inside
Encapsulation dot1q 20
Ip address 10.0.20.1 255.255.255.0
Interface gi0/1.30
ip nat inside
Encapsulation dot1q 30
Ip address 10.0.30.1 255.255.255.0
after changing still not working - please post updated config.
BB
When I do a sh ip route, I have my default route in.  I even set it up to use the port instead of the external ip address.  I did not have the dhcp command at the end, but I will make that change  and see what happens.  Thank you for taking the time to help.
there are numerous issues with your configurations. Make sure the router and switch configs look EXACTLY like the ones below, line by line:
ROUTER
hostname McCoy_Router
no ip domain-lookup
no cdp run
ip dhcp excluded-address 10.0.10.1 10.0.10.10
ip dhcp pool BeautifulLie
default-router 10.0.10.1
dns-server X.X.X.X
network 10.0.10.0 255.255.255.0
ip dhcp excluded-address 10.0.20.1 10.0.20.10
ip dhcp pool 2M
default-router 10.0.20.1
dns-server X.X.X.X
network 10.0.20.0 255.255.255.0
Ip dhcp excluded-address 10.0.30.1 10.0.30.10
ip dhcp pool Work
default-router 10.0.30.1
dns-server X.X.X.X
network 10.0.30.0 255.255.255.0
interface gi0/0
description Uplink_to_Internet
ip address dhcp
ip nat outside
ip nat inside source list 1 interface gi0/0 overload
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/1.10
encapsulation dot1q 10
ip address 10.0.10.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.20
encapsulation dot1q 20
ip address 10.0.20.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.30
encapsulation dot1q 30
ip address 10.0.30.1 255.255.255.0
ip nat inside
SWITCH
hostname McCoy_Switch
no ip domain-lookup
no cdp run
vlan 10
name BeautifulLie
vlan 20
name 2M
vlan 30
name Work
interface range gi0/1-16
switchport mode access
switchport access vlan 10
spanning-tree portfast
interface range gi0/17-32
switchport access vlan 20
interface range gi0/33-47
switchport access vlan 30
Interface gi0/51
Description Trunk_to_Uplink
switchport mode trunk
########## WAP ##########
Interface gi0/51
Description Meraki_wifi
I'm going through this and making sure I got it all correct, will update.  Thank you very much.
In an effort to make this a little less confusing for the time being, I have configured the switch, but I can not ping from the 10.0.10.1 interface on the router to 8.8.8.8.
For my purposes and to be sure that I was understanding everything, I took the switch out the loop.
I entered in all the commands like you suggested.  I've added a sh run and sh ip route of the router.
MichaelMcCoy
good catch !
