08-28-2017 12:13 AM - edited 03-01-2019 06:05 PM
Hi everyone
I've problem with Cisco Prime Infrastructure 3.1 . When a port of a switch goes down, the cisco Prime Infrastructre doesn't generates Critical Alarm for that (this is a problem happen with all port) although Interface alarm policy is set by default (generates for all devies and group).
Please help me fix this issue.
Tks all
Solved! Go to Solution.
08-28-2017 12:28 AM
- Check, wether you have log forwarding and snmp trap forwarding set to cisco prime (also) for the particular set of switches.
M.
08-28-2017 12:28 AM
M.
08-28-2017 12:33 AM
M
Can u explain more detail about them? This is the fisrt time i've deployed PI, so i do'nt have much exp :D
Tks bro
08-28-2017 12:43 AM
- The latter are configuration changes which must be applied on the switches ; such as for instance:
logging host ip-address-of-prime-server
snmp-server host ip-address-of-prime-server
If you are not familiar with these (IOS) commands ; study there documentation first
M.
08-28-2017 01:17 AM
08-28-2017 01:31 AM
- That is true, but my suggestions still apply ; the notification forwarding makes prime aware of an issue otherwise prime would need continuous polling about interfaces statuses to generate correct notifications which would be a burden both for prime and the switches (in resource terms).. Hence the notification forwarding for the discussed components (snmp traps , and syslogging) from the switches -> Prime is still needed.
M.
08-28-2017 02:48 AM
