CAN'T SET DUPLEX MODE
chukwuma
using packet tracer, i was trying to set the duplex of some interfaces both router and and switch but i keep get that invalid input sign(^) under the "d" in the word "duplex". Then i tried to use the question mark to check if duplex is among the commands i can access under interface, lo and behold! the word "duplex" is not there.
please is this an issue with packet tracer or type of router being used?
2 Accepted Solutions
what are the device models you are trying to configure? and pkt version? normally duplex command is available.
Good luck
KB
in pkt version 8.0 its there. check the attached capture. also try using interface settings in GUI
Good luck
KB
5 Replies 5
Good luck
KB
The switch is 3650-24ps, the router is 2911 and the PK version is
v8.1.1.0022
The switch is 3650-24ps, the router is 2911 and the PK version is v8.1.1.0022
Good luck
KB
thanks it worked.
