Cannot Connect to ANIserver
rodrigopitta
Hi.
I'm after a reboot on LMS 2.6 server, the CM home page started showing the following message: "Cannot connect to ANI Server since it is down". I followed the procedures as in the thread "Ciscoworks ANI server cannot connect, Joe Clark please help", but, in the end, after I restarted yhe Damon Manager, all seervices came up, except for the ANI database engine. After I started this serrvice manually, it came up, but the ANI.log file reappeared and the message on the CM home became "Please wait... ANIServer is still initializing."
The result for the pdreg command is below:
C:\>pdreg -l ANIDbEngine
        Process      = ANIDbEngine
        Path         = C:\PROGRA~1\CSCOpx\objects\db\win32\dbsrv9.exe
        Flags        =
        Startup      = Started automatically at boot.
        Dependencies = Not applicable
The result for the pdshow command is attached.
Hope Joe Clark or anyone can help me to.
Thanks in advance.
29 Replies 29
Joe Clarke
You cannot start the ANIDbEngine service manually.  Reboot the server, and if the database does not come back up, then post the output of the pdshow command.
Hi, thank you for the reply.
I rebooted the server and the database came up, but the CM Home page still shows the same message: "Please wait... ANIServer is still initializing". I waited for an hour and no change. The ani.log file is there, but I cannot read it. The pdshow exit is attached.
It is getting worse. When I try to launch RME home, a message says "License Server/Daemon Manager is down. Please check license.log for more information."
I think something is preventing the services to come up.
There are no process problems reflected in the pdshow.  All of the required daemons are up.  Post the ani.log and the NMSROOT/MDC/tomcat/logs/stdout.log and stderr.log.
Have you tried restarting the daemon manager? this happened to me before and after restarting the daemon everything seems to be fine.
Yes. I've restarted Daemon Manager anda e
nven rebooted the server. No changes.
I'm running out of disk space, maybe that is the cause of the problems. Please find attached the stdout and the log for the databases.
The disk space problem is solved, but now, besides the ANI server problem, RME Engine does not start. The Windows Event Viewer shows the pollowing message: "Cannot open transaction log file -- No such file or directory". Is there any way to recover these services?
The log files for the  RME are attached.
Thanks.
Your transaction logs are corrupt.  See this document on how you can recover them:
https://supportforums.cisco.com/docs/DOC-8796
The information will be found under "Recovering from a Server Crash."
Thank you. Now RME engine comes up, but the JRM service still does not. CM Home says "Please wait.... ANIServer is still initializing " and RME home says "JRM Service could be down. Check whether JRM services are running".
The pdshow is attached.
Post the jrm.log.  Was the hostname on this server changed recently?
Yes, the server was renamed accordingly to the procedure in http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_common_services_software/3.0.5/user/guide/diagnos.html#wp1078582. But it worked fine for some time before this problem.
The jrm.log is attached.
Post the outputs of the hostname command and the "pdreg -l CTMJrmServer".
Here it is:
C:\>pdreg -l CTMJrmServer
        Process      = CTMJrmServer
        Path         = C:\PROGRA~1\CSCOpx\bin\cwjava.exe
        Flags        = -cw C:\PROGRA~1\CSCOpx -cw:jre lib/jre -cp:p MDC/tomcat/w
ebapps/rme/WEB-INF/classes,MDC/tomcat/webapps/rme/WEB-INF/lib/ctm.jar,MDC/tomcat
/webapps/rme/WEB-INF/lib/log4j.jar com.cisco.nm.rmeng.jrmwrapper.server.CTMJobMa
nagerServer cwsctx03rjorp
        Dependencies = RMEDbMonitor jrm TomcatMonitor RMECSTMServer
