Cant ping from pc1 to pc2 conected to same router with diferente Ip cl
stanleyssm
Hi 200-301
I started my course ccna 200-301
The first issue i get, is : i cant ping another pc with diferente Ip conected to the same router.
see the image attahed
Please assist
your image is not attached. check if your router have ip routing command in global configuration mode. also make sure PC firewalls are disabled
Good luck
KB
in case this is a Packet Tracer project, post your zipped project (.pkt) file...
stanleyssm
Thanks all
i add DG and works
