07-17-2021 11:37 AM
Hi all,
My ASA 5506-x all the sudden stopped working and I am getting through Putty below. any idea what is that?
thank you ...Please help!!
Rom image verified correctly
Cisco Systems ROMMON, Version 1.1.13, RELEASE SOFTWARE
Copyright (c) 1994-2017 by Cisco Systems, Inc.
Compiled Mon 10/16/2017 17:54:58.29 by wchen64
Current image running: Boot ROM0
Last reset cause: LocalSoft
DIMM Slot 0 : Present
Platform ASA5506 with 4096 Mbytes of main memory
MAC Address: a0:93:51:f3:09:bf
Use BREAK or ESC to interrupt boot.
Use SPACE to begin boot immediately.
Located '.boot_string' @ cluster 39065.
Attempt autoboot: "boot Pv▒▒▒\▒ ▒B{\▒▒ҀI塸V▒▒▒o▒▒▒A"
boot: unsupported boot device "Pv▒▒▒▒"
Attempt autoboot: "boot ▒Q▒ ▒"
boot: unsupported boot device "▒Q▒"
Attempt autoboot: "boot disk0:"
Located 'asa982-lfbff-k8.SPA' @ cluster 11.
Signature verification failed for key# 1
Failed to validate digital signature
LFBFF signature verification failed!!
Failed to Free memory block at address 0x0000000076058010
No kernel found to launch.
Located 'asdm-782.bin' @ cluster 26516.
Invalid cluster# 268435448
Unable to load image 'asdm-782.bin'.
Unable to load asdm-782.bin
boot: cannot determine first file name on device "disk0:/"
autoboot: All boot attempts have failed.
autoboot: Restarting the system.
07-17-2021 02:55 PM
Looks something has gone wrong here- may be a corrupted flash i guess.
Follow the below thread :
https://community.cisco.com/t5/network-security/asa-5506-toast/td-p/3332071
07-20-2021 04:08 AM
I found out that my ASA 5506-x won't save the configuration after reboot it. right now running fine but as soon as I turn it off or reboot it will start doing below and repeat it for maybe 30 to 40 times and then start completely no configuration whatsoever.
Ammar
07-17-2021 11:49 PM
- FYI : https://community.cisco.com/t5/network-security/asa-5506-x-cannot-boot-system/td-p/4261565
M.
07-18-2021 03:21 PM
Thank you for your help. but I have problem. I didn't configure this ASA nor have knowledge how to do it. a person did it for me and I cant get hold of him. So I am stuck.
can you please recommend a company can do this for me. Or maybe you can do it. I don't mind paying you.
Thank you,
Ammar
07-18-2021 11:47 PM
- You may be able to get support from a reseller or contact cisco TAC.
M.
07-20-2021 04:07 AM
Ammar
07-20-2021 04:53 AM - edited 07-20-2021 04:53 AM
boot: cannot determine first file name on device "disk0:/" autoboot: All boot attempts have failed. autoboot: Restarting the system.
i would still investigate this issue, make sure you fix this issue.
The config not save may be reason of config register.
asa# sh ver | i register
Configuration register is 0x1
If it is not 0x1, change it to that value:
asa(config)# config-register 0x1
Can you post complete below commands:
show version
show run
dir
sh bootvar
07-20-2021 05:17 AM
Hi Balaji,
I ran below all the commands you asked for it below.
please see below ....thank you for your help.
sho version
sho run
dir
sho bootvar
Please see below
ciscoasa# sho version
Cisco Adaptive Security Appliance Software Version 9.8(2)
Firepower Extensible Operating System Version 2.2(2.52)
Compiled on Sun 27-Aug-17 13:06 PDT by builders
System image file is "disk0:/asa982-lfbff-k8.SPA"
Config file at boot was "startup-config"
ciscoasa up 13 hours 0 mins
Hardware: ASA5506, 4096 MB RAM, CPU Atom C2000 series 1250 MHz, 1 CPU (4 cores )
Internal ATA Compact Flash, 8000MB
BIOS Flash M25P64 @ 0xfed01000, 16384KB
Encryption hardware device : Cisco ASA Crypto on-board accelerator (revision 0x1 )
Number of accelerators: 1
1: Ext: GigabitEthernet1/1 : address is a093.51f3.09c0, irq 255
2: Ext: GigabitEthernet1/2 : address is a093.51f3.09c1, irq 255
3: Ext: GigabitEthernet1/3 : address is a093.51f3.09c2, irq 255
4: Ext: GigabitEthernet1/4 : address is a093.51f3.09c3, irq 255
5: Ext: GigabitEthernet1/5 : address is a093.51f3.09c4, irq 255
6: Ext: GigabitEthernet1/6 : address is a093.51f3.09c5, irq 255
7: Ext: GigabitEthernet1/7 : address is a093.51f3.09c6, irq 255
8: Ext: GigabitEthernet1/8 : address is a093.51f3.09c7, irq 255
9: Int: Internal-Data1/1 : address is a093.51f3.09bf, irq 255
10: Int: Internal-Data1/2 : address is 0000.0001.0002, irq 0
11: Int: Internal-Control1/1 : address is 0000.0001.0001, irq 0
12: Int: Internal-Data1/3 : address is 0000.0001.0003, irq 0
13: Ext: Management1/1 : address is a093.51f3.09bf, irq 0
14: Int: Internal-Data1/4 : address is 0000.0100.0001, irq 0
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited perpetual
Maximum VLANs : 30 perpetual
Inside Hosts : Unlimited perpetual
Failover : Active/Standby perpetual
Encryption-DES : Enabled perpetual
Encryption-3DES-AES : Enabled perpetual
Carrier : Disabled perpetual
AnyConnect Premium Peers : 4 perpetual
AnyConnect Essentials : Disabled perpetual
Other VPN Peers : 50 perpetual
Total VPN Peers : 50 perpetual
AnyConnect for Mobile : Disabled perpetual
AnyConnect for Cisco VPN Phone : Disabled perpetual
Advanced Endpoint Assessment : Disabled perpetual
Shared License : Disabled perpetual
Total TLS Proxy Sessions : 160 perpetual
Botnet Traffic Filter : Disabled perpetual
Cluster : Disabled perpetual
This platform has an ASA 5506 Security Plus license.
Serial Number: JAD22250L66
Running Permanent Activation Key: 0xf638d073 0xc89f022e 0xf082f1bc 0x8c0ce018 0x4a271cbb
Image type : Release
Key Version : A
Configuration last modified by enable_15 at 00:23:31.919 UTC Tue Jul 20 2021
sho run
ciscoasa# sho run
: Saved
: Serial Number: JAD22250L66
: Hardware: ASA5506, 4096 MB RAM, CPU Atom C2000 series 1250 MHz, 1 CPU (4 cores)
ASA Version 9.8(2)
hostname ciscoasa
enable password $sha512$5000$UETkiOGDFOKsNNz3C86JIw==$qKbZzJ2vfUi5bzDLEp2dUg== pbkdf2
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
names
interface GigabitEthernet1/1
nameif outside
security-level 0
ip address 10.0.0.2 255.255.255.0
interface GigabitEthernet1/2
nameif inside
security-level 100
ip address 192.168.10.254 255.255.255.0
interface GigabitEthernet1/3
nameif camera
security-level 95
ip address 192.168.20.254 255.255.255.0
interface GigabitEthernet1/4
nameif security
security-level 90
ip address 192.168.30.254 255.255.255.0
interface GigabitEthernet1/5
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/6
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/7
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/8
shutdown
no nameif
no security-level
no ip address
interface Management1/1
management-only
shutdown
no nameif
no security-level
no ip address
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
access-list OUTSIDE_ACCESS_IN extended permit icmp any any echo
access-list OUTSIDE_ACCESS_IN extended permit icmp any any echo-reply
pager lines 24
logging enable
logging buffered informational
mtu outside 1500
mtu inside 1500
mtu camera 1500
mtu security 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-782.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
nat (any,outside) dynamic interface
access-group OUTSIDE_ACCESS_IN in interface outside
route outside 0.0.0.0 0.0.0.0 138.88.82.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
aaa authentication login-history
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
service sw-reset-button
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh stricthostkeycheck
ssh 10.0.0.1 255.255.255.255 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 60
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access inside
dhcpd dns 8.8.8.8 8.8.4.4
dhcpd address 192.168.10.10-192.168.10.100 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
dynamic-access-policy-record DfltAccessPolicy
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum client auto
message-length maximum 512
no tcp-inspection
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
policy-map type inspect dns migrated_dns_map_2
parameters
no tcp-inspection
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:713e90058c3597c860707e1e8b84993e
: end
ciscoasa# dir
Directory of disk0:/
2645 -rwx 108563072 06:31:18 Jun 26 2018 asa982-lfbff-k8.SPA
2646 -rwx 13029376 06:32:04 Jun 26 2018 asdm-782.bin
2647 -rwx 33 00:24:46 Jul 20 2021 .boot_string
101 drwx 4096 22:01:23 Jul 19 2021 log
111 drwx 4096 06:36:06 Jun 26 2018 crypto_archive
112 drwx 4096 06:36:08 Jun 26 2018 coredumpinfo
2648 -rwx 0 21:53:06 Jul 19 2021 FSCK0000.REC
2649 -rwx 0 21:53:06 Jul 19 2021 FSCK0001.REC
2650 -rwx 0 21:53:06 Jul 19 2021 FSCK0002.REC
2651 -rwx 0 21:53:06 Jul 19 2021 FSCK0003.REC
2652 -rwx 0 21:53:06 Jul 19 2021 FSCK0004.REC
2653 -rwx 0 21:53:06 Jul 19 2021 FSCK0005.REC
2654 -rwx 0 21:53:06 Jul 19 2021 FSCK0006.REC
2655 -rwx 0 21:53:08 Jul 19 2021 FSCK0007.REC
2656 -rwx 0 21:53:08 Jul 19 2021 FSCK0008.REC
2657 -rwx 0 21:53:08 Jul 19 2021 FSCK0009.REC
2658 -rwx 0 21:53:08 Jul 19 2021 FSCK0010.REC
2659 -rwx 0 21:53:08 Jul 19 2021 FSCK0011.REC
2660 -rwx 0 21:53:08 Jul 19 2021 FSCK0012.REC
2661 -rwx 0 21:53:08 Jul 19 2021 FSCK0013.REC
2662 -rwx 0 21:53:08 Jul 19 2021 FSCK0014.REC
2663 -rwx 0 21:53:08 Jul 19 2021 FSCK0015.REC
2664 -rwx 0 21:53:08 Jul 19 2021 FSCK0016.REC
2665 -rwx 0 21:53:08 Jul 19 2021 FSCK0017.REC
2666 -rwx 0 21:53:08 Jul 19 2021 FSCK0018.REC
2667 -rwx 0 21:53:08 Jul 19 2021 FSCK0019.REC
2668 -rwx 0 21:53:08 Jul 19 2021 FSCK0020.REC
2669 -rwx 0 21:53:08 Jul 19 2021 FSCK0021.REC
2670 -rwx 0 21:53:08 Jul 19 2021 FSCK0022.REC
2671 -rwx 0 21:53:08 Jul 19 2021 FSCK0023.REC
2672 -rwx 0 21:53:08 Jul 19 2021 FSCK0024.REC
2673 -rwx 0 21:53:08 Jul 19 2021 FSCK0025.REC
2674 -rwx 0 21:53:08 Jul 19 2021 FSCK0026.REC
2675 -rwx 0 21:53:08 Jul 19 2021 FSCK0027.REC
2676 -rwx 0 21:53:08 Jul 19 2021 FSCK0028.REC
2677 -rwx 0 21:53:08 Jul 19 2021 FSCK0029.REC
2678 -rwx 0 21:53:08 Jul 19 2021 FSCK0030.REC
2679 -rwx 0 21:53:08 Jul 19 2021 FSCK0031.REC
2680 -rwx 0 21:53:08 Jul 19 2021 FSCK0032.REC
2681 -rwx 0 21:53:08 Jul 19 2021 FSCK0033.REC
2682 -rwx 0 21:53:08 Jul 19 2021 FSCK0034.REC
2683 -rwx 0 21:53:08 Jul 19 2021 FSCK0035.REC
2684 -rwx 0 21:53:08 Jul 19 2021 FSCK0036.REC
2685 -rwx 0 21:53:08 Jul 19 2021 FSCK0037.REC
2686 -rwx 0 21:53:08 Jul 19 2021 FSCK0038.REC
2687 -rwx 0 21:53:08 Jul 19 2021 FSCK0039.REC
2688 -rwx 0 21:53:08 Jul 19 2021 FSCK0040.REC
2689 -rwx 0 21:53:08 Jul 19 2021 FSCK0041.REC
2690 -rwx 0 21:53:08 Jul 19 2021 FSCK0042.REC
2691 -rwx 0 21:53:08 Jul 19 2021 FSCK0043.REC
2692 -rwx 0 21:53:08 Jul 19 2021 FSCK0044.REC
2693 -rwx 0 21:53:08 Jul 19 2021 FSCK0045.REC
2694 -rwx 0 21:53:08 Jul 19 2021 FSCK0046.REC
2695 -rwx 0 21:53:08 Jul 19 2021 FSCK0047.REC
2696 -rwx 0 21:53:08 Jul 19 2021 FSCK0048.REC
2697 -rwx 0 21:53:08 Jul 19 2021 FSCK0049.REC
2698 -rwx 0 21:53:08 Jul 19 2021 FSCK0050.REC
2699 -rwx 0 21:53:08 Jul 19 2021 FSCK0051.REC
2700 -rwx 0 21:53:08 Jul 19 2021 FSCK0052.REC
2701 -rwx 0 21:53:08 Jul 19 2021 FSCK0053.REC
2702 -rwx 0 21:53:08 Jul 19 2021 FSCK0054.REC
2703 -rwx 0 21:53:08 Jul 19 2021 FSCK0055.REC
2704 -rwx 0 21:53:08 Jul 19 2021 FSCK0056.REC
2705 -rwx 0 21:53:08 Jul 19 2021 FSCK0057.REC
2706 -rwx 0 21:53:08 Jul 19 2021 FSCK0058.REC
2707 -rwx 0 21:53:08 Jul 19 2021 FSCK0059.REC
2708 -rwx 0 21:53:08 Jul 19 2021 FSCK0060.REC
2709 -rwx 0 21:53:08 Jul 19 2021 FSCK0061.REC
2710 -rwx 0 21:53:08 Jul 19 2021 FSCK0062.REC
2711 -rwx 0 21:53:08 Jul 19 2021 FSCK0063.REC
2712 -rwx 0 21:53:08 Jul 19 2021 FSCK0064.REC
2713 -rwx 0 21:53:08 Jul 19 2021 FSCK0065.REC
2714 -rwx 0 21:53:08 Jul 19 2021 FSCK0066.REC
2715 -rwx 0 21:53:08 Jul 19 2021 FSCK0067.REC
2716 -rwx 0 21:53:08 Jul 19 2021 FSCK0068.REC
2717 -rwx 0 21:53:08 Jul 19 2021 FSCK0069.REC
2718 -rwx 0 21:53:08 Jul 19 2021 FSCK0070.REC
2719 -rwx 0 21:53:08 Jul 19 2021 FSCK0071.REC
2720 -rwx 0 21:53:08 Jul 19 2021 FSCK0072.REC
2721 -rwx 0 21:53:08 Jul 19 2021 FSCK0073.REC
2722 -rwx 0 21:53:08 Jul 19 2021 FSCK0074.REC
2723 -rwx 0 21:53:08 Jul 19 2021 FSCK0075.REC
2724 -rwx 0 21:53:08 Jul 19 2021 FSCK0076.REC
2725 -rwx 0 21:53:08 Jul 19 2021 FSCK0077.REC
2726 -rwx 0 21:53:08 Jul 19 2021 FSCK0078.REC
2727 -rwx 0 21:53:08 Jul 19 2021 FSCK0079.REC
2728 -rwx 0 21:53:08 Jul 19 2021 FSCK0080.REC
2729 -rwx 0 21:53:08 Jul 19 2021 FSCK0081.REC
2730 -rwx 0 21:53:08 Jul 19 2021 FSCK0082.REC
2731 -rwx 0 21:53:08 Jul 19 2021 FSCK0083.REC
2732 -rwx 0 21:53:08 Jul 19 2021 FSCK0084.REC
2733 -rwx 0 21:53:08 Jul 19 2021 FSCK0085.REC
2734 -rwx 0 21:53:08 Jul 19 2021 FSCK0086.REC
2735 -rwx 0 21:53:08 Jul 19 2021 FSCK0087.REC
2736 -rwx 0 21:53:08 Jul 19 2021 FSCK0088.REC
2737 -rwx 0 21:53:08 Jul 19 2021 FSCK0089.REC
2738 -rwx 0 21:53:08 Jul 19 2021 FSCK0090.REC
2739 -rwx 0 21:53:08 Jul 19 2021 FSCK0091.REC
2740 -rwx 0 21:53:08 Jul 19 2021 FSCK0092.REC
2741 -rwx 0 21:53:08 Jul 19 2021 FSCK0093.REC
2742 -rwx 0 21:53:08 Jul 19 2021 FSCK0094.REC
2743 -rwx 0 21:53:08 Jul 19 2021 FSCK0095.REC
2744 -rwx 0 21:53:08 Jul 19 2021 FSCK0096.REC
2745 -rwx 0 21:53:08 Jul 19 2021 FSCK0097.REC
2746 -rwx 0 21:53:08 Jul 19 2021 FSCK0098.REC
2747 -rwx 0 21:53:08 Jul 19 2021 FSCK0099.REC
2748 -rwx 0 21:53:08 Jul 19 2021 FSCK0100.REC
2749 -rwx 0 21:53:08 Jul 19 2021 FSCK0101.REC
2750 -rwx 0 21:53:08 Jul 19 2021 FSCK0102.REC
2751 -rwx 0 21:53:08 Jul 19 2021 FSCK0103.REC
2752 -rwx 0 21:53:08 Jul 19 2021 FSCK0104.REC
2753 -rwx 0 21:53:08 Jul 19 2021 FSCK0105.REC
2754 -rwx 0 21:53:08 Jul 19 2021 FSCK0106.REC
2755 -rwx 0 21:53:08 Jul 19 2021 FSCK0107.REC
2756 -rwx 0 21:53:08 Jul 19 2021 FSCK0108.REC
2757 -rwx 0 21:53:08 Jul 19 2021 FSCK0109.REC
2758 -rwx 0 21:53:08 Jul 19 2021 FSCK0110.REC
2759 -rwx 0 21:53:08 Jul 19 2021 FSCK0111.REC
2760 -rwx 0 21:53:08 Jul 19 2021 FSCK0112.REC
2761 -rwx 0 21:53:08 Jul 19 2021 FSCK0113.REC
2762 -rwx 0 21:53:08 Jul 19 2021 FSCK0114.REC
2763 -rwx 0 21:53:08 Jul 19 2021 FSCK0115.REC
2764 -rwx 0 21:53:10 Jul 19 2021 FSCK0116.REC
2765 -rwx 0 21:53:10 Jul 19 2021 FSCK0117.REC
2766 -rwx 0 21:53:10 Jul 19 2021 FSCK0118.REC
2767 -rwx 0 21:53:10 Jul 19 2021 FSCK0119.REC
2768 -rwx 0 21:53:10 Jul 19 2021 FSCK0120.REC
2769 -rwx 0 21:53:10 Jul 19 2021 FSCK0121.REC
2770 -rwx 0 21:53:10 Jul 19 2021 FSCK0122.REC
2771 -rwx 0 21:53:10 Jul 19 2021 FSCK0123.REC
2772 -rwx 0 21:53:10 Jul 19 2021 FSCK0124.REC
2773 -rwx 0 21:53:10 Jul 19 2021 FSCK0125.REC
2774 -rwx 0 21:53:10 Jul 19 2021 FSCK0126.REC
2775 -rwx 0 21:53:10 Jul 19 2021 FSCK0127.REC
2776 -rwx 0 21:53:10 Jul 19 2021 FSCK0128.REC
2777 -rwx 0 21:53:10 Jul 19 2021 FSCK0129.REC
2778 -rwx 0 21:53:10 Jul 19 2021 FSCK0130.REC
2779 -rwx 0 21:53:10 Jul 19 2021 FSCK0131.REC
2780 -rwx 0 21:53:10 Jul 19 2021 FSCK0132.REC
2781 -rwx 0 21:53:10 Jul 19 2021 FSCK0133.REC
2782 -rwx 0 21:53:10 Jul 19 2021 FSCK0134.REC
2783 -rwx 0 21:53:10 Jul 19 2021 FSCK0135.REC
2784 -rwx 0 21:53:10 Jul 19 2021 FSCK0136.REC
2785 -rwx 0 21:53:10 Jul 19 2021 FSCK0137.REC
2786 -rwx 0 21:53:10 Jul 19 2021 FSCK0138.REC
2787 -rwx 0 21:53:10 Jul 19 2021 FSCK0139.REC
2788 -rwx 0 21:53:10 Jul 19 2021 FSCK0140.REC
2789 -rwx 0 21:53:10 Jul 19 2021 FSCK0141.REC
2790 -rwx 0 21:53:10 Jul 19 2021 FSCK0142.REC
2791 -rwx 0 21:53:10 Jul 19 2021 FSCK0143.REC
2792 -rwx 0 21:53:10 Jul 19 2021 FSCK0144.REC
2793 -rwx 0 21:53:10 Jul 19 2021 FSCK0145.REC
2794 -rwx 0 21:53:10 Jul 19 2021 FSCK0146.REC
2795 -rwx 0 21:53:10 Jul 19 2021 FSCK0147.REC
2796 -rwx 0 21:53:10 Jul 19 2021 FSCK0148.REC
2797 -rwx 0 21:53:10 Jul 19 2021 FSCK0149.REC
2798 -rwx 0 21:53:10 Jul 19 2021 FSCK0150.REC
2799 -rwx 0 21:53:10 Jul 19 2021 FSCK0151.REC
2800 -rwx 0 21:53:10 Jul 19 2021 FSCK0152.REC
2801 -rwx 0 21:53:10 Jul 19 2021 FSCK0153.REC
2802 -rwx 0 21:53:10 Jul 19 2021 FSCK0154.REC
2803 -rwx 0 21:53:10 Jul 19 2021 FSCK0155.REC
2804 -rwx 0 21:53:10 Jul 19 2021 FSCK0156.REC
2805 -rwx 0 21:53:10 Jul 19 2021 FSCK0157.REC
2806 -rwx 0 21:53:10 Jul 19 2021 FSCK0158.REC
2807 -rwx 0 21:53:10 Jul 19 2021 FSCK0159.REC
2808 -rwx 0 21:53:10 Jul 19 2021 FSCK0160.REC
2809 -rwx 0 21:53:10 Jul 19 2021 FSCK0161.REC
2810 -rwx 0 21:53:10 Jul 19 2021 FSCK0162.REC
2811 -rwx 0 21:53:10 Jul 19 2021 FSCK0163.REC
2812 -rwx 0 21:53:10 Jul 19 2021 FSCK0164.REC
2813 -rwx 0 21:53:10 Jul 19 2021 FSCK0165.REC
2814 -rwx 0 21:53:10 Jul 19 2021 FSCK0166.REC
2815 -rwx 0 21:53:10 Jul 19 2021 FSCK0167.REC
2816 -rwx 0 21:53:10 Jul 19 2021 FSCK0168.REC
2817 -rwx 0 21:53:10 Jul 19 2021 FSCK0169.REC
2818 -rwx 0 21:53:10 Jul 19 2021 FSCK0170.REC
2819 -rwx 0 21:53:12 Jul 19 2021 FSCK0171.REC
2820 -rwx 0 21:53:12 Jul 19 2021 FSCK0172.REC
2821 -rwx 0 21:53:12 Jul 19 2021 FSCK0173.REC
2822 -rwx 0 21:53:12 Jul 19 2021 FSCK0174.REC
2823 -rwx 0 21:53:12 Jul 19 2021 FSCK0175.REC
2824 -rwx 0 21:53:12 Jul 19 2021 FSCK0176.REC
2825 -rwx 0 21:53:12 Jul 19 2021 FSCK0177.REC
2826 -rwx 0 21:53:12 Jul 19 2021 FSCK0178.REC
2827 -rwx 0 21:53:12 Jul 19 2021 FSCK0179.REC
2828 -rwx 0 21:53:12 Jul 19 2021 FSCK0180.REC
2829 -rwx 0 21:53:12 Jul 19 2021 FSCK0181.REC
2830 -rwx 0 21:53:12 Jul 19 2021 FSCK0182.REC
2831 -rwx 0 21:53:12 Jul 19 2021 FSCK0183.REC
2832 -rwx 0 21:53:12 Jul 19 2021 FSCK0184.REC
2833 -rwx 0 21:53:12 Jul 19 2021 FSCK0185.REC
2834 -rwx 0 21:53:12 Jul 19 2021 FSCK0186.REC
2835 -rwx 0 21:53:12 Jul 19 2021 FSCK0187.REC
2836 -rwx 0 21:53:12 Jul 19 2021 FSCK0188.REC
2837 -rwx 0 21:53:12 Jul 19 2021 FSCK0189.REC
2838 -rwx 0 21:53:12 Jul 19 2021 FSCK0190.REC
2839 -rwx 0 21:53:12 Jul 19 2021 FSCK0191.REC
2840 -rwx 0 21:53:12 Jul 19 2021 FSCK0192.REC
2841 -rwx 0 21:53:12 Jul 19 2021 FSCK0193.REC
2842 -rwx 0 21:53:12 Jul 19 2021 FSCK0194.REC
2843 -rwx 0 21:53:12 Jul 19 2021 FSCK0195.REC
2844 -rwx 0 21:53:12 Jul 19 2021 FSCK0196.REC
2845 -rwx 0 21:53:12 Jul 19 2021 FSCK0197.REC
2846 -rwx 0 21:53:12 Jul 19 2021 FSCK0198.REC
2847 -rwx 0 21:53:12 Jul 19 2021 FSCK0199.REC
2848 -rwx 0 21:53:12 Jul 19 2021 FSCK0200.REC
2849 -rwx 0 21:53:12 Jul 19 2021 FSCK0201.REC
2850 -rwx 0 21:53:12 Jul 19 2021 FSCK0202.REC
2851 -rwx 0 21:53:12 Jul 19 2021 FSCK0203.REC
2852 -rwx 0 21:53:12 Jul 19 2021 FSCK0204.REC
2853 -rwx 0 21:53:12 Jul 19 2021 FSCK0205.REC
2854 -rwx 0 21:53:12 Jul 19 2021 FSCK0206.REC
2855 -rwx 0 21:53:12 Jul 19 2021 FSCK0207.REC
2856 -rwx 0 21:53:12 Jul 19 2021 FSCK0208.REC
2857 -rwx 0 21:53:12 Jul 19 2021 FSCK0209.REC
2858 -rwx 0 21:53:12 Jul 19 2021 FSCK0210.REC
2859 -rwx 0 21:53:12 Jul 19 2021 FSCK0211.REC
2860 -rwx 0 21:53:12 Jul 19 2021 FSCK0212.REC
2861 -rwx 0 21:53:12 Jul 19 2021 FSCK0213.REC
2862 -rwx 0 21:53:12 Jul 19 2021 FSCK0214.REC
2863 -rwx 0 21:53:12 Jul 19 2021 FSCK0215.REC
2864 -rwx 0 21:53:12 Jul 19 2021 FSCK0216.REC
2865 -rwx 0 21:53:14 Jul 19 2021 FSCK0217.REC
2866 -rwx 0 21:53:14 Jul 19 2021 FSCK0218.REC
2867 -rwx 0 21:53:14 Jul 19 2021 FSCK0219.REC
2868 -rwx 0 21:53:14 Jul 19 2021 FSCK0220.REC
2869 -rwx 0 21:53:14 Jul 19 2021 FSCK0221.REC
2870 -rwx 0 21:53:14 Jul 19 2021 FSCK0222.REC
2871 -rwx 0 21:53:14 Jul 19 2021 FSCK0223.REC
2872 -rwx 0 21:53:14 Jul 19 2021 FSCK0224.REC
2873 -rwx 0 21:53:14 Jul 19 2021 FSCK0225.REC
2874 -rwx 0 21:53:14 Jul 19 2021 FSCK0226.REC
2875 -rwx 0 21:53:14 Jul 19 2021 FSCK0227.REC
2876 -rwx 0 21:53:14 Jul 19 2021 FSCK0228.REC
2877 -rwx 0 21:53:14 Jul 19 2021 FSCK0229.REC
2878 -rwx 0 21:53:14 Jul 19 2021 FSCK0230.REC
2879 -rwx 0 21:53:14 Jul 19 2021 FSCK0231.REC
2880 -rwx 0 21:53:14 Jul 19 2021 FSCK0232.REC
2881 -rwx 0 21:53:14 Jul 19 2021 FSCK0233.REC
2882 -rwx 0 21:53:14 Jul 19 2021 FSCK0234.REC
2883 -rwx 0 21:53:14 Jul 19 2021 FSCK0235.REC
2884 -rwx 0 21:53:14 Jul 19 2021 FSCK0236.REC
2885 -rwx 0 21:53:14 Jul 19 2021 FSCK0237.REC
2886 -rwx 0 21:53:14 Jul 19 2021 FSCK0238.REC
2887 -rwx 0 21:53:14 Jul 19 2021 FSCK0239.REC
2888 -rwx 0 21:53:14 Jul 19 2021 FSCK0240.REC
2889 -rwx 0 21:53:14 Jul 19 2021 FSCK0241.REC
2890 -rwx 0 21:53:14 Jul 19 2021 FSCK0242.REC
2891 -rwx 0 21:53:14 Jul 19 2021 FSCK0243.REC
2892 -rwx 0 21:53:14 Jul 19 2021 FSCK0244.REC
2893 -rwx 0 21:53:14 Jul 19 2021 FSCK0245.REC
2894 -rwx 0 21:53:14 Jul 19 2021 FSCK0246.REC
2895 -rwx 0 21:53:14 Jul 19 2021 FSCK0247.REC
2896 -rwx 0 21:53:14 Jul 19 2021 FSCK0248.REC
2897 -rwx 0 21:53:14 Jul 19 2021 FSCK0249.REC
2898 -rwx 0 21:53:14 Jul 19 2021 FSCK0250.REC
2899 -rwx 0 21:53:14 Jul 19 2021 FSCK0251.REC
2900 -rwx 0 21:53:14 Jul 19 2021 FSCK0252.REC
2901 -rwx 0 21:53:14 Jul 19 2021 FSCK0253.REC
2902 -rwx 0 21:53:16 Jul 19 2021 FSCK0254.REC
2903 -rwx 0 21:53:16 Jul 19 2021 FSCK0255.REC
2904 -rwx 0 21:53:16 Jul 19 2021 FSCK0256.REC
2905 -rwx 0 21:53:16 Jul 19 2021 FSCK0257.REC
2906 -rwx 0 21:53:16 Jul 19 2021 FSCK0258.REC
2907 -rwx 0 21:53:16 Jul 19 2021 FSCK0259.REC
2908 -rwx 0 21:53:16 Jul 19 2021 FSCK0260.REC
2909 -rwx 0 21:53:16 Jul 19 2021 FSCK0261.REC
2910 -rwx 0 21:53:16 Jul 19 2021 FSCK0262.REC
2911 -rwx 0 21:53:16 Jul 19 2021 FSCK0263.REC
2912 -rwx 0 21:53:16 Jul 19 2021 FSCK0264.REC
2913 -rwx 0 21:53:16 Jul 19 2021 FSCK0265.REC
2914 -rwx 0 21:53:16 Jul 19 2021 FSCK0266.REC
2915 -rwx 0 21:53:16 Jul 19 2021 FSCK0267.REC
2916 -rwx 0 21:53:16 Jul 19 2021 FSCK0268.REC
2917 -rwx 0 21:53:16 Jul 19 2021 FSCK0269.REC
2918 -rwx 0 21:53:16 Jul 19 2021 FSCK0270.REC
2919 -rwx 0 21:53:16 Jul 19 2021 FSCK0271.REC
2920 -rwx 0 21:53:16 Jul 19 2021 FSCK0272.REC
2921 -rwx 0 21:53:16 Jul 19 2021 FSCK0273.REC
2922 -rwx 0 21:53:16 Jul 19 2021 FSCK0274.REC
2923 -rwx 0 21:53:16 Jul 19 2021 FSCK0275.REC
2924 -rwx 0 21:53:16 Jul 19 2021 FSCK0276.REC
2925 -rwx 0 21:53:16 Jul 19 2021 FSCK0277.REC
2926 -rwx 0 21:53:16 Jul 19 2021 FSCK0278.REC
2927 -rwx 0 21:53:16 Jul 19 2021 FSCK0279.REC
2928 -rwx 0 21:53:16 Jul 19 2021 FSCK0280.REC
2929 -rwx 0 21:53:16 Jul 19 2021 FSCK0281.REC
2930 -rwx 0 21:53:16 Jul 19 2021 FSCK0282.REC
2931 -rwx 0 21:53:16 Jul 19 2021 FSCK0283.REC
2932 -rwx 0 21:53:16 Jul 19 2021 FSCK0284.REC
2933 -rwx 0 21:53:16 Jul 19 2021 FSCK0285.REC
2934 -rwx 0 21:53:18 Jul 19 2021 FSCK0286.REC
2935 -rwx 0 21:53:18 Jul 19 2021 FSCK0287.REC
2936 -rwx 0 21:53:18 Jul 19 2021 FSCK0288.REC
2937 -rwx 0 21:53:18 Jul 19 2021 FSCK0289.REC
2938 -rwx 0 21:53:18 Jul 19 2021 FSCK0290.REC
2939 -rwx 0 21:53:18 Jul 19 2021 FSCK0291.REC
2940 -rwx 0 21:53:18 Jul 19 2021 FSCK0292.REC
2941 -rwx 0 21:53:18 Jul 19 2021 FSCK0293.REC
2942 -rwx 0 21:53:18 Jul 19 2021 FSCK0294.REC
2943 -rwx 0 21:53:18 Jul 19 2021 FSCK0295.REC
2944 -rwx 0 21:53:18 Jul 19 2021 FSCK0296.REC
2945 -rwx 0 21:53:18 Jul 19 2021 FSCK0297.REC
2946 -rwx 0 21:53:18 Jul 19 2021 FSCK0298.REC
2947 -rwx 0 21:53:18 Jul 19 2021 FSCK0299.REC
2948 -rwx 0 21:53:18 Jul 19 2021 FSCK0300.REC
2949 -rwx 0 21:53:18 Jul 19 2021 FSCK0301.REC
2950 -rwx 0 21:53:18 Jul 19 2021 FSCK0302.REC
2951 -rwx 0 21:53:18 Jul 19 2021 FSCK0303.REC
2952 -rwx 0 21:53:18 Jul 19 2021 FSCK0304.REC
2953 -rwx 0 21:53:18 Jul 19 2021 FSCK0305.REC
2954 -rwx 0 21:53:18 Jul 19 2021 FSCK0306.REC
2955 -rwx 0 21:53:18 Jul 19 2021 FSCK0307.REC
2956 -rwx 0 21:53:18 Jul 19 2021 FSCK0308.REC
2957 -rwx 0 21:53:18 Jul 19 2021 FSCK0309.REC
2958 -rwx 0 21:53:18 Jul 19 2021 FSCK0310.REC
2959 -rwx 0 21:53:18 Jul 19 2021 FSCK0311.REC
2960 -rwx 0 21:53:18 Jul 19 2021 FSCK0312.REC
2961 -rwx 0 21:53:18 Jul 19 2021 FSCK0313.REC
2962 -rwx 0 21:53:18 Jul 19 2021 FSCK0314.REC
2963 -rwx 0 21:53:20 Jul 19 2021 FSCK0315.REC
2964 -rwx 0 21:53:20 Jul 19 2021 FSCK0316.REC
2965 -rwx 0 21:53:20 Jul 19 2021 FSCK0317.REC
2966 -rwx 0 21:53:20 Jul 19 2021 FSCK0318.REC
2967 -rwx 0 21:53:20 Jul 19 2021 FSCK0319.REC
2968 -rwx 0 21:53:20 Jul 19 2021 FSCK0320.REC
2969 -rwx 0 21:53:20 Jul 19 2021 FSCK0321.REC
2970 -rwx 0 21:53:20 Jul 19 2021 FSCK0322.REC
2971 -rwx 0 21:53:20 Jul 19 2021 FSCK0323.REC
2972 -rwx 0 21:53:20 Jul 19 2021 FSCK0324.REC
2973 -rwx 0 21:53:20 Jul 19 2021 FSCK0325.REC
2974 -rwx 0 21:53:20 Jul 19 2021 FSCK0326.REC
2975 -rwx 0 21:53:20 Jul 19 2021 FSCK0327.REC
2976 -rwx 0 21:53:20 Jul 19 2021 FSCK0328.REC
2977 -rwx 0 21:53:20 Jul 19 2021 FSCK0329.REC
2978 -rwx 0 21:53:20 Jul 19 2021 FSCK0330.REC
2979 -rwx 0 21:53:20 Jul 19 2021 FSCK0331.REC
2980 -rwx 0 21:53:20 Jul 19 2021 FSCK0332.REC
2981 -rwx 0 21:53:20 Jul 19 2021 FSCK0333.REC
2982 -rwx 0 21:53:20 Jul 19 2021 FSCK0334.REC
2983 -rwx 0 21:53:20 Jul 19 2021 FSCK0335.REC
2984 -rwx 0 21:53:20 Jul 19 2021 FSCK0336.REC
2985 -rwx 0 21:53:20 Jul 19 2021 FSCK0337.REC
2986 -rwx 0 21:53:20 Jul 19 2021 FSCK0338.REC
2987 -rwx 0 21:53:20 Jul 19 2021 FSCK0339.REC
2988 -rwx 0 21:53:20 Jul 19 2021 FSCK0340.REC
2989 -rwx 0 21:53:20 Jul 19 2021 FSCK0341.REC
2990 -rwx 0 21:53:20 Jul 19 2021 FSCK0342.REC
2991 -rwx 0 21:53:22 Jul 19 2021 FSCK0343.REC
2992 -rwx 0 21:53:22 Jul 19 2021 FSCK0344.REC
2993 -rwx 0 21:53:22 Jul 19 2021 FSCK0345.REC
2994 -rwx 0 21:53:22 Jul 19 2021 FSCK0346.REC
2995 -rwx 0 21:53:22 Jul 19 2021 FSCK0347.REC
2996 -rwx 0 21:53:22 Jul 19 2021 FSCK0348.REC
2997 -rwx 0 21:53:22 Jul 19 2021 FSCK0349.REC
2998 -rwx 0 21:53:22 Jul 19 2021 FSCK0350.REC
2999 -rwx 0 21:53:22 Jul 19 2021 FSCK0351.REC
3000 -rwx 0 21:53:22 Jul 19 2021 FSCK0352.REC
3001 -rwx 0 21:53:22 Jul 19 2021 FSCK0353.REC
3002 -rwx 0 21:53:22 Jul 19 2021 FSCK0354.REC
3003 -rwx 0 21:53:22 Jul 19 2021 FSCK0355.REC
3004 -rwx 0 21:53:22 Jul 19 2021 FSCK0356.REC
3005 -rwx 0 21:53:22 Jul 19 2021 FSCK0357.REC
3006 -rwx 0 21:53:22 Jul 19 2021 FSCK0358.REC
3007 -rwx 0 21:53:22 Jul 19 2021 FSCK0359.REC
3008 -rwx 0 21:53:22 Jul 19 2021 FSCK0360.REC
3009 -rwx 0 21:53:22 Jul 19 2021 FSCK0361.REC
3010 -rwx 0 21:53:22 Jul 19 2021 FSCK0362.REC
3011 -rwx 0 21:53:22 Jul 19 2021 FSCK0363.REC
3012 -rwx 0 21:53:22 Jul 19 2021 FSCK0364.REC
3013 -rwx 0 21:53:22 Jul 19 2021 FSCK0365.REC
3014 -rwx 0 21:53:22 Jul 19 2021 FSCK0366.REC
3015 -rwx 0 21:53:22 Jul 19 2021 FSCK0367.REC
3016 -rwx 0 21:53:22 Jul 19 2021 FSCK0368.REC
3017 -rwx 0 21:53:24 Jul 19 2021 FSCK0369.REC
3018 -rwx 0 21:53:24 Jul 19 2021 FSCK0370.REC
3019 -rwx 0 21:53:24 Jul 19 2021 FSCK0371.REC
3020 -rwx 0 21:53:24 Jul 19 2021 FSCK0372.REC
3021 -rwx 0 21:53:24 Jul 19 2021 FSCK0373.REC
3022 -rwx 0 21:53:24 Jul 19 2021 FSCK0374.REC
3023 -rwx 0 21:53:24 Jul 19 2021 FSCK0375.REC
3024 -rwx 0 21:53:24 Jul 19 2021 FSCK0376.REC
3025 -rwx 0 21:53:24 Jul 19 2021 FSCK0377.REC
3026 -rwx 0 21:53:24 Jul 19 2021 FSCK0378.REC
3027 -rwx 0 21:53:24 Jul 19 2021 FSCK0379.REC
3028 -rwx 0 21:53:24 Jul 19 2021 FSCK0380.REC
3029 -rwx 0 21:53:24 Jul 19 2021 FSCK0381.REC
3030 -rwx 0 21:53:24 Jul 19 2021 FSCK0382.REC
3031 -rwx 0 21:53:24 Jul 19 2021 FSCK0383.REC
3032 -rwx 0 21:53:24 Jul 19 2021 FSCK0384.REC
3033 -rwx 0 21:53:24 Jul 19 2021 FSCK0385.REC
3034 -rwx 0 21:53:24 Jul 19 2021 FSCK0386.REC
3035 -rwx 0 21:53:24 Jul 19 2021 FSCK0387.REC
3036 -rwx 0 21:53:24 Jul 19 2021 FSCK0388.REC
3037 -rwx 0 21:53:24 Jul 19 2021 FSCK0389.REC
3038 -rwx 0 21:53:24 Jul 19 2021 FSCK0390.REC
3039 -rwx 0 21:53:26 Jul 19 2021 FSCK0391.REC
3040 -rwx 0 21:53:26 Jul 19 2021 FSCK0392.REC
3041 -rwx 0 21:53:26 Jul 19 2021 FSCK0393.REC
3042 -rwx 0 21:53:26 Jul 19 2021 FSCK0394.REC
3043 -rwx 0 21:53:26 Jul 19 2021 FSCK0395.REC
3044 -rwx 0 21:53:26 Jul 19 2021 FSCK0396.REC
3045 -rwx 0 21:53:26 Jul 19 2021 FSCK0397.REC
3046 -rwx 0 21:53:26 Jul 19 2021 FSCK0398.REC
3047 -rwx 0 21:53:26 Jul 19 2021 FSCK0399.REC
3048 -rwx 0 21:53:26 Jul 19 2021 FSCK0400.REC
3049 -rwx 0 21:53:26 Jul 19 2021 FSCK0401.REC
3050 -rwx 0 21:53:26 Jul 19 2021 FSCK0402.REC
3051 -rwx 0 21:53:26 Jul 19 2021 FSCK0403.REC
3052 -rwx 0 21:53:26 Jul 19 2021 FSCK0404.REC
3053 -rwx 0 21:53:26 Jul 19 2021 FSCK0405.REC
3054 -rwx 0 21:53:26 Jul 19 2021 FSCK0406.REC
3055 -rwx 0 21:53:26 Jul 19 2021 FSCK0407.REC
3056 -rwx 0 21:53:26 Jul 19 2021 FSCK0408.REC
3057 -rwx 0 21:53:26 Jul 19 2021 FSCK0409.REC
3058 -rwx 0 21:53:26 Jul 19 2021 FSCK0410.REC
3059 -rwx 0 21:53:26 Jul 19 2021 FSCK0411.REC
3060 -rwx 0 21:53:28 Jul 19 2021 FSCK0412.REC
3061 -rwx 0 21:53:28 Jul 19 2021 FSCK0413.REC
3062 -rwx 0 21:53:28 Jul 19 2021 FSCK0414.REC
3063 -rwx 0 21:53:28 Jul 19 2021 FSCK0415.REC
3064 -rwx 0 21:53:28 Jul 19 2021 FSCK0416.REC
3065 -rwx 0 21:53:28 Jul 19 2021 FSCK0417.REC
3066 -rwx 0 21:53:28 Jul 19 2021 FSCK0418.REC
3067 -rwx 0 21:53:28 Jul 19 2021 FSCK0419.REC
3068 -rwx 0 21:53:28 Jul 19 2021 FSCK0420.REC
3069 -rwx 0 21:53:28 Jul 19 2021 FSCK0421.REC
3070 -rwx 0 21:53:28 Jul 19 2021 FSCK0422.REC
3071 -rwx 0 21:53:28 Jul 19 2021 FSCK0423.REC
3072 -rwx 0 21:53:28 Jul 19 2021 FSCK0424.REC
3073 -rwx 0 21:53:28 Jul 19 2021 FSCK0425.REC
3074 -rwx 0 21:53:28 Jul 19 2021 FSCK0426.REC
3075 -rwx 0 21:53:28 Jul 19 2021 FSCK0427.REC
3076 -rwx 0 21:53:28 Jul 19 2021 FSCK0428.REC
3077 -rwx 0 21:53:28 Jul 19 2021 FSCK0429.REC
3078 -rwx 0 21:53:28 Jul 19 2021 FSCK0430.REC
3079 -rwx 0 21:53:28 Jul 19 2021 FSCK0431.REC
3080 -rwx 0 21:53:28 Jul 19 2021 FSCK0432.REC
3081 -rwx 0 21:53:30 Jul 19 2021 FSCK0433.REC
3082 -rwx 0 21:53:30 Jul 19 2021 FSCK0434.REC
3083 -rwx 0 21:53:30 Jul 19 2021 FSCK0435.REC
3084 -rwx 0 21:53:30 Jul 19 2021 FSCK0436.REC
3085 -rwx 0 21:53:30 Jul 19 2021 FSCK0437.REC
3086 -rwx 0 21:53:30 Jul 19 2021 FSCK0438.REC
3087 -rwx 0 21:53:30 Jul 19 2021 FSCK0439.REC
3088 -rwx 0 21:53:30 Jul 19 2021 FSCK0440.REC
3089 -rwx 0 21:53:30 Jul 19 2021 FSCK0441.REC
3090 -rwx 0 21:53:30 Jul 19 2021 FSCK0442.REC
3091 -rwx 0 21:53:30 Jul 19 2021 FSCK0443.REC
3092 -rwx 0 21:53:30 Jul 19 2021 FSCK0444.REC
3093 -rwx 0 21:53:30 Jul 19 2021 FSCK0445.REC
3094 -rwx 0 21:53:30 Jul 19 2021 FSCK0446.REC
3095 -rwx 0 21:53:30 Jul 19 2021 FSCK0447.REC
3096 -rwx 0 21:53:30 Jul 19 2021 FSCK0448.REC
3097 -rwx 0 21:53:30 Jul 19 2021 FSCK0449.REC
3098 -rwx 0 21:53:30 Jul 19 2021 FSCK0450.REC
3099 -rwx 0 21:53:30 Jul 19 2021 FSCK0451.REC
3100 -rwx 0 21:53:30 Jul 19 2021 FSCK0452.REC
3101 -rwx 0 21:53:32 Jul 19 2021 FSCK0453.REC
3102 -rwx 0 21:53:32 Jul 19 2021 FSCK0454.REC
3103 -rwx 0 21:53:32 Jul 19 2021 FSCK0455.REC
3104 -rwx 0 21:53:32 Jul 19 2021 FSCK0456.REC
3105 -rwx 0 21:53:32 Jul 19 2021 FSCK0457.REC
3106 -rwx 0 21:53:32 Jul 19 2021 FSCK0458.REC
3107 -rwx 0 21:53:32 Jul 19 2021 FSCK0459.REC
3108 -rwx 0 21:53:32 Jul 19 2021 FSCK0460.REC
3109 -rwx 0 21:53:32 Jul 19 2021 FSCK0461.REC
3110 -rwx 0 21:53:32 Jul 19 2021 FSCK0462.REC
3111 -rwx 0 21:53:32 Jul 19 2021 FSCK0463.REC
3112 -rwx 0 21:53:32 Jul 19 2021 FSCK0464.REC
3113 -rwx 0 21:53:32 Jul 19 2021 FSCK0465.REC
3114 -rwx 0 21:53:32 Jul 19 2021 FSCK0466.REC
3115 -rwx 0 21:53:32 Jul 19 2021 FSCK0467.REC
3116 -rwx 0 21:53:32 Jul 19 2021 FSCK0468.REC
3117 -rwx 0 21:53:32 Jul 19 2021 FSCK0469.REC
3118 -rwx 0 21:53:32 Jul 19 2021 FSCK0470.REC
3119 -rwx 0 21:53:32 Jul 19 2021 FSCK0471.REC
3120 -rwx 0 21:53:32 Jul 19 2021 FSCK0472.REC
3121 -rwx 0 21:53:34 Jul 19 2021 FSCK0473.REC
3122 -rwx 0 21:53:34 Jul 19 2021 FSCK0474.REC
3123 -rwx 0 21:53:34 Jul 19 2021 FSCK0475.REC
3124 -rwx 0 21:53:34 Jul 19 2021 FSCK0476.REC
3125 -rwx 0 21:53:34 Jul 19 2021 FSCK0477.REC
3126 -rwx 0 21:53:34 Jul 19 2021 FSCK0478.REC
3127 -rwx 0 21:53:34 Jul 19 2021 FSCK0479.REC
3128 -rwx 0 21:53:34 Jul 19 2021 FSCK0480.REC
3129 -rwx 0 21:53:34 Jul 19 2021 FSCK0481.REC
3130 -rwx 0 21:53:34 Jul 19 2021 FSCK0482.REC
3131 -rwx 0 21:53:34 Jul 19 2021 FSCK0483.REC
3132 -rwx 0 21:53:34 Jul 19 2021 FSCK0484.REC
3133 -rwx 0 21:53:34 Jul 19 2021 FSCK0485.REC
3134 -rwx 0 21:53:34 Jul 19 2021 FSCK0486.REC
3135 -rwx 0 21:53:34 Jul 19 2021 FSCK0487.REC
3136 -rwx 0 21:53:34 Jul 19 2021 FSCK0488.REC
3137 -rwx 0 21:53:34 Jul 19 2021 FSCK0489.REC
3138 -rwx 0 21:53:34 Jul 19 2021 FSCK0490.REC
3139 -rwx 0 21:53:36 Jul 19 2021 FSCK0491.REC
3140 -rwx 0 21:53:36 Jul 19 2021 FSCK0492.REC
3141 -rwx 0 21:53:36 Jul 19 2021 FSCK0493.REC
3142 -rwx 0 21:53:36 Jul 19 2021 FSCK0494.REC
3143 -rwx 0 21:53:36 Jul 19 2021 FSCK0495.REC
3144 -rwx 0 21:53:36 Jul 19 2021 FSCK0496.REC
3145 -rwx 0 21:53:36 Jul 19 2021 FSCK0497.REC
3146 -rwx 0 21:53:36 Jul 19 2021 FSCK0498.REC
3147 -rwx 0 21:53:36 Jul 19 2021 FSCK0499.REC
3148 -rwx 0 21:53:36 Jul 19 2021 FSCK0500.REC
3149 -rwx 0 21:53:36 Jul 19 2021 FSCK0501.REC
3150 -rwx 0 21:53:36 Jul 19 2021 FSCK0502.REC
3151 -rwx 0 21:53:36 Jul 19 2021 FSCK0503.REC
3152 -rwx 0 21:53:36 Jul 19 2021 FSCK0504.REC
3153 -rwx 0 21:53:36 Jul 19 2021 FSCK0505.REC
3154 -rwx 0 21:53:36 Jul 19 2021 FSCK0506.REC
3155 -rwx 0 21:53:36 Jul 19 2021 FSCK0507.REC
3156 -rwx 0 21:53:38 Jul 19 2021 FSCK0508.REC
3157 -rwx 0 21:53:38 Jul 19 2021 FSCK0509.REC
3158 -rwx 0 21:53:38 Jul 19 2021 FSCK0510.REC
3159 -rwx 0 21:53:38 Jul 19 2021 FSCK0511.REC
3160 -rwx 0 21:53:38 Jul 19 2021 FSCK0512.REC
3161 -rwx 0 21:53:38 Jul 19 2021 FSCK0513.REC
3162 -rwx 0 21:53:38 Jul 19 2021 FSCK0514.REC
3163 -rwx 0 21:53:38 Jul 19 2021 FSCK0515.REC
3164 -rwx 0 21:53:38 Jul 19 2021 FSCK0516.REC
3165 -rwx 0 21:53:38 Jul 19 2021 FSCK0517.REC
3166 -rwx 0 21:53:38 Jul 19 2021 FSCK0518.REC
3167 -rwx 0 21:53:38 Jul 19 2021 FSCK0519.REC
3168 -rwx 0 21:53:38 Jul 19 2021 FSCK0520.REC
3169 -rwx 0 21:53:38 Jul 19 2021 FSCK0521.REC
3170 -rwx 0 21:53:38 Jul 19 2021 FSCK0522.REC
3171 -rwx 0 21:53:38 Jul 19 2021 FSCK0523.REC
3172 -rwx 0 21:53:40 Jul 19 2021 FSCK0524.REC
3173 -rwx 0 21:53:40 Jul 19 2021 FSCK0525.REC
3174 -rwx 0 21:53:40 Jul 19 2021 FSCK0526.REC
3175 -rwx 0 21:53:40 Jul 19 2021 FSCK0527.REC
3176 -rwx 0 21:53:40 Jul 19 2021 FSCK0528.REC
3177 -rwx 0 21:53:40 Jul 19 2021 FSCK0529.REC
3178 -rwx 0 21:53:40 Jul 19 2021 FSCK0530.REC
3179 -rwx 0 21:53:40 Jul 19 2021 FSCK0531.REC
3180 -rwx 0 21:53:40 Jul 19 2021 FSCK0532.REC
3181 -rwx 0 21:53:40 Jul 19 2021 FSCK0533.REC
3182 -rwx 0 21:53:40 Jul 19 2021 FSCK0534.REC
3183 -rwx 0 21:53:40 Jul 19 2021 FSCK0535.REC
3184 -rwx 0 21:53:40 Jul 19 2021 FSCK0536.REC
3185 -rwx 0 21:53:40 Jul 19 2021 FSCK0537.REC
3186 -rwx 0 21:53:40 Jul 19 2021 FSCK0538.REC
3187 -rwx 0 21:53:40 Jul 19 2021 FSCK0539.REC
3188 -rwx 0 21:53:42 Jul 19 2021 FSCK0540.REC
3189 -rwx 0 21:53:42 Jul 19 2021 FSCK0541.REC
3190 -rwx 0 21:53:42 Jul 19 2021 FSCK0542.REC
3191 -rwx 0 21:53:42 Jul 19 2021 FSCK0543.REC
3192 -rwx 0 21:53:42 Jul 19 2021 FSCK0544.REC
3193 -rwx 0 21:53:42 Jul 19 2021 FSCK0545.REC
3194 -rwx 0 21:53:42 Jul 19 2021 FSCK0546.REC
3195 -rwx 0 21:53:42 Jul 19 2021 FSCK0547.REC
3196 -rwx 0 21:53:42 Jul 19 2021 FSCK0548.REC
3197 -rwx 0 21:53:42 Jul 19 2021 FSCK0549.REC
3198 -rwx 0 21:53:42 Jul 19 2021 FSCK0550.REC
3199 -rwx 0 21:53:42 Jul 19 2021 FSCK0551.REC
3200 -rwx 0 21:53:42 Jul 19 2021 FSCK0552.REC
3201 -rwx 0 21:53:42 Jul 19 2021 FSCK0553.REC
3202 -rwx 0 21:53:42 Jul 19 2021 FSCK0554.REC
3203 -rwx 0 21:53:42 Jul 19 2021 FSCK0555.REC
3204 -rwx 0 21:53:44 Jul 19 2021 FSCK0556.REC
3205 -rwx 0 21:53:44 Jul 19 2021 FSCK0557.REC
3206 -rwx 0 21:53:44 Jul 19 2021 FSCK0558.REC
3207 -rwx 0 21:53:44 Jul 19 2021 FSCK0559.REC
3208 -rwx 0 21:53:44 Jul 19 2021 FSCK0560.REC
3209 -rwx 0 21:53:44 Jul 19 2021 FSCK0561.REC
3210 -rwx 0 21:53:44 Jul 19 2021 FSCK0562.REC
3211 -rwx 0 21:53:44 Jul 19 2021 FSCK0563.REC
3212 -rwx 0 21:53:44 Jul 19 2021 FSCK0564.REC
3213 -rwx 0 21:53:44 Jul 19 2021 FSCK0565.REC
3214 -rwx 0 21:53:44 Jul 19 2021 FSCK0566.REC
3215 -rwx 0 21:53:44 Jul 19 2021 FSCK0567.REC
3216 -rwx 0 21:53:44 Jul 19 2021 FSCK0568.REC
3217 -rwx 0 21:53:44 Jul 19 2021 FSCK0569.REC
3218 -rwx 0 21:53:44 Jul 19 2021 FSCK0570.REC
3219 -rwx 0 21:53:46 Jul 19 2021 FSCK0571.REC
3220 -rwx 0 21:53:46 Jul 19 2021 FSCK0572.REC
3221 -rwx 0 21:53:46 Jul 19 2021 FSCK0573.REC
3222 -rwx 0 21:53:46 Jul 19 2021 FSCK0574.REC
3223 -rwx 0 21:53:46 Jul 19 2021 FSCK0575.REC
3224 -rwx 0 21:53:46 Jul 19 2021 FSCK0576.REC
3225 -rwx 0 21:53:46 Jul 19 2021 FSCK0577.REC
3226 -rwx 0 21:53:46 Jul 19 2021 FSCK0578.REC
3227 -rwx 0 21:53:46 Jul 19 2021 FSCK0579.REC
3228 -rwx 0 21:53:46 Jul 19 2021 FSCK0580.REC
3229 -rwx 0 21:53:46 Jul 19 2021 FSCK0581.REC
3230 -rwx 0 21:53:46 Jul 19 2021 FSCK0582.REC
3231 -rwx 0 21:53:46 Jul 19 2021 FSCK0583.REC
3232 -rwx 0 21:53:46 Jul 19 2021 FSCK0584.REC
3233 -rwx 0 21:53:46 Jul 19 2021 FSCK0585.REC
3234 -rwx 0 21:53:48 Jul 19 2021 FSCK0586.REC
3235 -rwx 0 21:53:48 Jul 19 2021 FSCK0587.REC
3236 -rwx 0 21:53:48 Jul 19 2021 FSCK0588.REC
3237 -rwx 0 21:53:48 Jul 19 2021 FSCK0589.REC
3238 -rwx 0 21:53:48 Jul 19 2021 FSCK0590.REC
3239 -rwx 0 21:53:48 Jul 19 2021 FSCK0591.REC
3240 -rwx 0 21:53:48 Jul 19 2021 FSCK0592.REC
3241 -rwx 0 21:53:48 Jul 19 2021 FSCK0593.REC
3242 -rwx 0 21:53:48 Jul 19 2021 FSCK0594.REC
3243 -rwx 0 21:53:48 Jul 19 2021 FSCK0595.REC
3244 -rwx 0 21:53:48 Jul 19 2021 FSCK0596.REC
3245 -rwx 0 21:53:48 Jul 19 2021 FSCK0597.REC
3246 -rwx 0 21:53:48 Jul 19 2021 FSCK0598.REC
3247 -rwx 0 21:53:48 Jul 19 2021 FSCK0599.REC
3248 -rwx 0 21:53:48 Jul 19 2021 FSCK0600.REC
3249 -rwx 0 21:53:50 Jul 19 2021 FSCK0601.REC
3250 -rwx 0 21:53:50 Jul 19 2021 FSCK0602.REC
3251 -rwx 0 21:53:50 Jul 19 2021 FSCK0603.REC
3252 -rwx 0 21:53:50 Jul 19 2021 FSCK0604.REC
3253 -rwx 0 21:53:50 Jul 19 2021 FSCK0605.REC
3254 -rwx 0 21:53:50 Jul 19 2021 FSCK0606.REC
3255 -rwx 0 21:53:50 Jul 19 2021 FSCK0607.REC
3256 -rwx 0 21:53:50 Jul 19 2021 FSCK0608.REC
3257 -rwx 0 21:53:50 Jul 19 2021 FSCK0609.REC
3258 -rwx 0 21:53:50 Jul 19 2021 FSCK0610.REC
3259 -rwx 0 21:53:50 Jul 19 2021 FSCK0611.REC
3260 -rwx 0 21:53:50 Jul 19 2021 FSCK0612.REC
3261 -rwx 0 21:53:50 Jul 19 2021 FSCK0613.REC
3262 -rwx 0 21:53:50 Jul 19 2021 FSCK0614.REC
3263 -rwx 0 21:53:52 Jul 19 2021 FSCK0615.REC
3264 -rwx 0 21:53:52 Jul 19 2021 FSCK0616.REC
3265 -rwx 0 21:53:52 Jul 19 2021 FSCK0617.REC
3266 -rwx 0 21:53:52 Jul 19 2021 FSCK0618.REC
3267 -rwx 0 21:53:52 Jul 19 2021 FSCK0619.REC
3268 -rwx 0 21:53:52 Jul 19 2021 FSCK0620.REC
3269 -rwx 0 21:53:52 Jul 19 2021 FSCK0621.REC
3270 -rwx 0 21:53:52 Jul 19 2021 FSCK0622.REC
3271 -rwx 0 21:53:52 Jul 19 2021 FSCK0623.REC
3272 -rwx 0 21:53:52 Jul 19 2021 FSCK0624.REC
3273 -rwx 0 21:53:52 Jul 19 2021 FSCK0625.REC
3274 -rwx 0 21:53:52 Jul 19 2021 FSCK0626.REC
3275 -rwx 0 21:53:52 Jul 19 2021 FSCK0627.REC
3276 -rwx 0 21:53:54 Jul 19 2021 FSCK0628.REC
3277 -rwx 0 21:53:54 Jul 19 2021 FSCK0629.REC
3278 -rwx 0 21:53:54 Jul 19 2021 FSCK0630.REC
3279 -rwx 0 21:53:54 Jul 19 2021 FSCK0631.REC
3280 -rwx 0 21:53:54 Jul 19 2021 FSCK0632.REC
3281 -rwx 0 21:53:54 Jul 19 2021 FSCK0633.REC
3282 -rwx 0 21:53:54 Jul 19 2021 FSCK0634.REC
3283 -rwx 0 21:53:54 Jul 19 2021 FSCK0635.REC
3284 -rwx 0 21:53:54 Jul 19 2021 FSCK0636.REC
3285 -rwx 0 21:53:54 Jul 19 2021 FSCK0637.REC
3286 -rwx 0 21:53:54 Jul 19 2021 FSCK0638.REC
3287 -rwx 0 21:53:54 Jul 19 2021 FSCK0639.REC
3288 -rwx 0 21:53:54 Jul 19 2021 FSCK0640.REC
3289 -rwx 0 21:53:56 Jul 19 2021 FSCK0641.REC
3290 -rwx 0 21:53:56 Jul 19 2021 FSCK0642.REC
3291 -rwx 0 21:53:56 Jul 19 2021 FSCK0643.REC
3292 -rwx 0 21:53:56 Jul 19 2021 FSCK0644.REC
3293 -rwx 0 21:53:56 Jul 19 2021 FSCK0645.REC
3294 -rwx 0 21:53:56 Jul 19 2021 FSCK0646.REC
3295 -rwx 0 21:53:56 Jul 19 2021 FSCK0647.REC
3296 -rwx 0 21:53:56 Jul 19 2021 FSCK0648.REC
3297 -rwx 0 21:53:56 Jul 19 2021 FSCK0649.REC
3298 -rwx 0 21:53:56 Jul 19 2021 FSCK0650.REC
3299 -rwx 0 21:53:56 Jul 19 2021 FSCK0651.REC
3300 -rwx 0 21:53:56 Jul 19 2021 FSCK0652.REC
3301 -rwx 0 21:53:56 Jul 19 2021 FSCK0653.REC
3302 -rwx 0 21:53:58 Jul 19 2021 FSCK0654.REC
3303 -rwx 0 21:53:58 Jul 19 2021 FSCK0655.REC
3304 -rwx 0 21:53:58 Jul 19 2021 FSCK0656.REC
3305 -rwx 0 21:53:58 Jul 19 2021 FSCK0657.REC
3306 -rwx 0 21:53:58 Jul 19 2021 FSCK0658.REC
3307 -rwx 0 21:53:58 Jul 19 2021 FSCK0659.REC
3308 -rwx 0 21:53:58 Jul 19 2021 FSCK0660.REC
3309 -rwx 0 21:53:58 Jul 19 2021 FSCK0661.REC
3310 -rwx 0 21:53:58 Jul 19 2021 FSCK0662.REC
3311 -rwx 0 21:53:58 Jul 19 2021 FSCK0663.REC
3312 -rwx 0 21:53:58 Jul 19 2021 FSCK0664.REC
3313 -rwx 0 21:53:58 Jul 19 2021 FSCK0665.REC
3314 -rwx 0 21:54:00 Jul 19 2021 FSCK0666.REC
3315 -rwx 0 21:54:00 Jul 19 2021 FSCK0667.REC
3316 -rwx 0 21:54:00 Jul 19 2021 FSCK0668.REC
3317 -rwx 0 21:54:00 Jul 19 2021 FSCK0669.REC
3318 -rwx 0 21:54:00 Jul 19 2021 FSCK0670.REC
3319 -rwx 0 21:54:00 Jul 19 2021 FSCK0671.REC
3320 -rwx 0 21:54:00 Jul 19 2021 FSCK0672.REC
3321 -rwx 0 21:54:00 Jul 19 2021 FSCK0673.REC
3322 -rwx 0 21:54:00 Jul 19 2021 FSCK0674.REC
3323 -rwx 0 21:54:00 Jul 19 2021 FSCK0675.REC
3324 -rwx 0 21:54:00 Jul 19 2021 FSCK0676.REC
3325 -rwx 0 21:54:00 Jul 19 2021 FSCK0677.REC
3326 -rwx 0 21:54:02 Jul 19 2021 FSCK0678.REC
3327 -rwx 0 21:54:02 Jul 19 2021 FSCK0679.REC
3328 -rwx 0 21:54:02 Jul 19 2021 FSCK0680.REC
3329 -rwx 0 21:54:02 Jul 19 2021 FSCK0681.REC
3330 -rwx 0 21:54:02 Jul 19 2021 FSCK0682.REC
3331 -rwx 0 21:54:02 Jul 19 2021 FSCK0683.REC
3332 -rwx 0 21:54:02 Jul 19 2021 FSCK0684.REC
3333 -rwx 0 21:54:02 Jul 19 2021 FSCK0685.REC
3334 -rwx 0 21:54:02 Jul 19 2021 FSCK0686.REC
3335 -rwx 0 21:54:02 Jul 19 2021 FSCK0687.REC
3336 -rwx 0 21:54:02 Jul 19 2021 FSCK0688.REC
3337 -rwx 0 21:54:02 Jul 19 2021 FSCK0689.REC
3338 -rwx 0 21:54:02 Jul 19 2021 FSCK0690.REC
3339 -rwx 0 21:54:04 Jul 19 2021 FSCK0691.REC
3340 -rwx 0 21:54:04 Jul 19 2021 FSCK0692.REC
3341 -rwx 0 21:54:04 Jul 19 2021 FSCK0693.REC
3342 -rwx 0 21:54:04 Jul 19 2021 FSCK0694.REC
3343 -rwx 0 21:54:04 Jul 19 2021 FSCK0695.REC
3344 -rwx 0 21:54:04 Jul 19 2021 FSCK0696.REC
3345 -rwx 0 21:54:04 Jul 19 2021 FSCK0697.REC
3346 -rwx 0 21:54:04 Jul 19 2021 FSCK0698.REC
3347 -rwx 0 21:54:04 Jul 19 2021 FSCK0699.REC
3348 -rwx 0 21:54:04 Jul 19 2021 FSCK0700.REC
3349 -rwx 0 21:54:04 Jul 19 2021 FSCK0701.REC
3350 -rwx 0 21:54:04 Jul 19 2021 FSCK0702.REC
3351 -rwx 0 21:54:06 Jul 19 2021 FSCK0703.REC
3352 -rwx 0 21:54:06 Jul 19 2021 FSCK0704.REC
3353 -rwx 0 21:54:06 Jul 19 2021 FSCK0705.REC
3354 -rwx 0 21:54:06 Jul 19 2021 FSCK0706.REC
3355 -rwx 0 21:54:06 Jul 19 2021 FSCK0707.REC
3356 -rwx 0 21:54:06 Jul 19 2021 FSCK0708.REC
3357 -rwx 0 21:54:06 Jul 19 2021 FSCK0709.REC
3358 -rwx 0 21:54:06 Jul 19 2021 FSCK0710.REC
3359 -rwx 0 21:54:06 Jul 19 2021 FSCK0711.REC
3360 -rwx 0 21:54:06 Jul 19 2021 FSCK0712.REC
3361 -rwx 0 21:54:06 Jul 19 2021 FSCK0713.REC
3362 -rwx 0 21:54:08 Jul 19 2021 FSCK0714.REC
3363 -rwx 0 21:54:08 Jul 19 2021 FSCK0715.REC
3364 -rwx 0 21:54:08 Jul 19 2021 FSCK0716.REC
3365 -rwx 0 21:54:08 Jul 19 2021 FSCK0717.REC
3366 -rwx 0 21:54:08 Jul 19 2021 FSCK0718.REC
3367 -rwx 0 21:54:08 Jul 19 2021 FSCK0719.REC
3368 -rwx 0 21:54:08 Jul 19 2021 FSCK0720.REC
3369 -rwx 0 21:54:08 Jul 19 2021 FSCK0721.REC
3370 -rwx 0 21:54:08 Jul 19 2021 FSCK0722.REC
3371 -rwx 0 21:54:08 Jul 19 2021 FSCK0723.REC
3372 -rwx 0 21:54:08 Jul 19 2021 FSCK0724.REC
3373 -rwx 0 21:54:08 Jul 19 2021 FSCK0725.REC
3374 -rwx 0 21:54:10 Jul 19 2021 FSCK0726.REC
3375 -rwx 0 21:54:10 Jul 19 2021 FSCK0727.REC
3376 -rwx 0 21:54:10 Jul 19 2021 FSCK0728.REC
3377 -rwx 0 21:54:10 Jul 19 2021 FSCK0729.REC
3378 -rwx 0 21:54:10 Jul 19 2021 FSCK0730.REC
3379 -rwx 0 21:54:10 Jul 19 2021 FSCK0731.REC
3380 -rwx 0 21:54:10 Jul 19 2021 FSCK0732.REC
3381 -rwx 0 21:54:10 Jul 19 2021 FSCK0733.REC
3382 -rwx 0 21:54:10 Jul 19 2021 FSCK0734.REC
3383 -rwx 0 21:54:10 Jul 19 2021 FSCK0735.REC
3384 -rwx 0 21:54:10 Jul 19 2021 FSCK0736.REC
3385 -rwx 0 21:54:10 Jul 19 2021 FSCK0737.REC
3386 -rwx 0 21:54:12 Jul 19 2021 FSCK0738.REC
3387 -rwx 0 21:54:12 Jul 19 2021 FSCK0739.REC
3388 -rwx 0 21:54:12 Jul 19 2021 FSCK0740.REC
3389 -rwx 0 21:54:12 Jul 19 2021 FSCK0741.REC
3390 -rwx 0 21:54:12 Jul 19 2021 FSCK0742.REC
3391 -rwx 0 21:54:12 Jul 19 2021 FSCK0743.REC
3392 -rwx 0 21:54:12 Jul 19 2021 FSCK0744.REC
3393 -rwx 0 21:54:12 Jul 19 2021 FSCK0745.REC
3394 -rwx 0 21:54:12 Jul 19 2021 FSCK0746.REC
3395 -rwx 0 21:54:12 Jul 19 2021 FSCK0747.REC
3396 -rwx 0 21:54:12 Jul 19 2021 FSCK0748.REC
3397 -rwx 0 21:54:14 Jul 19 2021 FSCK0749.REC
3398 -rwx 0 21:54:14 Jul 19 2021 FSCK0750.REC
3399 -rwx 0 21:54:14 Jul 19 2021 FSCK0751.REC
3400 -rwx 0 21:54:14 Jul 19 2021 FSCK0752.REC
3401 -rwx 0 21:54:14 Jul 19 2021 FSCK0753.REC
3402 -rwx 0 21:54:14 Jul 19 2021 FSCK0754.REC
3403 -rwx 0 21:54:14 Jul 19 2021 FSCK0755.REC
3404 -rwx 0 21:54:14 Jul 19 2021 FSCK0756.REC
3405 -rwx 0 21:54:14 Jul 19 2021 FSCK0757.REC
3406 -rwx 0 21:54:14 Jul 19 2021 FSCK0758.REC
3407 -rwx 0 21:54:16 Jul 19 2021 FSCK0759.REC
3408 -rwx 0 21:54:16 Jul 19 2021 FSCK0760.REC
3409 -rwx 0 21:54:16 Jul 19 2021 FSCK0761.REC
3410 -rwx 0 21:54:16 Jul 19 2021 FSCK0762.REC
3411 -rwx 0 21:54:16 Jul 19 2021 FSCK0763.REC
3412 -rwx 0 21:54:16 Jul 19 2021 FSCK0764.REC
3413 -rwx 0 21:54:16 Jul 19 2021 FSCK0765.REC
3414 -rwx 0 21:54:16 Jul 19 2021 FSCK0766.REC
3415 -rwx 0 21:54:16 Jul 19 2021 FSCK0767.REC
3416 -rwx 0 21:54:16 Jul 19 2021 FSCK0768.REC
3417 -rwx 0 21:54:18 Jul 19 2021 FSCK0769.REC
3418 -rwx 0 21:54:18 Jul 19 2021 FSCK0770.REC
3419 -rwx 0 21:54:18 Jul 19 2021 FSCK0771.REC
3420 -rwx 0 21:54:18 Jul 19 2021 FSCK0772.REC
3421 -rwx 0 21:54:18 Jul 19 2021 FSCK0773.REC
3422 -rwx 0 21:54:18 Jul 19 2021 FSCK0774.REC
3423 -rwx 0 21:54:18 Jul 19 2021 FSCK0775.REC
3424 -rwx 0 21:54:18 Jul 19 2021 FSCK0776.REC
3425 -rwx 0 21:54:18 Jul 19 2021 FSCK0777.REC
3426 -rwx 0 21:54:18 Jul 19 2021 FSCK0778.REC
3427 -rwx 0 21:54:20 Jul 19 2021 FSCK0779.REC
3428 -rwx 0 21:54:20 Jul 19 2021 FSCK0780.REC
3429 -rwx 0 21:54:20 Jul 19 2021 FSCK0781.REC
3430 -rwx 0 21:54:20 Jul 19 2021 FSCK0782.REC
3431 -rwx 0 21:54:20 Jul 19 2021 FSCK0783.REC
3432 -rwx 0 21:54:20 Jul 19 2021 FSCK0784.REC
3433 -rwx 0 21:54:20 Jul 19 2021 FSCK0785.REC
3434 -rwx 0 21:54:20 Jul 19 2021 FSCK0786.REC
3435 -rwx 0 21:54:20 Jul 19 2021 FSCK0787.REC
3436 -rwx 0 21:54:20 Jul 19 2021 FSCK0788.REC
3437 -rwx 0 21:54:22 Jul 19 2021 FSCK0789.REC
3438 -rwx 0 21:54:22 Jul 19 2021 FSCK0790.REC
3439 -rwx 0 21:54:22 Jul 19 2021 FSCK0791.REC
3440 -rwx 0 21:54:22 Jul 19 2021 FSCK0792.REC
3441 -rwx 0 21:54:22 Jul 19 2021 FSCK0793.REC
3442 -rwx 0 21:54:22 Jul 19 2021 FSCK0794.REC
3443 -rwx 0 21:54:22 Jul 19 2021 FSCK0795.REC
3444 -rwx 0 21:54:22 Jul 19 2021 FSCK0796.REC
3445 -rwx 0 21:54:22 Jul 19 2021 FSCK0797.REC
3446 -rwx 0 21:54:22 Jul 19 2021 FSCK0798.REC
3447 -rwx 0 21:54:24 Jul 19 2021 FSCK0799.REC
3448 -rwx 0 21:54:24 Jul 19 2021 FSCK0800.REC
3449 -rwx 0 21:54:24 Jul 19 2021 FSCK0801.REC
3450 -rwx 0 21:54:24 Jul 19 2021 FSCK0802.REC
3451 -rwx 0 21:54:24 Jul 19 2021 FSCK0803.REC
3452 -rwx 0 21:54:24 Jul 19 2021 FSCK0804.REC
3453 -rwx 0 21:54:24 Jul 19 2021 FSCK0805.REC
3454 -rwx 0 21:54:24 Jul 19 2021 FSCK0806.REC
3455 -rwx 0 21:54:24 Jul 19 2021 FSCK0807.REC
3456 -rwx 0 21:54:24 Jul 19 2021 FSCK0808.REC
3457 -rwx 0 21:54:26 Jul 19 2021 FSCK0809.REC
3458 -rwx 0 21:54:26 Jul 19 2021 FSCK0810.REC
3459 -rwx 0 21:54:26 Jul 19 2021 FSCK0811.REC
3460 -rwx 0 21:54:26 Jul 19 2021 FSCK0812.REC
3461 -rwx 0 21:54:26 Jul 19 2021 FSCK0813.REC
3462 -rwx 0 21:54:26 Jul 19 2021 FSCK0814.REC
3463 -rwx 0 21:54:26 Jul 19 2021 FSCK0815.REC
3464 -rwx 0 21:54:26 Jul 19 2021 FSCK0816.REC
3465 -rwx 0 21:54:26 Jul 19 2021 FSCK0817.REC
3466 -rwx 0 21:54:26 Jul 19 2021 FSCK0818.REC
3467 -rwx 0 21:54:28 Jul 19 2021 FSCK0819.REC
3468 -rwx 0 21:54:28 Jul 19 2021 FSCK0820.REC
3469 -rwx 0 21:54:28 Jul 19 2021 FSCK0821.REC
3470 -rwx 0 21:54:28 Jul 19 2021 FSCK0822.REC
3471 -rwx 0 21:54:28 Jul 19 2021 FSCK0823.REC
3472 -rwx 0 21:54:28 Jul 19 2021 FSCK0824.REC
3473 -rwx 0 21:54:28 Jul 19 2021 FSCK0825.REC
3474 -rwx 0 21:54:28 Jul 19 2021 FSCK0826.REC
3475 -rwx 0 21:54:28 Jul 19 2021 FSCK0827.REC
3476 -rwx 0 21:54:28 Jul 19 2021 FSCK0828.REC
3477 -rwx 0 21:54:30 Jul 19 2021 FSCK0829.REC
3478 -rwx 0 21:54:30 Jul 19 2021 FSCK0830.REC
3479 -rwx 0 21:54:30 Jul 19 2021 FSCK0831.REC
3480 -rwx 0 21:54:30 Jul 19 2021 FSCK0832.REC
3481 -rwx 0 21:54:30 Jul 19 2021 FSCK0833.REC
3482 -rwx 0 21:54:30 Jul 19 2021 FSCK0834.REC
3483 -rwx 0 21:54:30 Jul 19 2021 FSCK0835.REC
3484 -rwx 0 21:54:30 Jul 19 2021 FSCK0836.REC
3485 -rwx 0 21:54:30 Jul 19 2021 FSCK0837.REC
3486 -rwx 0 21:54:32 Jul 19 2021 FSCK0838.REC
3487 -rwx 0 21:54:32 Jul 19 2021 FSCK0839.REC
3488 -rwx 0 21:54:32 Jul 19 2021 FSCK0840.REC
3489 -rwx 0 21:54:32 Jul 19 2021 FSCK0841.REC
3490 -rwx 0 21:54:32 Jul 19 2021 FSCK0842.REC
3491 -rwx 0 21:54:32 Jul 19 2021 FSCK0843.REC
3492 -rwx 0 21:54:32 Jul 19 2021 FSCK0844.REC
3493 -rwx 0 21:54:32 Jul 19 2021 FSCK0845.REC
3494 -rwx 0 21:54:32 Jul 19 2021 FSCK0846.REC
3495 -rwx 0 21:54:32 Jul 19 2021 FSCK0847.REC
3496 -rwx 0 21:54:34 Jul 19 2021 FSCK0848.REC
3497 -rwx 0 21:54:34 Jul 19 2021 FSCK0849.REC
3498 -rwx 0 21:54:34 Jul 19 2021 FSCK0850.REC
3499 -rwx 0 21:54:34 Jul 19 2021 FSCK0851.REC
3500 -rwx 0 21:54:34 Jul 19 2021 FSCK0852.REC
3501 -rwx 0 21:54:34 Jul 19 2021 FSCK0853.REC
3502 -rwx 0 21:54:34 Jul 19 2021 FSCK0854.REC
3503 -rwx 0 21:54:34 Jul 19 2021 FSCK0855.REC
3504 -rwx 0 21:54:34 Jul 19 2021 FSCK0856.REC
3505 -rwx 0 21:54:36 Jul 19 2021 FSCK0857.REC
3506 -rwx 0 21:54:36 Jul 19 2021 FSCK0858.REC
3507 -rwx 0 21:54:36 Jul 19 2021 FSCK0859.REC
3508 -rwx 0 21:54:36 Jul 19 2021 FSCK0860.REC
3509 -rwx 0 21:54:36 Jul 19 2021 FSCK0861.REC
3510 -rwx 0 21:54:36 Jul 19 2021 FSCK0862.REC
3511 -rwx 0 21:54:36 Jul 19 2021 FSCK0863.REC
3512 -rwx 0 21:54:36 Jul 19 2021 FSCK0864.REC
3513 -rwx 0 21:54:36 Jul 19 2021 FSCK0865.REC
3514 -rwx 0 21:54:36 Jul 19 2021 FSCK0866.REC
3515 -rwx 0 21:54:38 Jul 19 2021 FSCK0867.REC
3516 -rwx 0 21:54:38 Jul 19 2021 FSCK0868.REC
3517 -rwx 0 21:54:38 Jul 19 2021 FSCK0869.REC
3518 -rwx 0 21:54:38 Jul 19 2021 FSCK0870.REC
3519 -rwx 0 21:54:38 Jul 19 2021 FSCK0871.REC
3520 -rwx 0 21:54:38 Jul 19 2021 FSCK0872.REC
3521 -rwx 0 21:54:38 Jul 19 2021 FSCK0873.REC
3522 -rwx 0 21:54:38 Jul 19 2021 FSCK0874.REC
3523 -rwx 0 21:54:38 Jul 19 2021 FSCK0875.REC
3524 -rwx 0 21:54:40 Jul 19 2021 FSCK0876.REC
3525 -rwx 0 21:54:40 Jul 19 2021 FSCK0877.REC
3526 -rwx 0 21:54:40 Jul 19 2021 FSCK0878.REC
3527 -rwx 0 21:54:40 Jul 19 2021 FSCK0879.REC
3528 -rwx 0 21:54:40 Jul 19 2021 FSCK0880.REC
3529 -rwx 0 21:54:40 Jul 19 2021 FSCK0881.REC
3530 -rwx 0 21:54:40 Jul 19 2021 FSCK0882.REC
3531 -rwx 0 21:54:40 Jul 19 2021 FSCK0883.REC
3532 -rwx 0 21:54:42 Jul 19 2021 FSCK0884.REC
3533 -rwx 0 21:54:42 Jul 19 2021 FSCK0885.REC
3534 -rwx 0 21:54:42 Jul 19 2021 FSCK0886.REC
3535 -rwx 0 21:54:42 Jul 19 2021 FSCK0887.REC
3536 -rwx 0 21:54:42 Jul 19 2021 FSCK0888.REC
3537 -rwx 0 21:54:42 Jul 19 2021 FSCK0889.REC
3538 -rwx 0 21:54:42 Jul 19 2021 FSCK0890.REC
3539 -rwx 0 21:54:42 Jul 19 2021 FSCK0891.REC
3540 -rwx 0 21:54:42 Jul 19 2021 FSCK0892.REC
3541 -rwx 0 21:54:44 Jul 19 2021 FSCK0893.REC
3542 -rwx 0 21:54:44 Jul 19 2021 FSCK0894.REC
3543 -rwx 0 21:54:44 Jul 19 2021 FSCK0895.REC
3544 -rwx 0 21:54:44 Jul 19 2021 FSCK0896.REC
3545 -rwx 0 21:54:44 Jul 19 2021 FSCK0897.REC
3546 -rwx 0 21:54:44 Jul 19 2021 FSCK0898.REC
3547 -rwx 0 21:54:44 Jul 19 2021 FSCK0899.REC
3548 -rwx 0 21:54:44 Jul 19 2021 FSCK0900.REC
3549 -rwx 0 21:54:46 Jul 19 2021 FSCK0901.REC
3550 -rwx 0 21:54:46 Jul 19 2021 FSCK0902.REC
3551 -rwx 0 21:54:46 Jul 19 2021 FSCK0903.REC
3552 -rwx 0 21:54:46 Jul 19 2021 FSCK0904.REC
3553 -rwx 0 21:54:46 Jul 19 2021 FSCK0905.REC
3554 -rwx 0 21:54:46 Jul 19 2021 FSCK0906.REC
3555 -rwx 0 21:54:46 Jul 19 2021 FSCK0907.REC
3556 -rwx 0 21:54:46 Jul 19 2021 FSCK0908.REC
3557 -rwx 0 21:54:46 Jul 19 2021 FSCK0909.REC
3558 -rwx 0 21:54:48 Jul 19 2021 FSCK0910.REC
3559 -rwx 0 21:54:48 Jul 19 2021 FSCK0911.REC
3560 -rwx 0 21:54:48 Jul 19 2021 FSCK0912.REC
3561 -rwx 0 21:54:48 Jul 19 2021 FSCK0913.REC
3562 -rwx 0 21:54:48 Jul 19 2021 FSCK0914.REC
3563 -rwx 0 21:54:48 Jul 19 2021 FSCK0915.REC
3564 -rwx 0 21:54:48 Jul 19 2021 FSCK0916.REC
3565 -rwx 0 21:54:48 Jul 19 2021 FSCK0917.REC
3566 -rwx 0 21:54:50 Jul 19 2021 FSCK0918.REC
3567 -rwx 0 21:54:50 Jul 19 2021 FSCK0919.REC
3568 -rwx 0 21:54:50 Jul 19 2021 FSCK0920.REC
3569 -rwx 0 21:54:50 Jul 19 2021 FSCK0921.REC
3570 -rwx 0 21:54:50 Jul 19 2021 FSCK0922.REC
3571 -rwx 0 21:54:50 Jul 19 2021 FSCK0923.REC
3572 -rwx 0 21:54:50 Jul 19 2021 FSCK0924.REC
3573 -rwx 0 21:54:50 Jul 19 2021 FSCK0925.REC
3574 -rwx 0 21:54:52 Jul 19 2021 FSCK0926.REC
3575 -rwx 0 21:54:52 Jul 19 2021 FSCK0927.REC
3576 -rwx 0 21:54:52 Jul 19 2021 FSCK0928.REC
3577 -rwx 0 21:54:52 Jul 19 2021 FSCK0929.REC
3578 -rwx 0 21:54:52 Jul 19 2021 FSCK0930.REC
3579 -rwx 0 21:54:52 Jul 19 2021 FSCK0931.REC
3580 -rwx 0 21:54:52 Jul 19 2021 FSCK0932.REC
3581 -rwx 0 21:54:52 Jul 19 2021 FSCK0933.REC
3582 -rwx 0 21:54:52 Jul 19 2021 FSCK0934.REC
3583 -rwx 0 21:54:54 Jul 19 2021 FSCK0935.REC
3584 -rwx 0 21:54:54 Jul 19 2021 FSCK0936.REC
3585 -rwx 0 21:54:54 Jul 19 2021 FSCK0937.REC
3586 -rwx 0 21:54:54 Jul 19 2021 FSCK0938.REC
3587 -rwx 0 21:54:54 Jul 19 2021 FSCK0939.REC
3588 -rwx 0 21:54:54 Jul 19 2021 FSCK0940.REC
3589 -rwx 0 21:54:54 Jul 19 2021 FSCK0941.REC
3590 -rwx 0 21:54:54 Jul 19 2021 FSCK0942.REC
3591 -rwx 0 21:54:56 Jul 19 2021 FSCK0943.REC
3592 -rwx 0 21:54:56 Jul 19 2021 FSCK0944.REC
3593 -rwx 0 21:54:56 Jul 19 2021 FSCK0945.REC
3594 -rwx 0 21:54:56 Jul 19 2021 FSCK0946.REC
3595 -rwx 0 21:54:56 Jul 19 2021 FSCK0947.REC
3596 -rwx 0 21:54:56 Jul 19 2021 FSCK0948.REC
3597 -rwx 0 21:54:56 Jul 19 2021 FSCK0949.REC
3598 -rwx 0 21:54:56 Jul 19 2021 FSCK0950.REC
3599 -rwx 0 21:54:58 Jul 19 2021 FSCK0951.REC
3600 -rwx 0 21:54:58 Jul 19 2021 FSCK0952.REC
3601 -rwx 0 21:54:58 Jul 19 2021 FSCK0953.REC
3602 -rwx 0 21:54:58 Jul 19 2021 FSCK0954.REC
3603 -rwx 0 21:54:58 Jul 19 2021 FSCK0955.REC
3604 -rwx 0 21:54:58 Jul 19 2021 FSCK0956.REC
3605 -rwx 0 21:54:58 Jul 19 2021 FSCK0957.REC
3606 -rwx 0 21:54:58 Jul 19 2021 FSCK0958.REC
3607 -rwx 0 21:55:00 Jul 19 2021 FSCK0959.REC
3608 -rwx 0 21:55:00 Jul 19 2021 FSCK0960.REC
3609 -rwx 0 21:55:00 Jul 19 2021 FSCK0961.REC
3610 -rwx 0 21:55:00 Jul 19 2021 FSCK0962.REC
3611 -rwx 0 21:55:00 Jul 19 2021 FSCK0963.REC
3612 -rwx 0 21:55:00 Jul 19 2021 FSCK0964.REC
3613 -rwx 0 21:55:00 Jul 19 2021 FSCK0965.REC
3614 -rwx 0 21:55:00 Jul 19 2021 FSCK0966.REC
3615 -rwx 0 21:55:02 Jul 19 2021 FSCK0967.REC
3616 -rwx 0 21:55:02 Jul 19 2021 FSCK0968.REC
3617 -rwx 0 21:55:02 Jul 19 2021 FSCK0969.REC
3618 -rwx 0 21:55:02 Jul 19 2021 FSCK0970.REC
3619 -rwx 0 21:55:02 Jul 19 2021 FSCK0971.REC
3620 -rwx 0 21:55:02 Jul 19 2021 FSCK0972.REC
3621 -rwx 0 21:55:02 Jul 19 2021 FSCK0973.REC
3622 -rwx 0 21:55:02 Jul 19 2021 FSCK0974.REC
3623 -rwx 0 21:55:04 Jul 19 2021 FSCK0975.REC
3624 -rwx 0 21:55:04 Jul 19 2021 FSCK0976.REC
3625 -rwx 0 21:55:04 Jul 19 2021 FSCK0977.REC
3626 -rwx 0 21:55:04 Jul 19 2021 FSCK0978.REC
3627 -rwx 0 21:55:04 Jul 19 2021 FSCK0979.REC
3628 -rwx 0 21:55:04 Jul 19 2021 FSCK0980.REC
3629 -rwx 0 21:55:04 Jul 19 2021 FSCK0981.REC
3630 -rwx 0 21:55:04 Jul 19 2021 FSCK0982.REC
3631 -rwx 0 21:55:06 Jul 19 2021 FSCK0983.REC
3632 -rwx 0 21:55:06 Jul 19 2021 FSCK0984.REC
3633 -rwx 0 21:55:06 Jul 19 2021 FSCK0985.REC
3634 -rwx 0 21:55:06 Jul 19 2021 FSCK0986.REC
3635 -rwx 0 21:55:06 Jul 19 2021 FSCK0987.REC
3636 -rwx 0 21:55:06 Jul 19 2021 FSCK0988.REC
3637 -rwx 0 21:55:06 Jul 19 2021 FSCK0989.REC
3638 -rwx 0 21:55:08 Jul 19 2021 FSCK0990.REC
3639 -rwx 0 21:55:08 Jul 19 2021 FSCK0991.REC
3640 -rwx 0 21:55:08 Jul 19 2021 FSCK0992.REC
3641 -rwx 0 21:55:08 Jul 19 2021 FSCK0993.REC
3642 -rwx 0 21:55:08 Jul 19 2021 FSCK0994.REC
3643 -rwx 0 21:55:08 Jul 19 2021 FSCK0995.REC
3644 -rwx 0 21:55:08 Jul 19 2021 FSCK0996.REC
3645 -rwx 0 21:55:08 Jul 19 2021 FSCK0997.REC
3646 -rwx 0 21:55:10 Jul 19 2021 FSCK0998.REC
3647 -rwx 0 21:55:10 Jul 19 2021 FSCK0999.REC
3648 -rwx 0 21:55:10 Jul 19 2021 FSCK1000.REC
3649 -rwx 0 21:55:10 Jul 19 2021 FSCK1001.REC
3650 -rwx 0 21:55:10 Jul 19 2021 FSCK1002.REC
3651 -rwx 0 21:55:10 Jul 19 2021 FSCK1003.REC
3652 -rwx 0 21:55:10 Jul 19 2021 FSCK1004.REC
3653 -rwx 0 21:55:10 Jul 19 2021 FSCK1005.REC
3654 -rwx 0 21:55:12 Jul 19 2021 FSCK1006.REC
3655 -rwx 0 21:55:12 Jul 19 2021 FSCK1007.REC
3656 -rwx 0 21:55:12 Jul 19 2021 FSCK1008.REC
3657 -rwx 0 21:55:12 Jul 19 2021 FSCK1009.REC
3658 -rwx 0 21:55:12 Jul 19 2021 FSCK1010.REC
3659 -rwx 0 21:55:12 Jul 19 2021 FSCK1011.REC
4102 -rwx 0 21:55:12 Jul 19 2021 FSCK1012.REC
4103 -rwx 0 21:55:14 Jul 19 2021 FSCK1013.REC
4104 -rwx 0 21:55:14 Jul 19 2021 FSCK1014.REC
4105 -rwx 0 21:55:14 Jul 19 2021 FSCK1015.REC
4106 -rwx 0 21:55:14 Jul 19 2021 FSCK1016.REC
4107 -rwx 0 21:55:14 Jul 19 2021 FSCK1017.REC
4108 -rwx 0 21:55:14 Jul 19 2021 FSCK1018.REC
4109 -rwx 0 21:55:14 Jul 19 2021 FSCK1019.REC
4110 -rwx 0 21:55:16 Jul 19 2021 FSCK1020.REC
4111 -rwx 0 21:55:16 Jul 19 2021 FSCK1021.REC
4112 -rwx 0 21:55:16 Jul 19 2021 FSCK1022.REC
4113 -rwx 0 21:55:16 Jul 19 2021 FSCK1023.REC
4114 -rwx 0 21:55:16 Jul 19 2021 FSCK1024.REC
4115 -rwx 0 21:55:16 Jul 19 2021 FSCK1025.REC
4116 -rwx 0 21:55:16 Jul 19 2021 FSCK1026.REC
4117 -rwx 0 21:55:18 Jul 19 2021 FSCK1027.REC
4118 -rwx 0 21:55:18 Jul 19 2021 FSCK1028.REC
4119 -rwx 0 21:55:18 Jul 19 2021 FSCK1029.REC
4120 -rwx 0 21:55:18 Jul 19 2021 FSCK1030.REC
4121 -rwx 0 21:55:18 Jul 19 2021 FSCK1031.REC
4122 -rwx 0 21:55:18 Jul 19 2021 FSCK1032.REC
4123 -rwx 0 21:55:18 Jul 19 2021 FSCK1033.REC
4124 -rwx 0 21:55:20 Jul 19 2021 FSCK1034.REC
4125 -rwx 0 21:55:20 Jul 19 2021 FSCK1035.REC
4126 -rwx 0 21:55:20 Jul 19 2021 FSCK1036.REC
4127 -rwx 0 21:55:20 Jul 19 2021 FSCK1037.REC
4128 -rwx 0 21:55:20 Jul 19 2021 FSCK1038.REC
4129 -rwx 0 21:55:20 Jul 19 2021 FSCK1039.REC
4130 -rwx 0 21:55:20 Jul 19 2021 FSCK1040.REC
4131 -rwx 0 21:55:22 Jul 19 2021 FSCK1041.REC
4132 -rwx 0 21:55:22 Jul 19 2021 FSCK1042.REC
4133 -rwx 0 21:55:22 Jul 19 2021 FSCK1043.REC
4134 -rwx 0 21:55:22 Jul 19 2021 FSCK1044.REC
4135 -rwx 0 21:55:22 Jul 19 2021 FSCK1045.REC
4136 -rwx 0 21:55:22 Jul 19 2021 FSCK1046.REC
4137 -rwx 0 21:55:22 Jul 19 2021 FSCK1047.REC
4138 -rwx 0 21:55:24 Jul 19 2021 FSCK1048.REC
4139 -rwx 0 21:55:24 Jul 19 2021 FSCK1049.REC
4140 -rwx 0 21:55:24 Jul 19 2021 FSCK1050.REC
4141 -rwx 0 21:55:24 Jul 19 2021 FSCK1051.REC
4142 -rwx 0 21:55:24 Jul 19 2021 FSCK1052.REC
4143 -rwx 0 21:55:24 Jul 19 2021 FSCK1053.REC
4144 -rwx 0 21:55:24 Jul 19 2021 FSCK1054.REC
4145 -rwx 0 21:55:26 Jul 19 2021 FSCK1055.REC
4146 -rwx 0 21:55:26 Jul 19 2021 FSCK1056.REC
4147 -rwx 0 21:55:26 Jul 19 2021 FSCK1057.REC
4148 -rwx 0 21:55:26 Jul 19 2021 FSCK1058.REC
4149 -rwx 0 21:55:26 Jul 19 2021 FSCK1059.REC
4150 -rwx 0 21:55:26 Jul 19 2021 FSCK1060.REC
4151 -rwx 0 21:55:26 Jul 19 2021 FSCK1061.REC
4152 -rwx 0 21:55:28 Jul 19 2021 FSCK1062.REC
4153 -rwx 0 21:55:28 Jul 19 2021 FSCK1063.REC
4154 -rwx 0 21:55:28 Jul 19 2021 FSCK1064.REC
4155 -rwx 0 21:55:28 Jul 19 2021 FSCK1065.REC
4156 -rwx 0 21:55:28 Jul 19 2021 FSCK1066.REC
4157 -rwx 0 21:55:28 Jul 19 2021 FSCK1067.REC
4158 -rwx 0 21:55:28 Jul 19 2021 FSCK1068.REC
4159 -rwx 0 21:55:30 Jul 19 2021 FSCK1069.REC
4160 -rwx 0 21:55:30 Jul 19 2021 FSCK1070.REC
4161 -rwx 0 21:55:30 Jul 19 2021 FSCK1071.REC
4162 -rwx 0 21:55:30 Jul 19 2021 FSCK1072.REC
4163 -rwx 0 21:55:30 Jul 19 2021 FSCK1073.REC
4164 -rwx 0 21:55:30 Jul 19 2021 FSCK1074.REC
4165 -rwx 0 21:55:30 Jul 19 2021 FSCK1075.REC
4166 -rwx 0 21:55:32 Jul 19 2021 FSCK1076.REC
4167 -rwx 0 21:55:32 Jul 19 2021 FSCK1077.REC
4168 -rwx 0 21:55:32 Jul 19 2021 FSCK1078.REC
4169 -rwx 0 21:55:32 Jul 19 2021 FSCK1079.REC
4170 -rwx 0 21:55:32 Jul 19 2021 FSCK1080.REC
4171 -rwx 0 21:55:32 Jul 19 2021 FSCK1081.REC
4172 -rwx 0 21:55:32 Jul 19 2021 FSCK1082.REC
4173 -rwx 0 21:55:34 Jul 19 2021 FSCK1083.REC
4174 -rwx 0 21:55:34 Jul 19 2021 FSCK1084.REC
4175 -rwx 0 21:55:34 Jul 19 2021 FSCK1085.REC
4176 -rwx 0 21:55:34 Jul 19 2021 FSCK1086.REC
4177 -rwx 0 21:55:34 Jul 19 2021 FSCK1087.REC
4178 -rwx 0 21:55:34 Jul 19 2021 FSCK1088.REC
4179 -rwx 0 21:55:34 Jul 19 2021 FSCK1089.REC
4180 -rwx 0 21:55:36 Jul 19 2021 FSCK1090.REC
4181 -rwx 0 21:55:36 Jul 19 2021 FSCK1091.REC
4182 -rwx 0 21:55:36 Jul 19 2021 FSCK1092.REC
4183 -rwx 0 21:55:36 Jul 19 2021 FSCK1093.REC
4184 -rwx 0 21:55:36 Jul 19 2021 FSCK1094.REC
4185 -rwx 0 21:55:36 Jul 19 2021 FSCK1095.REC
4186 -rwx 0 21:55:38 Jul 19 2021 FSCK1096.REC
4187 -rwx 0 21:55:38 Jul 19 2021 FSCK1097.REC
4188 -rwx 0 21:55:38 Jul 19 2021 FSCK1098.REC
4189 -rwx 0 21:55:38 Jul 19 2021 FSCK1099.REC
4190 -rwx 0 21:55:38 Jul 19 2021 FSCK1100.REC
4191 -rwx 0 21:55:38 Jul 19 2021 FSCK1101.REC
4192 -rwx 0 21:55:38 Jul 19 2021 FSCK1102.REC
4193 -rwx 0 21:55:40 Jul 19 2021 FSCK1103.REC
4194 -rwx 0 21:55:40 Jul 19 2021 FSCK1104.REC
4195 -rwx 0 21:55:40 Jul 19 2021 FSCK1105.REC
4196 -rwx 0 21:55:40 Jul 19 2021 FSCK1106.REC
4197 -rwx 0 21:55:40 Jul 19 2021 FSCK1107.REC
4198 -rwx 0 21:55:40 Jul 19 2021 FSCK1108.REC
4199 -rwx 0 21:55:40 Jul 19 2021 FSCK1109.REC
4200 -rwx 0 21:55:42 Jul 19 2021 FSCK1110.REC
4201 -rwx 0 21:55:42 Jul 19 2021 FSCK1111.REC
4202 -rwx 0 21:55:42 Jul 19 2021 FSCK1112.REC
4203 -rwx 0 21:55:42 Jul 19 2021 FSCK1113.REC
4204 -rwx 0 21:55:42 Jul 19 2021 FSCK1114.REC
4205 -rwx 0 21:55:42 Jul 19 2021 FSCK1115.REC
4206 -rwx 0 21:55:44 Jul 19 2021 FSCK1116.REC
4207 -rwx 0 21:55:44 Jul 19 2021 FSCK1117.REC
4208 -rwx 0 21:55:44 Jul 19 2021 FSCK1118.REC
4209 -rwx 0 21:55:44 Jul 19 2021 FSCK1119.REC
4210 -rwx 0 21:55:44 Jul 19 2021 FSCK1120.REC
4211 -rwx 0 21:55:44 Jul 19 2021 FSCK1121.REC
4212 -rwx 0 21:55:44 Jul 19 2021 FSCK1122.REC
4213 -rwx 0 21:55:46 Jul 19 2021 FSCK1123.REC
4214 -rwx 0 21:55:46 Jul 19 2021 FSCK1124.REC
4215 -rwx 0 21:55:46 Jul 19 2021 FSCK1125.REC
4216 -rwx 0 21:55:46 Jul 19 2021 FSCK1126.REC
4217 -rwx 0 21:55:46 Jul 19 2021 FSCK1127.REC
4218 -rwx 0 21:55:46 Jul 19 2021 FSCK1128.REC
4219 -rwx 0 21:55:48 Jul 19 2021 FSCK1129.REC
4220 -rwx 0 21:55:48 Jul 19 2021 FSCK1130.REC
4221 -rwx 0 21:55:48 Jul 19 2021 FSCK1131.REC
4222 -rwx 0 21:55:48 Jul 19 2021 FSCK1132.REC
4223 -rwx 0 21:55:48 Jul 19 2021 FSCK1133.REC
4224 -rwx 0 21:55:48 Jul 19 2021 FSCK1134.REC
4225 -rwx 0 21:55:48 Jul 19 2021 FSCK1135.REC
4226 -rwx 0 21:55:50 Jul 19 2021 FSCK1136.REC
4227 -rwx 0 21:55:50 Jul 19 2021 FSCK1137.REC
4228 -rwx 0 21:55:50 Jul 19 2021 FSCK1138.REC
4229 -rwx 0 21:55:50 Jul 19 2021 FSCK1139.REC
4230 -rwx 0 21:55:50 Jul 19 2021 FSCK1140.REC
4231 -rwx 0 21:55:50 Jul 19 2021 FSCK1141.REC
4232 -rwx 0 21:55:52 Jul 19 2021 FSCK1142.REC
4233 -rwx 0 21:55:52 Jul 19 2021 FSCK1143.REC
4234 -rwx 0 21:55:52 Jul 19 2021 FSCK1144.REC
4235 -rwx 0 21:55:52 Jul 19 2021 FSCK1145.REC
4236 -rwx 0 21:55:52 Jul 19 2021 FSCK1146.REC
4237 -rwx 0 21:55:52 Jul 19 2021 FSCK1147.REC
4238 -rwx 0 21:55:54 Jul 19 2021 FSCK1148.REC
4239 -rwx 0 21:55:54 Jul 19 2021 FSCK1149.REC
4240 -rwx 0 21:55:54 Jul 19 2021 FSCK1150.REC
4241 -rwx 0 21:55:54 Jul 19 2021 FSCK1151.REC
4242 -rwx 0 21:55:54 Jul 19 2021 FSCK1152.REC
4243 -rwx 0 21:55:54 Jul 19 2021 FSCK1153.REC
4244 -rwx 0 21:55:56 Jul 19 2021 FSCK1154.REC
4245 -rwx 0 21:55:56 Jul 19 2021 FSCK1155.REC
4246 -rwx 0 21:55:56 Jul 19 2021 FSCK1156.REC
4247 -rwx 0 21:55:56 Jul 19 2021 FSCK1157.REC
4248 -rwx 0 21:55:56 Jul 19 2021 FSCK1158.REC
4249 -rwx 0 21:55:56 Jul 19 2021 FSCK1159.REC
4250 -rwx 0 21:55:58 Jul 19 2021 FSCK1160.REC
4251 -rwx 0 21:55:58 Jul 19 2021 FSCK1161.REC
4252 -rwx 0 21:55:58 Jul 19 2021 FSCK1162.REC
4253 -rwx 0 21:55:58 Jul 19 2021 FSCK1163.REC
4254 -rwx 0 21:55:58 Jul 19 2021 FSCK1164.REC
4255 -rwx 0 21:55:58 Jul 19 2021 FSCK1165.REC
4256 -rwx 0 21:56:00 Jul 19 2021 FSCK1166.REC
4257 -rwx 0 21:56:00 Jul 19 2021 FSCK1167.REC
4258 -rwx 0 21:56:00 Jul 19 2021 FSCK1168.REC
4259 -rwx 0 21:56:00 Jul 19 2021 FSCK1169.REC
4260 -rwx 0 21:56:00 Jul 19 2021 FSCK1170.REC
4261 -rwx 0 21:56:00 Jul 19 2021 FSCK1171.REC
4262 -rwx 0 21:56:02 Jul 19 2021 FSCK1172.REC
4263 -rwx 0 21:56:02 Jul 19 2021 FSCK1173.REC
4264 -rwx 0 21:56:02 Jul 19 2021 FSCK1174.REC
4265 -rwx 0 21:56:02 Jul 19 2021 FSCK1175.REC
4266 -rwx 0 21:56:02 Jul 19 2021 FSCK1176.REC
4267 -rwx 0 21:56:02 Jul 19 2021 FSCK1177.REC
4268 -rwx 0 21:56:04 Jul 19 2021 FSCK1178.REC
4269 -rwx 0 21:56:04 Jul 19 2021 FSCK1179.REC
4270 -rwx 0 21:56:04 Jul 19 2021 FSCK1180.REC
4271 -rwx 0 21:56:04 Jul 19 2021 FSCK1181.REC
4272 -rwx 0 21:56:04 Jul 19 2021 FSCK1182.REC
4273 -rwx 0 21:56:04 Jul 19 2021 FSCK1183.REC
4274 -rwx 0 21:56:06 Jul 19 2021 FSCK1184.REC
4275 -rwx 0 21:56:06 Jul 19 2021 FSCK1185.REC
4276 -rwx 0 21:56:06 Jul 19 2021 FSCK1186.REC
4277 -rwx 0 21:56:06 Jul 19 2021 FSCK1187.REC
4278 -rwx 0 21:56:06 Jul 19 2021 FSCK1188.REC
4279 -rwx 0 21:56:06 Jul 19 2021 FSCK1189.REC
4280 -rwx 0 21:56:08 Jul 19 2021 FSCK1190.REC
4281 -rwx 0 21:56:08 Jul 19 2021 FSCK1191.REC
4282 -rwx 0 21:56:08 Jul 19 2021 FSCK1192.REC
4283 -rwx 0 21:56:08 Jul 19 2021 FSCK1193.REC
4284 -rwx 0 21:56:08 Jul 19 2021 FSCK1194.REC
4285 -rwx 0 21:56:08 Jul 19 2021 FSCK1195.REC
4286 -rwx 0 21:56:10 Jul 19 2021 FSCK1196.REC
4287 -rwx 0 21:56:10 Jul 19 2021 FSCK1197.REC
4288 -rwx 0 21:56:10 Jul 19 2021 FSCK1198.REC
4289 -rwx 0 21:56:10 Jul 19 2021 FSCK1199.REC
4290 -rwx 0 21:56:10 Jul 19 2021 FSCK1200.REC
4291 -rwx 0 21:56:10 Jul 19 2021 FSCK1201.REC
4292 -rwx 0 21:56:12 Jul 19 2021 FSCK1202.REC
4293 -rwx 0 21:56:12 Jul 19 2021 FSCK1203.REC
4294 -rwx 0 21:56:12 Jul 19 2021 FSCK1204.REC
4295 -rwx 0 21:56:12 Jul 19 2021 FSCK1205.REC
4296 -rwx 0 21:56:12 Jul 19 2021 FSCK1206.REC
4297 -rwx 0 21:56:12 Jul 19 2021 FSCK1207.REC
4298 -rwx 0 21:56:14 Jul 19 2021 FSCK1208.REC
4299 -rwx 0 21:56:14 Jul 19 2021 FSCK1209.REC
4300 -rwx 0 21:56:14 Jul 19 2021 FSCK1210.REC
4301 -rwx 0 21:56:14 Jul 19 2021 FSCK1211.REC
4302 -rwx 0 21:56:14 Jul 19 2021 FSCK1212.REC
4303 -rwx 0 21:56:14 Jul 19 2021 FSCK1213.REC
4304 -rwx 0 21:56:16 Jul 19 2021 FSCK1214.REC
4305 -rwx 0 21:56:16 Jul 19 2021 FSCK1215.REC
4306 -rwx 0 21:56:16 Jul 19 2021 FSCK1216.REC
4307 -rwx 0 21:56:16 Jul 19 2021 FSCK1217.REC
4308 -rwx 0 21:56:16 Jul 19 2021 FSCK1218.REC
4309 -rwx 0 21:56:18 Jul 19 2021 FSCK1219.REC
4310 -rwx 0 21:56:18 Jul 19 2021 FSCK1220.REC
4311 -rwx 0 21:56:18 Jul 19 2021 FSCK1221.REC
4312 -rwx 0 21:56:18 Jul 19 2021 FSCK1222.REC
4313 -rwx 0 21:56:18 Jul 19 2021 FSCK1223.REC
4314 -rwx 0 21:56:18 Jul 19 2021 FSCK1224.REC
4315 -rwx 0 21:56:20 Jul 19 2021 FSCK1225.REC
4316 -rwx 0 21:56:20 Jul 19 2021 FSCK1226.REC
4317 -rwx 0 21:56:20 Jul 19 2021 FSCK1227.REC
4318 -rwx 0 21:56:20 Jul 19 2021 FSCK1228.REC
4319 -rwx 0 21:56:20 Jul 19 2021 FSCK1229.REC
4320 -rwx 0 21:56:20 Jul 19 2021 FSCK1230.REC
4321 -rwx 0 21:56:22 Jul 19 2021 FSCK1231.REC
4322 -rwx 0 21:56:22 Jul 19 2021 FSCK1232.REC
4323 -rwx 0 21:56:22 Jul 19 2021 FSCK1233.REC
4324 -rwx 0 21:56:22 Jul 19 2021 FSCK1234.REC
4325 -rwx 0 21:56:22 Jul 19 2021 FSCK1235.REC
4326 -rwx 0 21:56:22 Jul 19 2021 FSCK1236.REC
4327 -rwx 0 21:56:24 Jul 19 2021 FSCK1237.REC
4328 -rwx 0 21:56:24 Jul 19 2021 FSCK1238.REC
4329 -rwx 0 21:56:24 Jul 19 2021 FSCK1239.REC
4330 -rwx 0 21:56:24 Jul 19 2021 FSCK1240.REC
4331 -rwx 0 21:56:24 Jul 19 2021 FSCK1241.REC
4332 -rwx 0 21:56:24 Jul 19 2021 FSCK1242.REC
4333 -rwx 0 21:56:26 Jul 19 2021 FSCK1243.REC
4334 -rwx 0 21:56:26 Jul 19 2021 FSCK1244.REC
4335 -rwx 0 21:56:26 Jul 19 2021 FSCK1245.REC
4336 -rwx 0 21:56:26 Jul 19 2021 FSCK1246.REC
4337 -rwx 0 21:56:26 Jul 19 2021 FSCK1247.REC
4338 -rwx 0 21:56:28 Jul 19 2021 FSCK1248.REC
4339 -rwx 0 21:56:28 Jul 19 2021 FSCK1249.REC
4340 -rwx 0 21:56:28 Jul 19 2021 FSCK1250.REC
4341 -rwx 0 21:56:28 Jul 19 2021 FSCK1251.REC
4342 -rwx 0 21:56:28 Jul 19 2021 FSCK1252.REC
4343 -rwx 0 21:56:28 Jul 19 2021 FSCK1253.REC
4344 -rwx 0 21:56:30 Jul 19 2021 FSCK1254.REC
4345 -rwx 0 21:56:30 Jul 19 2021 FSCK1255.REC
4346 -rwx 0 21:56:30 Jul 19 2021 FSCK1256.REC
4347 -rwx 0 21:56:30 Jul 19 2021 FSCK1257.REC
4348 -rwx 0 21:56:30 Jul 19 2021 FSCK1258.REC
4349 -rwx 0 21:56:32 Jul 19 2021 FSCK1259.REC
4350 -rwx 0 21:56:32 Jul 19 2021 FSCK1260.REC
4351 -rwx 0 21:56:32 Jul 19 2021 FSCK1261.REC
4352 -rwx 0 21:56:32 Jul 19 2021 FSCK1262.REC
4353 -rwx 0 21:56:32 Jul 19 2021 FSCK1263.REC
4354 -rwx 0 21:56:32 Jul 19 2021 FSCK1264.REC
4355 -rwx 0 21:56:34 Jul 19 2021 FSCK1265.REC
4356 -rwx 0 21:56:34 Jul 19 2021 FSCK1266.REC
4357 -rwx 0 21:56:34 Jul 19 2021 FSCK1267.REC
4358 -rwx 0 21:56:34 Jul 19 2021 FSCK1268.REC
4359 -rwx 0 21:56:34 Jul 19 2021 FSCK1269.REC
4360 -rwx 0 21:56:36 Jul 19 2021 FSCK1270.REC
4361 -rwx 0 21:56:36 Jul 19 2021 FSCK1271.REC
4362 -rwx 0 21:56:36 Jul 19 2021 FSCK1272.REC
4363 -rwx 0 21:56:36 Jul 19 2021 FSCK1273.REC
4364 -rwx 0 21:56:36 Jul 19 2021 FSCK1274.REC
4365 -rwx 0 21:56:38 Jul 19 2021 FSCK1275.REC
4366 -rwx 0 21:56:38 Jul 19 2021 FSCK1276.REC
4367 -rwx 0 21:56:38 Jul 19 2021 FSCK1277.REC
4368 -rwx 0 21:56:38 Jul 19 2021 FSCK1278.REC
4369 -rwx 0 21:56:38 Jul 19 2021 FSCK1279.REC
4370 -rwx 0 21:56:38 Jul 19 2021 FSCK1280.REC
4371 -rwx 0 21:56:40 Jul 19 2021 FSCK1281.REC
4372 -rwx 0 21:56:40 Jul 19 2021 FSCK1282.REC
4373 -rwx 0 21:56:40 Jul 19 2021 FSCK1283.REC
4374 -rwx 0 21:56:40 Jul 19 2021 FSCK1284.REC
4375 -rwx 0 21:56:40 Jul 19 2021 FSCK1285.REC
4376 -rwx 0 21:56:42 Jul 19 2021 FSCK1286.REC
4377 -rwx 0 21:56:42 Jul 19 2021 FSCK1287.REC
4378 -rwx 0 21:56:42 Jul 19 2021 FSCK1288.REC
4379 -rwx 0 21:56:42 Jul 19 2021 FSCK1289.REC
4380 -rwx 0 21:56:42 Jul 19 2021 FSCK1290.REC
4381 -rwx 0 21:56:44 Jul 19 2021 FSCK1291.REC
4382 -rwx 0 21:56:44 Jul 19 2021 FSCK1292.REC
4383 -rwx 0 21:56:44 Jul 19 2021 FSCK1293.REC
4384 -rwx 0 21:56:44 Jul 19 2021 FSCK1294.REC
4385 -rwx 0 21:56:44 Jul 19 2021 FSCK1295.REC
4386 -rwx 0 21:56:46 Jul 19 2021 FSCK1296.REC
4387 -rwx 0 21:56:46 Jul 19 2021 FSCK1297.REC
4388 -rwx 0 21:56:46 Jul 19 2021 FSCK1298.REC
4389 -rwx 0 21:56:46 Jul 19 2021 FSCK1299.REC
4390 -rwx 0 21:56:46 Jul 19 2021 FSCK1300.REC
4391 -rwx 0 21:56:46 Jul 19 2021 FSCK1301.REC
4392 -rwx 0 21:56:48 Jul 19 2021 FSCK1302.REC
4393 -rwx 0 21:56:48 Jul 19 2021 FSCK1303.REC
4394 -rwx 0 21:56:48 Jul 19 2021 FSCK1304.REC
4395 -rwx 0 21:56:48 Jul 19 2021 FSCK1305.REC
4396 -rwx 0 21:56:48 Jul 19 2021 FSCK1306.REC
4397 -rwx 0 21:56:50 Jul 19 2021 FSCK1307.REC
4398 -rwx 0 21:56:50 Jul 19 2021 FSCK1308.REC
4399 -rwx 0 21:56:50 Jul 19 2021 FSCK1309.REC
4400 -rwx 0 21:56:50 Jul 19 2021 FSCK1310.REC
4401 -rwx 0 21:56:50 Jul 19 2021 FSCK1311.REC
4402 -rwx 0 21:56:52 Jul 19 2021 FSCK1312.REC
4403 -rwx 0 21:56:52 Jul 19 2021 FSCK1313.REC
4404 -rwx 0 21:56:52 Jul 19 2021 FSCK1314.REC
4405 -rwx 0 21:56:52 Jul 19 2021 FSCK1315.REC
4406 -rwx 0 21:56:52 Jul 19 2021 FSCK1316.REC
4407 -rwx 0 21:56:54 Jul 19 2021 FSCK1317.REC
4408 -rwx 0 21:56:54 Jul 19 2021 FSCK1318.REC
4409 -rwx 0 21:56:54 Jul 19 2021 FSCK1319.REC
4410 -rwx 0 21:56:54 Jul 19 2021 FSCK1320.REC
4411 -rwx 0 21:56:54 Jul 19 2021 FSCK1321.REC
4412 -rwx 0 21:56:56 Jul 19 2021 FSCK1322.REC
4413 -rwx 0 21:56:56 Jul 19 2021 FSCK1323.REC
4414 -rwx 0 21:56:56 Jul 19 2021 FSCK1324.REC
4415 -rwx 0 21:56:56 Jul 19 2021 FSCK1325.REC
4416 -rwx 0 21:56:56 Jul 19 2021 FSCK1326.REC
4417 -rwx 0 21:56:58 Jul 19 2021 FSCK1327.REC
4418 -rwx 0 21:56:58 Jul 19 2021 FSCK1328.REC
4419 -rwx 0 21:56:58 Jul 19 2021 FSCK1329.REC
4420 -rwx 0 21:56:58 Jul 19 2021 FSCK1330.REC
4421 -rwx 0 21:56:58 Jul 19 2021 FSCK1331.REC
4422 -rwx 0 21:57:00 Jul 19 2021 FSCK1332.REC
4423 -rwx 0 21:57:00 Jul 19 2021 FSCK1333.REC
4424 -rwx 0 21:57:00 Jul 19 2021 FSCK1334.REC
4425 -rwx 0 21:57:00 Jul 19 2021 FSCK1335.REC
4426 -rwx 0 21:57:00 Jul 19 2021 FSCK1336.REC
4427 -rwx 0 21:57:02 Jul 19 2021 FSCK1337.REC
4428 -rwx 0 21:57:02 Jul 19 2021 FSCK1338.REC
4429 -rwx 0 21:57:02 Jul 19 2021 FSCK1339.REC
4430 -rwx 0 21:57:02 Jul 19 2021 FSCK1340.REC
4431 -rwx 0 21:57:02 Jul 19 2021 FSCK1341.REC
4432 -rwx 0 21:57:04 Jul 19 2021 FSCK1342.REC
4433 -rwx 0 21:57:04 Jul 19 2021 FSCK1343.REC
4434 -rwx 0 21:57:04 Jul 19 2021 FSCK1344.REC
4435 -rwx 0 21:57:04 Jul 19 2021 FSCK1345.REC
4436 -rwx 0 21:57:04 Jul 19 2021 FSCK1346.REC
4437 -rwx 0 21:57:06 Jul 19 2021 FSCK1347.REC
4438 -rwx 0 21:57:06 Jul 19 2021 FSCK1348.REC
4439 -rwx 0 21:57:06 Jul 19 2021 FSCK1349.REC
4440 -rwx 0 21:57:06 Jul 19 2021 FSCK1350.REC
4441 -rwx 0 21:57:06 Jul 19 2021 FSCK1351.REC
4442 -rwx 0 21:57:08 Jul 19 2021 FSCK1352.REC
4443 -rwx 0 21:57:08 Jul 19 2021 FSCK1353.REC
4444 -rwx 0 21:57:08 Jul 19 2021 FSCK1354.REC
4445 -rwx 0 21:57:08 Jul 19 2021 FSCK1355.REC
4446 -rwx 0 21:57:08 Jul 19 2021 FSCK1356.REC
4447 -rwx 0 21:57:10 Jul 19 2021 FSCK1357.REC
4448 -rwx 0 21:57:10 Jul 19 2021 FSCK1358.REC
4449 -rwx 0 21:57:10 Jul 19 2021 FSCK1359.REC
4450 -rwx 0 21:57:10 Jul 19 2021 FSCK1360.REC
4451 -rwx 0 21:57:10 Jul 19 2021 FSCK1361.REC
4452 -rwx 0 21:57:12 Jul 19 2021 FSCK1362.REC
4453 -rwx 0 21:57:12 Jul 19 2021 FSCK1363.REC
4454 -rwx 0 21:57:12 Jul 19 2021 FSCK1364.REC
4455 -rwx 0 21:57:12 Jul 19 2021 FSCK1365.REC
4456 -rwx 0 21:57:12 Jul 19 2021 FSCK1366.REC
4457 -rwx 0 21:57:14 Jul 19 2021 FSCK1367.REC
4458 -rwx 0 21:57:14 Jul 19 2021 FSCK1368.REC
4459 -rwx 0 21:57:14 Jul 19 2021 FSCK1369.REC
4460 -rwx 0 21:57:14 Jul 19 2021 FSCK1370.REC
4461 -rwx 0 21:57:16 Jul 19 2021 FSCK1371.REC
4462 -rwx 0 21:57:16 Jul 19 2021 FSCK1372.REC
4463 -rwx 0 21:57:16 Jul 19 2021 FSCK1373.REC
4464 -rwx 0 21:57:16 Jul 19 2021 FSCK1374.REC
4465 -rwx 0 21:57:16 Jul 19 2021 FSCK1375.REC
4466 -rwx 0 21:57:18 Jul 19 2021 FSCK1376.REC
4467 -rwx 0 21:57:18 Jul 19 2021 FSCK1377.REC
4468 -rwx 0 21:57:18 Jul 19 2021 FSCK1378.REC
4469 -rwx 0 21:57:18 Jul 19 2021 FSCK1379.REC
4470 -rwx 0 21:57:18 Jul 19 2021 FSCK1380.REC
4471 -rwx 0 21:57:20 Jul 19 2021 FSCK1381.REC
4472 -rwx 0 21:57:20 Jul 19 2021 FSCK1382.REC
4473 -rwx 0 21:57:20 Jul 19 2021 FSCK1383.REC
4474 -rwx 0 21:57:20 Jul 19 2021 FSCK1384.REC
4475 -rwx 0 21:57:20 Jul 19 2021 FSCK1385.REC
4476 -rwx 0 21:57:22 Jul 19 2021 FSCK1386.REC
4477 -rwx 0 21:57:22 Jul 19 2021 FSCK1387.REC
4478 -rwx 0 21:57:22 Jul 19 2021 FSCK1388.REC
4479 -rwx 0 21:57:22 Jul 19 2021 FSCK1389.REC
4480 -rwx 0 21:57:22 Jul 19 2021 FSCK1390.REC
4481 -rwx 0 21:57:24 Jul 19 2021 FSCK1391.REC
4482 -rwx 0 21:57:24 Jul 19 2021 FSCK1392.REC
4483 -rwx 0 21:57:24 Jul 19 2021 FSCK1393.REC
4484 -rwx 0 21:57:24 Jul 19 2021 FSCK1394.REC
4485 -rwx 0 21:57:26 Jul 19 2021 FSCK1395.REC
4486 -rwx 0 21:57:26 Jul 19 2021 FSCK1396.REC
4487 -rwx 0 21:57:26 Jul 19 2021 FSCK1397.REC
4488 -rwx 0 21:57:26 Jul 19 2021 FSCK1398.REC
4489 -rwx 0 21:57:26 Jul 19 2021 FSCK1399.REC
4490 -rwx 0 21:57:28 Jul 19 2021 FSCK1400.REC
4491 -rwx 0 21:57:28 Jul 19 2021 FSCK1401.REC
4492 -rwx 0 21:57:28 Jul 19 2021 FSCK1402.REC
4493 -rwx 0 21:57:28 Jul 19 2021 FSCK1403.REC
4494 -rwx 0 21:57:30 Jul 19 2021 FSCK1404.REC
4495 -rwx 0 21:57:30 Jul 19 2021 FSCK1405.REC
4496 -rwx 0 21:57:30 Jul 19 2021 FSCK1406.REC
4497 -rwx 0 21:57:30 Jul 19 2021 FSCK1407.REC
4498 -rwx 0 21:57:30 Jul 19 2021 FSCK1408.REC
4499 -rwx 0 21:57:32 Jul 19 2021 FSCK1409.REC
4500 -rwx 0 21:57:32 Jul 19 2021 FSCK1410.REC
4501 -rwx 0 21:57:32 Jul 19 2021 FSCK1411.REC
4502 -rwx 0 21:57:32 Jul 19 2021 FSCK1412.REC
4503 -rwx 0 21:57:34 Jul 19 2021 FSCK1413.REC
4504 -rwx 0 21:57:34 Jul 19 2021 FSCK1414.REC
4505 -rwx 0 21:57:34 Jul 19 2021 FSCK1415.REC
4506 -rwx 0 21:57:34 Jul 19 2021 FSCK1416.REC
4507 -rwx 0 21:57:34 Jul 19 2021 FSCK1417.REC
4508 -rwx 0 21:57:36 Jul 19 2021 FSCK1418.REC
4509 -rwx 0 21:57:36 Jul 19 2021 FSCK1419.REC
4510 -rwx 0 21:57:36 Jul 19 2021 FSCK1420.REC
4511 -rwx 0 21:57:36 Jul 19 2021 FSCK1421.REC
4512 -rwx 0 21:57:38 Jul 19 2021 FSCK1422.REC
4513 -rwx 0 21:57:38 Jul 19 2021 FSCK1423.REC
4514 -rwx 0 21:57:38 Jul 19 2021 FSCK1424.REC
4515 -rwx 0 21:57:38 Jul 19 2021 FSCK1425.REC
4516 -rwx 0 21:57:38 Jul 19 2021 FSCK1426.REC
4517 -rwx 0 21:57:40 Jul 19 2021 FSCK1427.REC
4518 -rwx 0 21:57:40 Jul 19 2021 FSCK1428.REC
4519 -rwx 0 21:57:40 Jul 19 2021 FSCK1429.REC
4520 -rwx 0 21:57:40 Jul 19 2021 FSCK1430.REC
4521 -rwx 0 21:57:42 Jul 19 2021 FSCK1431.REC
4522 -rwx 0 21:57:42 Jul 19 2021 FSCK1432.REC
4523 -rwx 0 21:57:42 Jul 19 2021 FSCK1433.REC
4524 -rwx 0 21:57:42 Jul 19 2021 FSCK1434.REC
4525 -rwx 0 21:57:42 Jul 19 2021 FSCK1435.REC
4526 -rwx 0 21:57:44 Jul 19 2021 FSCK1436.REC
4527 -rwx 0 21:57:44 Jul 19 2021 FSCK1437.REC
4528 -rwx 0 21:57:44 Jul 19 2021 FSCK1438.REC
4529 -rwx 0 21:57:44 Jul 19 2021 FSCK1439.REC
4530 -rwx 0 21:57:46 Jul 19 2021 FSCK1440.REC
4531 -rwx 0 21:57:46 Jul 19 2021 FSCK1441.REC
4532 -rwx 0 21:57:46 Jul 19 2021 FSCK1442.REC
4533 -rwx 0 21:57:46 Jul 19 2021 FSCK1443.REC
4534 -rwx 0 21:57:46 Jul 19 2021 FSCK1444.REC
4535 -rwx 0 21:57:48 Jul 19 2021 FSCK1445.REC
4536 -rwx 0 21:57:48 Jul 19 2021 FSCK1446.REC
4537 -rwx 0 21:57:48 Jul 19 2021 FSCK1447.REC
4538 -rwx 0 21:57:48 Jul 19 2021 FSCK1448.REC
4539 -rwx 0 21:57:50 Jul 19 2021 FSCK1449.REC
4540 -rwx 0 21:57:50 Jul 19 2021 FSCK1450.REC
4541 -rwx 0 21:57:50 Jul 19 2021 FSCK1451.REC
4542 -rwx 0 21:57:50 Jul 19 2021 FSCK1452.REC
4543 -rwx 0 21:57:50 Jul 19 2021 FSCK1453.REC
1457 file(s) total size: 121592481 bytes
7365472256 bytes total (4020453376 bytes free/54% free)
ciscoasa# sho bootvar
BOOT variable =
Current BOOT variable =
CONFIG_FILE variable =
Current CONFIG_FILE variable =
ciscoasa#
07-20-2021 09:52 AM
- Try :
fsck flash:
M.
07-20-2021 10:31 AM
Below is the result.....
ciscoasa# fsck flash:
ERROR: There are one or more sw-modules running on the system. Please shut down the sw-modules before attempting to run fsck on flash:
07-21-2021 12:28 AM
- Ref : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuw95262
Unfortunately resolving this problem depends on a software upgrade , since your system is not usable, your only option is to ask advice from cisco TAC, because you have a chicken and egg problem (make a call).
M.
07-21-2021 05:13 AM
07-21-2021 06:06 AM
>...Do I need to have a service contract with Cisco TAC
Yes, and or this particular problem is beyond the scope of the forum (can not be resolved here)
M,
05-20-2022 12:01 AM
Hi Ammar,
we see the same problem on a number of ASA5506 devices that we use. The devices have been running fine but at some point they failed. We are trying to find the root cause. The devices have hardware version v07 so we should not be affected by the clock signal problem described here: https://www.cisco.com/c/en/us/support/web/clock-signal.html#~overview
Questions:
- Was the root cause found for this problem?
- Anybody else suffering from this?
- Can the flash memory get corrupted when the power is removed from the device during normal operation?
Tom
Here is the output from the boot sequence
Attempt autoboot: "boot disk0:/asa982-lfbff-k8.SPA" Located 'asa982-lfbff-k8.SPA' @ cluster 40065. ########################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################## Signature verification failed for key# 1 Failed to validate digital signature Signature verification failed for key# 1 Failed to validate digital signature LFBFF signature verification failed!! No kernel found to launch.
