Cat 3850 stacks with Cacti
ziutek
I would like to monitor CPU util. on a 3850 stack (4 switch stack) using Cacti.
I have tried using the standard Cisco CPU template, but for the 3850, this does not return any values.
I have browsed the device with a MIB browser, and have identified the appropriate OID (which is actually the same as the OID used by the standard Cisco CPU template), but I still cannot get any data into a graph.
I actually see these errors in the Cacti log:
09/07/2016 10:08:13 AM - CMDPHP: Poller[0] Host[333] DS[5163] WARNING: Result from SNMP not valid. Partial Result: U
09/07/2016 10:03:08 AM - CMDPHP: Poller[0] Host[333] DS[5163] WARNING: Result from SNMP not valid. Partial Result: U
09/07/2016 09:58:08 AM - CMDPHP: Poller[0] Host[333] DS[5163] WARNING: Result from SNMP not valid. Partial Result: U
09/07/2016 09:53:07 AM - CMDPHP: Poller[0] Host[333] DS[5163] WARNING: Result from SNMP not valid. Partial Result: U
09/07/2016 09:48:10 AM - CMDPHP: Poller[0] Host[333] DS[5163] WARNING: Result from SNMP not valid. Partial Result: U
09/07/2016 09:43:08 AM - CMDPHP: Poller[0] Host[333] DS[5163] WARNING: Result from SNMP not valid. Partial Result: U
09/07/2016 09:38:08 AM - CMDPHP: Poller[0] Host[333] DS[5163] WARNING: Result from SNMP not valid. Partial Result: U
09/07/2016 09:35:09 AM - CMDPHP: Poller[0] Host[333] DS[5163] WARNING: Result from SNMP not valid. Partial Result: U
09/07/2016 09:32:08 AM - CMDPHP: Poller[0] Host[333] DS[5163] WARNING: Result from SNMP not valid. Partial Result: U
09/07/2016 09:27:17 AM - CMDPHP: Poller[0] Host[333] DS[5163] WARNING: Result from SNMP not valid. Partial Result: U
Any help with this would be much appreciated.
Joe
