CAT3750 Temperature via OID
thomascollins
Level 3
Level 3
I have a 3750 that should support temperature readings (WS-C3750G-48TS). In fact through CLI I can get the exact temperature:
show env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 40 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 56 Degree Celsius
Red Threshold : 66 Degree Celsius
POWER is OK
RPS is NOT PRESENT
So it would seem that I should be able to read the temperature via SNMP. But the OID that I thought it was, returns nothing:
snmpget -v1 -cmystring myswitch 1.3.6.1.4.1.9.9.13.1.3.1.3
Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: SNMPv2-SMI::enterprises.9.9.13.1.3.1.3
I read somewhere else that the OID might be different because these are stackable switches? Not sure if that is true?
2 Accepted Solutions
nhabib
Level 9
Level 9
Try snmpwalk instead of snmpget and see if you have better success.
unbrowser
It seems you are trying to retrieve this object.
CISCO-ENVMON-MIB::ciscoEnvMonTemperatureStatusValue
This is a column in the table ciscoEnvMonTemperatureStatusTable. You need to append an index to the OID if you want to retrieve table entries. You can use the snmpwalk command or a free MIB browser such as Unbrowse or iReasoning to find out the index values.
7 Replies 7
nhabib
Level 9
Level 9
unbrowser
Wow perfect thanks guys. SNMPWALK showed me the correct OID. Oddly, it is .1005. Not sure why?
snmpwalk -v1 -cmystring myswitch 1.3.6.1.4.1.9.9.13.1.3.1.3
SNMPv2-SMI::enterprises.9.9.13.1.3.1.3.1005 = Gauge32: 40
Any idea what it might be .1005? It does appear to be consistant for all my switches, so it'll work.
THANKS!!!
Hi Thomas
Since its your master switch you're getting the temperature from, the 1005 number indicates that its switch number 1 which is the master..
I have a stack where switch 2 is the master, on that switch stack i need to poll the mib with .2005 at the end of the OID.
Interesting, thanks!
Hi there, do you know the default values (normal, warning, critical) of temperature for the this catalyst. What value is for default warning and critial. Thanks
You can see this via the "show env temp status" command.  Here's mine:
#show env temp status
Temperature Value: 28 Degree Celsius
Yellow Threshold : 46 Degree Celsius
Red Threshold    : 60 Degree Celsius
Also, I created a Cacti template for graphing the temperature on a 3750 stack, if anyone's interested:
https://www.hightail.com/download/OGhjc2ZGSWhZY1FLSk1UQw
