Catalyst 2960 Two mac's on one port need two vlans
fixitrodd
I have a device that does ip audio on one mac address and managagement is on another mac address. Both of these mac addresses come from one NIC on the device. We need to split these two traffic paths into two different vlans.
How can I program this switch to sperate the different traffic into two vlan's based on mac address on one interface?
Thank You very much!!!!!
Leo Laohoo
Configure the port as a 802.1Q Trunk and allow only the two VLANs you need.
Here's what it is. It's and ip audio device that has cobranet and control traffic. You can't have the device tag the traffic so 802.1Q may be non available. That's what I need the switch interface to do... seperate the traffic and tag it. Cobranet doesn't have an ip address, just a mac address.
I'm guessing it would be similar to if you had a hub hooked up to a port and wanted to tell the switch what vlan each mac address belongs too... if that's possible.
Your help is aprreciated very much!!!!!!
