catalyst 4500-X SFP issues
Sivan
Hello guys,
I have a Catalyst 4500-X switch which is having all TenGigabyteEthernet ports. I am using a mix of 10Gbe SFP fibre modules and 1 Gbe SFP Ethernet modules. My issue is some of the ports doesn't comes up if i remove and reconnect the cables (or restart the device which is connected on the port). I may need to remove the SFP module in that port multiple times and reconnect again, then only it comes. Once its up its working fine. Even if i connect my laptop to any of these ports, it doesn't show any connection. Please help. Is that something to configure on that ports or switch... All the ports are in Static access administrative mode and part of a VLAN. If i change the port speed to 1Gbe or 10Gbe according to devices attached will it help ?.. please advice.
here is what the statement would look like , this is from my 4500x below , you would add your image name in place and save it then check command show bootv to confirm its ready before reload
#sh run | i boot
boot-start-marker
boot system flash bootflash:cat4500e-universalk9.SPA.03.08.07.E.152-4.E7.bin
boot system flash bootflash:cat4500e-universalk9.SPA.03.06.07.E.152-2.E7.bin
boot-end-marker
#show bootv
BOOT variable = bootflash:cat4500e-universalk9.SPA.03.08.07.E.152-4.E7.bin,1;bootflash:cat4500e-universalk9.SPA.03.06.07.E.152-2.E7.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby BOOT variable = bootflash:cat4500e-universalk9.SPA.03.08.07.E.152-4.E7.bin,1;bootflash:cat4500e-universalk9.SPA.03.06.07.E.152-2.E7.bin,1;
Standby CONFIG_FILE variable does not exist
Standby BOOTLDR variable does not exist
Standby Configuration register is 0x2102
25 Replies 25
balaji.bandi
Can we have more information about the modules, and SFP information.
show version
show modules
show interface information (where you have issue)
BB
Dear Balaji,
Attached the response. The interface status by using "show interfaces" command. Attached them. My issue is main on port 1/1 and port 1/2. Both are in a single VLAN 31. The sttus on these ports shows not connected Line protocol is down. If i remove the SFP and reconnect it , then it starts working.
Harmonic_Switch_A#show interface tenGigabitEthernet1/1
TenGigabitEthernet1/1 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet Port, address is 6c20.56c5.ba10 (bia 6c20.56c5.ba10)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, link type is auto, media type is 1000BaseT
input flow-control is off, output flow-control is off
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
77781 packets input, 18770499 bytes, 0 no buffer
Received 1126 broadcasts (70 multicasts)
78945 packets output, 18871065 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
Harmonic_Switch_A#
Harmonic_Switch_A#show interface tenGigabitEthernet1/1 status
Port Name Status Vlan Duplex Speed Type
Te1/1 notconnect 31 full auto 1000BaseT
The show module command returns as below;
Harmonic_Switch_A#show module
Chassis Type : WS-C4500X-16
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 16 4500X-16 10GE (SFP+) WS-C4500X-16 JAE16490E1I
M MAC addresses Hw Fw Sw Status
1 6c20.56c5.ba10 to 6c20.56c5.ba1f 1.0 15.0(1r)SG6 03.06.03.E Ok
System Failures:
Power Supply: bad/off (see 'show power')
show interfaces tenGigabitEthernet1/1 capa command return as below (But this command run after making the port up by re-inserting the SFP on the same port)
Harmonic_Switch_A#show interfaces tenGigabitEthernet1/1 capa
Model: WS-C4500X-16-Gbic
Type: 1000BaseT
Speed: 1000,10000
Duplex: full
Auto-MDIX: no
EEE: no
Trunk encap. type: 802.1Q
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100), hw
Multicast suppression: percentage(0-100), hw
Flowcontrol: rx-(off,on,desired),tx-(off,on,desired)
VLAN Membership: static, dynamic
Fast Start: yes
CoS rewrite: yes
ToS rewrite: yes
Inline power: no
SPAN: source/destination
UDLD: yes
Link Debounce: yes
Link Debounce Time: yes
Port Security: yes
Dot1x: yes
Maximum MTU: 9198 bytes (Jumbo Frames)
Multiple Media Types: no
Diagnostic Monitoring: N/A
Harmonic_Switch_A#
Harmonic_Switch_A#
Hi Sivan
have you tried hard coding the port as its copper  GLC-T SFP, that will remove negotiation ?
speed 1000, duplex full
see if that makes a difference
Are these ports directly connected or is there a patch panel in between?
Dear Mr.Mark,
These ports are directly connected.
Dear Mr.Balaji & Mark,
I have tried to change the port speed, but that doesn't allow me to change the port speed. i am getting error as below
Harmonic_Switch_A#config t
Enter configuration commands, one per line. End with CNTL/Z.
Harmonic_Switch_A(config)#interface ten
Harmonic_Switch_A(config)#interface tenGigabitEthernet 1/10
Harmonic_Switch_A(config-if)#speed 1000, duplex full
% Invalid input detected at '^' marker.
I have tried with CNA, but still its the same returns me an error.
kindly suggest.
1 command at a time as below
There is a copper SFP in that port yes ?
Harmonic_Switch_A(config-if)#duplex full
Dear Mr.Mark,
Yes those are copper SFPs except the ones connected in ports 11-16 (using 10G fiber)
The commands returns as below
Harmonic_Switch_A>
Harmonic_Switch_A>enable
Password:
Harmonic_Switch_A(config-if)#end
Harmonic_Switch_A#
*Apr 1 13:56:17.164: %SYS-5-CONFIG_I: Configured from console by console
Harmonic_Switch_A#
i just tested this on a 4500x
duplex command not available and with GLC-T in place you can only do speed 100, try that below
xxxxxx(config)#int t1/1/15
xxxxxx(config-if)#spe
xxxxxx(config-if)#speed ?
10 Force 10 Mbps operation
100 Force 100 Mbps operation
xxxxxxxxxx#sh int t1/1/15 | i Base
Full-duplex, 100Mb/s, link type is auto, media type is 1000BaseT
Hi Mr.Mark,
I really need these ports to be working in 1Gbe... So changing to 100 mbps wont work for me. But i will try this to make sure, my issues are because of that. I am not even able to connect my laptop to these ports. Don't know what i will do. A low priced HP Procurve switch works better than this without any of these mess ups.  :(
Could you not use a glc-sx-mmd fibre 1gb connection then instead, the 4500x is a fibre switch really a distribution switch 10gb , you could check what options your has by using the tab question mark ? too when your glc-t is connected to see if you have a 1gb copper option , mine does not as i posted but qe use ut as a 10gb distribution switch
This could be the reason, as suggest other post, set the speed 1G, connect the Laptop and test before actually connecting real port.So this confirm port working as expected.
BB
Dear Mr.Balaji,
Currently if i am connecting my laptop it doesn't work on these ports. So let me try this to force for 1G then will let you know. Thank you for your efforts and i will update you soon
Looking at the supported guide you should be able to do 1000mb with a GLCT , it gives 3 different versions of software as minimum though , what version are you on ? ia m on 3.8.7 maybe try the later 3.10
GLC-T
End Of Sale
10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic 0 to 70C N IOS 3.7.1E —
GLC-T
End Of Sale
10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic 0 to 70C N IOS 3.8.4E —
GLC-T
End Of Sale
10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic 0 to 70C N IOS 3.10.0E
Hi Mark,
I am on Version 03.06.03.E. I tried to update the software via CNA GUI, but it returns me a message saying File size is bigger than allowed in TFTP server. So i scared to do as i dont know the right procedure to do. Also its a bit expensive switch. I have the latest ROM bin file, but let me know how to update this.
