CBW150AX web interface management
kasper
Level 2
Level 2
I have set CBW150AX by using the Cisco Business iOS app. That works fine. However I would like the possibility of monitoring and configuring by web interface but whenever I try to connect to the unit it times out.
Why is it not possible to access the web UI?
Thanks.
12 Replies 12
Mark Elsen
 -  Can you ping the device (with the address or hostname as used in the browser) ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Yes, I can ping it and I can connect to it on WiFi.
 - Check if there's no local firewall on your device blocking http(s) access to it  , same for intermediate firewalling (if any). Check if you can get to the web interface on a device on the same subnet as the AP (if applicable) to verify possible unwanted firewalling .  You may further get insights by for instance using google chrome, press F12 first , then press the network tab, then connect to the CBW150AX web interface . (look for web traffic) , try the other tabs too in the chrome developer tools to analyze the problem ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thank you. However there is unfortunately no usable info in the dev tabs. It is a timeout.
  - That still means that there is a fundamental problem with the (needed) network path (connectivity) , look for the first sentences in my earlier reply concerning firewalling issues and for instance try traceroute to the AP.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Yes, I know. I have tried to setup a network of just the AP and a Mac. No firewalls. Still no connection, just timeout. It is like the AP not accepting the request.
A traceroute just returns * * *
             >....I have tried to setup a network of just the AP and a Mac
                       Try to use a switched network in between
 - Connect a console and reboot it , watch for errors if any during boot.
   Ref : https://nmap.org/  Also try : % nmap --reason -p443 CBW150AX                   (hostname)
 M.
       Beauty and terror
      Just keep going
       No feeling is final
kasper
Level 2
Level 2
Thank you, I need to try that at a later stage. But I have connected 8 AP's connected and none of them can be accessed. There are no firewalls or anything else. It is very frustrating!
 - Postponing analytics and or suggested troubleshooting makes no sense ; the problem won't go away....
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Well, yes that's true, but it's also easy to say!
I don't have the big experience in the console. You wan't me to console into the switch? And then how do I find the issue of the AP?
 - The referenced nmap command from my earlier reply needs to be executed from the device you are trying to access the AP from ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
kasper
Level 2
Level 2
For some reason the web interface started working after a lot of reboots during the installation.
Thank you for taking the time.
