CCNA 200-301
samuelnwadike
hi everyone
please just to verify, someone has just told me that its not advisable to use wide card mask in the exam for either eigrp or ospf. please and please can this be true, is there any fact in this ?
8 Replies 8
Javier Acuña
Greetings, thanks for communicating with the Cisco community. I understand that you want to advertise routes with a mask, it is preferable to use smaller masks to even initiate the routes, then I will send you a comparison between the different routing protocols.
 EIGRPOSPF
Setup
Easy
Difficult
Design
Flexible
Rigid
Scalability
Medium to Large Networks
Large Networks
CPU, Memory, and Bandwidth
More Efficient
Less Efficient
Provider Support
Less likely supported
Most likely supported
Load balancing
Equal and Unequal
Equal
IPv6
EIGRP Classic mode for IPv4 EIGRP Named mode for IPv6
Traditional OSPF OSPFv3 for IPv6 address family
In the graph you will find the assessment of convergence according to the routes
remember to rate this answer as this motivates you to continue contributing click on the star
Martin L
why not? it depends on a question; they may ask to advertise /30 only but not /24 or vice versa or they don't care.
I took CCNA very long time ago and I could use it or not, it was up to me. But I am not sure about  new CCNA exam.  you could ask this on CLN in CCNA study group/forum to see if anyone has any issues with wide card mask in the exam.
Note: Since COVID number of people taking exams is low, so you may not get answer but in case of eigrp/ospf, it should be similar to previous exam version.
https://learningnetwork.cisco.com/s/discussions
Regards, ML
**Please Rate All Helpful Responses **
Thanks for your responds it dose help, please would you be kind to give me links to better study group(s). the ones i have on what's app, seems to be a sales point where they never answer questions but suggest what you could buy to get answers from.
Thanks Martin L
go and look around in https://learningnetwork.cisco.com/s/communities
CLN is the official Cisco site for certs, exams, and exam topics/technologies;
This site here is more of real-world issues and technologies and support.
Regards, ML
surbhinahta
I am also learning CCNA and this information helps me to learn more about it.
CCNA is the first step toward your IT career and it is an entry level networking certification. If a person is CCNA certificate holder then he can get suited job in his desired IT field. If  you are interested in  learning CCNA then you can get in touch with seven mentor, it provides best CCNA course in Pune and has record of almost 100% placement of their students.
rishabsain
Thanks for sharing. The CCNA is an entry-level networking certification that can allow you to get a career as a network expert, network administrator or network engineer in the IT industry. It refers to Cisco's wide range of technical skills in the IT sector. Organizations choose these industry-standard certifications because they show a job candidate's technical training and expertise.
CCNA Course In Pune
iteducation92
Your sharing of the CCNA certification is much appreciated. It demonstrates a deep understanding of the IT industry and certifies that you possess the necessary knowledge to be a network expert, administrator, or engineer. It is also a testament to one's technical training and demonstrates one's skills aligning with industry standards.
CCNA course in Pune
