ccna loopback address
daniel45793
Frequent Visitor
Frequent Visitor
hi
can someone explain to me  when will i use loopback address
and is there loopback address on switch or only on router  and if there is on a switch then when will i use it
thanks (:
Martin L
Mainly loopback address is used as router ID since loopbacks interfaces are always up up (ospf and bgp).
For your home lab, you can add several loopback addresses to simulate various networks.   otherwise, you would have to add a device, which could be costly.
L3 switches and routers can have loopback interfaces.
Regards, ML
**Please Rate All Helpful Responses **
Martin L
Regards, ML
johnd2310
Level 11
Level 11
A loopback interface is always up and therefore, makes a stable interface. We use this stable interface things like management and routing. Most switches now support routing and will support loopback interfaces. If your switch supports loopback interfaces, then you would use the loopback interface for management or router-id for routing protocols.
John
**Please rate posts you find helpful**
