check_dial_peer_status.tcl
leagle
I tried e-mailing this to askabouteem.cisco.com but received an smtp error for this address.
I’m using the check_dial_peer_status.tcl to provide notification of when a SIP dial-peer is down.  Can this .tcl and the event manager commands be modified to monitor more than one SIP dial-peer?  Below are the dial-peers, Event Manager commands and the .tcl script.  I would like to monitor dial-peers 200 and 300.  I’m currently monitoring dial-peer 200.
US-HAL-NP1-CUBE2-I6#sh dial-peer voice sum
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT    KEEPALIVE
1000   voip  up   up             [2-9].........     1  syst                               active
200    voip  up   up             .T                 0  syst                               active
2000   voip  up   up             [2-9].........     2  syst                               active
300    voip  down down           map:400            0  syst
600    voip  up   up             map:300            0  syst                               active
track 200 stub-object
event manager environment dial_peer_number 200
event manager environment check_interval 30
event manager directory user policy "flash:/"
event manager applet siptrunk_down
event track 200 state down
action 10 snmp-trap strdata "siptrunk DOWN"
action 20 syslog msg "siptrunk down"
event manager applet siptrunk_up
event track 200 state up
action 15 snmp-trap strdata "siptrunk UP"
action 25 syslog msg "siptrunk up"
event manager policy check_dial_peer_status.tcl
::cisco::eem::event_register_timer watchdog time $check_interval nice 1
# Namespace imports
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
#--- Check required environment variable(s) has been defined
if {![info exists dial_peer_number]} {
   set result "EEM Policy Error: variable dial_peer_number has not been set"
   error $result $errorInfo
#------------------- " cli open" -------------------
if [catch {cli_open} result] {
} else {
   array set cli $result
#----------------------- "enable" ----------------------
if [catch {cli_exec $cli(fd) "enable"} result] { error $result $errorInfo }
#-------------- grab sip ood options-ping and track status --------------
if [catch {cli_exec $cli(fd) "show dial-peer voice sum | inc $dial_peer_number "} result] {
set cmd_output $result
array set track_result [action_track_read $dial_peer_number]
set track_state $track_result(state)
#-------------- set stub status --------------
if [string match "*busyout*" $cmd_output] {
   if { $track_state == "up" } {
       action_track_set $dial_peer_number state "down"
if [string match "*active*" $cmd_output] {
   if { $track_state == "down" } {
      action_track_set $dial_peer_number state "up"
#--------------------- cli close ------------------------
catch {cli_close $cli(fd) $cli(tty_id)} result
Joe Clarke
This should work.  Change your dial_peer_number value to 200,300:
# Namespace imports
} else {
foreach dp [split $dial_peer_number ","] {
if [catch {cli_exec $cli(fd) "show dial-peer voice sum | inc \"^$dp \""} result] {
array set track_result [action_track_read $dp]
       action_track_set $dp state "down"
      action_track_set $dp state "up"
I got an error with the foreach command.  I was able to get it working by creating two .tcl scripts with a unique dial_peer_number variable for each script.
